(unknown)
Have you checked the E-Gruop site to see if your still a member?
>>> keith@... 02/13/01 02:12PM >>>
Trying to figure out why I have not been getting messages for over 2
days. Could a moderator contact me offline at keith@...
Yahoo! Groups Sponsor
www.
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
Thanks for the info. DeAnna. I'll look into it. I think the 'line of site' issue may have us against a rock and a hard place from the get-go.
Troy
----- Original Message -----
To: Vantage
Sent: Thursday, May 24, 2001 12:34 PM
Subject: [Vantage] (unknown)
Troy
We had a microwave linking our two buildings. Our second facility basically
only ran data collection. It was a little slow. The microwave we had was
very inexpensive, we paid less than 3K installed. This was in 1995. The
company we got it from Innetix.
There website is www.innetix.com. I was not involved in the installation
so I don't know a lot of details. We no longer use it because we
consolidated our facilities, but we did run 4.0 on it.
De Anna Godfrey
V.P.
McNeal Enterprises, Inc.
408.922.7290 x14
fax 408.922.0728
Sent: Thursday, May 24, 2001 8:29 AM
To: Vantage
Subject: [Vantage] [off topic] LAN Wireless Access Point for 3.5 miles
Is anyone using, or is anyone aware of Wireless hardware that could connect
a LAN with a distance of 3.5 miles? We have a small manufacturing area
around 3.5 miles (as the crow flies) from our main plant, and would like to
connect about 5 or 6 PC's to our network for data collection and minimal
Vantage use.
Troy Funte
Liberty Electronics
Yahoo! Website Services- Click Here!
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Cisco makes wireless connection products called Aeronet that can
reach up to around 20 miles.
get-go.
> Troy
> From: De Anna Godfrey
> To: Vantage
> Troy
facility basically
we had was
1995. The
installation
> De Anna Godfrey
> V.P.
> 408.922.7290 x14
> fax 408.922.0728
> From: Troy Funte [mailto:tfunte@e...]
> To: Vantage
miles
could connect
area
would like to
minimal
> Vantage use.
> Troy Funte
> Liberty Electronics
Service.
Brent,
More and more of us seem to be bumping into this issue. Below are some links to Seagate about this error which I got from a .pdf file that Ted Kitch sent me. It seems to suggest that the fact that SQL-92 needs to login to progress, which Vantage reports can't do currently, causes this error. There are, however, other situations that cause this error. I found the error goes away when I use the Standard Merant 3.5 or 3.6 drivers (not the SQL-92 driver that comes with Progress).
A couple things you can try... 1. Link the new table in a subreport instead of the main part of the report and see what happens. 2. Use a Merant ODBC driver if you have one (costs $$). 3. Compile the report and uses the traveler.exe file in the Report Style Maintenance. 4. Export the needed table to a .dbf (or .csv), import it to Access, and then link the Crystal report to Access.
Also, please add your name to the list of users with issue#: 748545MPS and Error 599. This Issue is in 5.1, but I believe it exists in 5.0 also for those using the SQL-92 driver.
Please advise us as to how your doing with this... And here are the Seagate articles on the subject...
Error 599 - Returned when the user passes invalid database logon information
http://support.crystaldecisions.com/library/kbase/articles/C2001630.asp
http://support.crystaldecisions.com/library/kbase/articles/C2007581.asp
http://support.crystaldecisions.com/library/kbase/articles/C2007612.asp
http://support.crystaldecisions.com/library/kbase/articles/C2003803.asp
http://support.crystaldecisions.com/library/kbase/articles/C2002982.asp
Troy Funte
Liberty Electronics
Sent: Thursday, January 17, 2002 9:38 AM
We are on Vantage 5.0.337 and encountering problems adding new tables
to a custom job traveler using Crystal v8. The errors are as follows:
Your current link configuration contains multiple starting points.
Please be advised that this is generally not supported.
More than one database driver has been used in this report. If you
want to change the database drivers, use Database/Convert
Database Drivers.
Also, please make sure that no SQL expression is added and no
server-side
group-by is performed.
Also, when I try to link the key fields of the new tables with the
existing ones, I get "this is not a key field" even though they are
all indexed fields.
When we were at Vantage 5.0.325, I was able to add new tables without
getting all these errors. However, I did need to load the full
version of Crystal reports on each workstation viewing the traveler
in order to resolve the error 599 issue.
Now, I am getting error 599 even on the workstations with the full
version of Crystal. There were times when I was able to view the
traveler after adding a field from the new table, but the printout
was screwed up and some detail lines were printing out of sequence.
I did see some of the past messages on ODBC errors but I believe my
situation is a little different. I am using the Merant 3.60 SQL92
v9.1A driver and was told by technical support there may be a new
patch for this and that I should also consider ugrading Progress to
9.1C.
I would welcome anyone's advice or comments on this.
Thanks.
Brent O'Donnell
ADVERTISEMENT
Mark,
Would you be willing to share your report? That is something I could really use.
Dina
Shirley Graver wrote:
> Mark,
> Go into the border, to the left of your data fields, where its labled,
> "Record" "Page Header" etc. Right Click on any bandline Select "Band Line"
> from the dropdown list. Click the Radio Button, "Different Type", then go to
> the drop down any you will see band line types labled with the GROUPS that
> you've created. They will be in the order of precedence that you setup in
> groups. You have a choice of Header Or Footer band lines. Select your
> customer then select your shipto header bands. Don't worry if you select
> them out of order they go in in the right order regardless. Then put your
> Customer fields up in the customer band line, and your ship to's in the ship
> to band lines.
> Shirley
> -----Original Message-----
> From: Mark Smith [mailto:mark_smith@...]
> Sent: Friday, June 14, 2002 10:21 AM
> Subject: RE: [Vantage] (unknown)
> Shirley,
> Still getting learning how to setup groups etc. If I create a group
> (within
> groups) for customer and ship-to on company how do I set conditional
> print?
> From: Shirley Graver [mailto:shirleyg@...]
> Sent: Friday, June 14, 2002 8:45 AM
> Try a left outer join to the Ship To from Customer, Your link fields are
> Company, Customer ID, and ShipTo Number. Create a group for customer,
> and
> shipto, (Customer group1 and Shipto Group2) On the line for the ShipTo
> set
> Conditional Print to "Print when field has contents and select a field
> from
> the ShipTo table.)
> Shirley Graver
> Systems Administrator
> Rubber Associates Inc.
> Cleveland/Akron, OH
> From: innerpac_il [mailto:mark_smith@...]
> Sent: Friday, June 14, 2002 9:34 AM
> Hi,
> I am trying to create a report for management that gives customer
> name, address, etc/sales rep/ship-to-name, address etc/and last order
> date. I have successfully linked customer and last order date by
> joining customer to orderhed on company, and creating a aggregate
> field called lastorderdate. However, if ship-to address differs from
> customer address (sold-to) how can I pull this from the ship-to
> table, so the report will display both customer address and ship-to
> (assuming they are different)?
> Mark Smith
> and
> ADVERTISEMENT
> and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Dina M. Hieber
Vamco International, Inc.
555 Epsilon Drive
Pittsburgh, PA 15238
(412) 963-7100 - phone
(412) 963-9511 - fax
www.vamcointernational.com
If I can get it to work I'd be glad to!
Sent: Friday, June 14, 2002 11:27 AM
Subject: Re: [Vantage] (unknown)
Mark,
really use.
Dina
> Mark,
labled,
Line"
go to
that
in
select
your
ship
> to band lines.
> Shirley
> Shirley,
> (within
> print?
are
customer,
> and
ShipTo
> set
field
> from
> the ShipTo table.)
> Shirley Graver
> Cleveland/Akron, OH
> Hi,
order
from
ship-to
> Mark Smith
must
access. )
Builder
> and
Service.
> ADVERTISEMENT
must
access. )
Builder
> and
and
Dina M. Hieber
555 Epsilon Drive
I think this would probably be a little easier, unless I'm missing
something in your request:
Without going into too much detail, just make sure you have a sort on order
date (after the other items you wish to sort on), and show it in a group
footer. It will then only show the latest order date. If this is too
vague, I'll elaborate. Unless, of course, someone proves me wrong! :+)
__________________________
Gary Grenier
IT Manager
Bell Manufacturing Co.
(207) 784-2961 x245
mailto:ggrenier@...
Subject: (unknown)
Hi,
I have been asked to create a report for management, which I have
been working on for the last couple of days, but can't seem to get it
just right. The report I am working on lists customer, ship to,
sales rep and last order date. I'm doing something wrong as I am
very close, but not sure what it is. Does anyone have any experience
with a report like this? I am really running out of ideas on how to
fix it (and patience).
Mark Smith
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. If the reader of this message is not the intended recipient, you
are hereby notified that you have received this message in error and that
any review, dissemination, distribution or copying of this message
including any attachments is strictly prohibited. If you received this in
error, please contact the sender and delete the material from any computer.
Bill,
Do you have any reports to share that are similar to this?
Mark Smith
IT Manager
Innerpac, Inc.
(708) 863-8300
Sent: Wednesday, June 19, 2002 3:28 PM
Subject: [Vantage] Re: (unknown)
Gary Grenier
IT Manager
(207) 784-2961 x245
mailto:ggrenier@...
Subject: (unknown)
Hi,
Mark Smith
BLing,
In 6.1 the change log is created by the Business Activity Manager found
either under the Executive Analysis or System Management (Utilities).
You will need to set this up to start tracking changes. The nice part
is you can track the fields you want and can use this to launch alerts
via email to users. The bad news is you have to set it up first and
then it will start recording the changes.
If you have any further trouble with this just ask.
HTH
Aaron Hoyt
Hittite Microwave
Sent: Tuesday, August 10, 2004 9:31 PM
Hi Group,
I'm new in Vantage 6.1 and was confuse on change
log, i'm able to view change log in the training DB -
Milwaukee but NOT in the new created company!
Any setting need to be done before i can view
change log? Any prompt will be much appreciated!
Good Day,
BLing
PSB
__________________________________
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
access. )
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=1297o9gn4/M=298184.5285298.6392945.3001176/
D=groups/S=1705007183:HM/EXP=1092274287/A=2164331/R=0/SIG=11eaelai9/*htt
p://www.netflix.com/Default?mqso=60183351>
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=group
s/S=:HM/A=2164331/rand=333835853>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <http://docs.yahoo.com/info/terms/> .
We are just now testing Vantage 6.1.512 and have found that the Production
Detail report will lock the client if you search for a job for the report.
If you just enter the job number it will work fine. Has anyone else seen
this? Is there a fix for it? This happens on all our test workstations.
Any insight appreciated.
Paul Lipham
Alabama Specialty Products, Inc.
256-358-4202
We just migrated to Vantage 6.0.524. Most everything works as
expected...except the Production
Detail locks up the user when browsing for a job. Epicor states that
this problem is unique to
our install. They say that they cannot reproduce it.
To the best of my knowledge, this problem does NOT occur here. If this is
happening to Vantage users here, they have not reported it to me. I can say
with certainty that I personally have not seen this happen.
Regards,
Scott Lepley
Mauell Corporation
Phone: 717-432-8686, ext. 14
Fax: 717-432-8688
Email: sal@...
Vantage version: 6.10.512
Sent: Wednesday, August 11, 2004 10:14 AM
Subject: [Vantage] Vantage 6.1
Paul Lipham
256-358-4202
We are on 6.1.511 and our production detail report runs fine -- did this just occur going to .512 or where you on a lower version than 6.1.511
Sent: Wednesday, August 11, 2004 9:14 AM
Paul Lipham
256-358-4202
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1294e1616/M=298184.5285298.6392945.3001176/D=groups/S=1705007183:HM/EXP=1092320021/A=2164330/R=0/SIG=11eamf8g4/*http://www.netflix.com/Default?mqso=60183350> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=:HM/A=2164330/rand=982964395>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
We went straight to the 512 patch when installing the new server.
Paul
Sent: Wednesday, August 11, 2004 9:52 AM
Subject: RE: [Vantage] Vantage 6.1
Paul Lipham
256-358-4202
ADVERTISEMENT
netflix.com/Default?mqso=60183350> > click here
:HM/A=2164330/rand=982964395> >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129hbutpl/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705007183:HM/EXP=1092322366/A=2164331/R=0/SIG=11eaelai9/*http://www.
netflix.com/Default?mqso=60183351> click here
:HM/A=2164331/rand=731387051>
_____
Yahoo! Groups Links
We are on the .511 patch.
For us the Production Detail report runs,
but, occasionally, it takes an extremely
long time to respond. During this delay,
it is possible for a user to conclude that
the client has locked up.
We have no idea what the cause might be.
Paul Lipham
256-358-4202
Yahoo! Groups Links
Just wanted to update you guys on the Production Detail report lockup. We
finally realized if we would wait about 30 to 45 seconds after searching for
a job and selecting it the program would finally respond and you could print
the report. They have had us do all kinds of performance tuning to the
progress setup and make changes to the client setup as well. Nothing has
worked and now they want to see the database.
Everything else in the database runs really fast on the new server. I don't
think they can say the server or workstations do not have enough punch to
get the job done.
If anyone else is having this problem it might be good to contact Vantage
support just to let them know the problem isn't isolated.
Sent: Wednesday, August 11, 2004 9:47 AM
Paul,
I just tested and can confirm your problem.
I am calling into support now.
Sent: Tuesday, August 17, 2004 10:31 AM
Subject: RE: [Vantage] Vantage 6.1.512
We
for
print
has
don't
to
get the job done.
Vantage
Yahoo! Groups Links
Its an enhancement
Sent: Tuesday, August 17, 2004 11:50 AM
Paul,
We
for
print
has
don't
to
get the job done.
Vantage
Yahoo! Groups Links
Yahoo! Groups Links
How about if you click By Product Group?
I just tested this and the screen goes dead and you can see all the jobs
by that product group scroll sporadically.
Vantage locks up and you have no choice but to close out.
We
for
print
has
don't
to
get the job done.
Vantage
Yahoo! Groups Links
Thanks John!! At least I know it's not just our setup.
Jeremy you crack me up... I wonder what other enhancements they have? I
needed that!
Paul
Sent: Tuesday, August 17, 2004 10:50 AM
Paul,
We
for
print
has
don't
to
get the job done.
Vantage
