The Epicor sales junkies also have additional drivers/patches and custom stuff written in to boost their dog and pony shows at customer sites that run considerably faster than you ever will in a real-live system and they very well might be running 8.04 while selling you 8.00.
Also single user vs. 10 users will show a difference ultimately in true performance. You'll want to give yourself time to tune for performance the live server while users are doing testing/hammering away before you go-live. good way to run load-testing.
Its almost a guarantee that what you see on the sales pitch is not what you will get on your go-live. I always wondered why those sales guys never saw the umpteen unexpected application errors that we are so readily able to produce, on their laptops.
Given that disk and ram are cheap these days, I wouldn't skimp on either particularly RAM.
RSN
Aaron Hoyt <
aaron.hoyt@...> wrote:
Todd,
I purchased a DualCore Laptop for just this purpose. I figured if it's good
enough for the Epicor sales junkies to do their dog and pony shows on... It
is not the fastest thing in the world as far as running V8 goes, but it has
the advantage of running local to avoid the network end of issues related to
speed, although it can be run as a server and will be used for early client
testing. It is portable so I can bring the test server into the conference
room or an office on a whim, and when I am through with it I still have a
nice laptop to work on. As I noted it a previous post, it also saved my
behind a couple weeks back when I was able to install 6.1 on it and run it
for a short time as our production 6.1 server while the real 6.1 server was
repaired. I did spec a laptop with Dual core as I said, and 2 GB ram as
well as SATA HD, and it came with a GB Nic. If you care to check out the
base unit I selected, it was a Compaq nc8430.
Anyway, it's doing the job of a test server for us as we prepare for the
real server in the Nov. timeframe.
Good luck,
Aaron Hoyt
Vantage Plastics
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com]On Behalf Of
Todd Caughey
Sent: Thursday, September 14, 2006 4:51 PM
To:
Subject: RE: Spam RE:[Vantage] Spec'ing out a new server
Almost a Catch-22 sort of deal...can't get production server until I prove
things out on a "cheap" server. When I go to the well for the production
server it the proposal wil be loaded with everything under the sun...new
tape drives, NAS, SAN, server like Erik proposed and maybe some upgraded net
switches. One chance is all I will get to get it all right, and then only
after test server has proven the benefits of upgrading. I expect to take
about a year for trials and conversions before buying the ultimate setup.
If you mean virtual on current server...not a chance. Only 550Mhz proc
with 1GB RAM and only a couple gig free disk (DB is 1.5GB) running Win2K
Server.
-Todd C.
Michael Barry
Sent: Thursday, September 14, 2006 3:28 PM
To:
Todd,
If you're really trying to appease the cost mavens and you are only going
to
have a small handful of users on the test system at any given time, you
could run your test system in a virtual on the production server and
simply
cut it over to native when you go into production.
Regards,
Michael
_____
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto:
vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf Of
Todd Caughey
Sent: Thursday, September 14, 2006 1:04 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: Spam RE:[Vantage] Spec'ing out a new server
A twist on this topic....
I got asked today to plan on setting up a test/conversion server for
evaluating. Plan is to use it to test drive V8 and start converting RB to
Cryatal XI or Dashboard Queries. Probably not ever have more than 3-4
users
trying things out. When we buy the "real" production server this server
would become something else...probably a web server.
What are some of you others using (or have used) for this purpose? I need
to
keep the cost relatively low so where can I get away with scrimping? Would
a
single CPU, moderate (2GB) memory on SATA disks type server be OK?
-Todd C.
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
