Scott,
Use the wizard to add an after adapter, it will add the case statement for
you (and likely have update already pre-coded). Add a line within the case
statement:
Otrans.update()
That should do it for you.
Kevin Simon
SimsTrak Consulting
scottinct78
Sent: Wednesday, November 17, 2010 11:30 AM
Subject: [Vantage] Re: Screen Refresh after BPM
I am running into this exact same problem. I have a POST SalesOrder.Update
BPM which does everything I need, but I have to hit refresh on the release
before I can do anything. If not I get "Record has been updated by another
user".
A code example of the form event would be very helpful.
statement:
Otrans.update()
Kevin Simon
SimsTrak Consulting
scottinct78
user".
