This question seems to come up all the time… so I will answer it before you ask. How do I run Kinetic from a web browser? (or “Can I run Kinetic without downloading a client?”)
Yes, you CAN run Kinetic without a downloading a client, as long as the application you want to run has been converted to Kinetic (there are still a few that are not converted yet).
To run from a browser, you simply need to go to your favorite web browser (I use some version of Chrome… google, or MS Edge) and enter the web address for your server…
WAIT… what is that address? Well… the answer may be showing on your current installation. It is either at the top or the bottom of your screen. If you are in the “classic” client, it should be at the bottom (make sure that you have it turned on to display… see picture below). If you are in the Kinetic Home Page, then it will be at the top.
Thanks Tim. Appreciate this post and I do have both regular and MES types setup to test as URL’s.
We are not live yet, but the URL feels twice as fast in testing. I am not sure how useful it will really be though until all the base screens are converted to Kinetic.
It is my goal to have this as the main way we connect, hopefully before we go later this year.
Brad… the URL is faster than accessing from client, so your “feel” is correct. Once the system goes GA, most of the mainline processes should be in the new UI and accessible from a browser. Those remaining (at first) will be mostly in Technical areas which should be coming soon after that.
does using the link for MES chew up a full liscense? It seems to do that on my end which is totally useless. I have 12 data collection licenses, and it seems like those will be garbage if I am trying to use the the URL links for MES.
well, when you use MES, it SHOULD be consuming an MES License, unless one is not available. I believe if all the MES Licenses are consumed, then it will roll into non-mes licenses.
make sure that you completely log out of your non-mes license before testing MES, otherwise, it might be retaining your previous session.
Checking in session management, there is plenty of licenses left for data collection. But as soon as I login using the URL link for MES, it consumes a Default… Pretty soon my defaults are all used, and the thing won’t login at all, even though there are 11 data collection licenses available.
We’re getting ready to update to Kinetic from 10.2.600. While I was testing I tried to open Kinetic in a browser and kept getting the dreaded 403 Forbidden error. There were a couple of things I needed to tweak in setup but while it works with Edge it’s still a hard no with Chrome. Any suggestions on how to make Chrome cooperate are greatly appreciated! Edge is not my favorite …
While Kinetic on the browser is really amazing. I have even tried out creating some BAQs on a browser screen and was pleased with the intuitive approach of the new UI.
Sorry to report though that MES is not ready for prime time on the browser. Some functions do work, but logging in, starting and completing an operation have caused additional pops up.
I have had a ticket open since Dec. 2021 to see if we could get an issue address to use MES on android tablets, but the fix is not due out until 2022.2 (November?).
I should note - that this is for SaaS customers that I am working with. (several)
Glad to hear that you like the BAQ editor… We have done some internal reviews on the BAQ Screen, and I will note that not everything is as smooth as we hope to have when it is finally fully released. I too have created multiple simple BAQs using the new UI, and found that it takes slightly longer than what I am used to, but we hope to improve that.
In 2023.2 the Edge Agent will listen to specific events and the Kinetic UI will support Classic, basically it will tell the Agent the menu you clicked on is Classic and the Agent will find your Kinetic.exe and launch it with args to specifically log you in and launch the classic menu only, if I remember.
@timshuwy has more info on that. I am jumping the gun pre press release, heard it from a friend that knows a friend that knows a friend.
