Run Capture WIP - effect on Gross Margin Report
Thanks everyone for the continued conversations on this thread. It's been very helpful.
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
Sent: Tuesday, April 10, 2012 10:19 AM
Subject: RE: [Vantage] Re: Run Capture WIP - effect on Gross Margin Report
I agree, if that's the normal behavior for a given part, then do just that..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of b_ordway
Sent: Tuesday, April 10, 2012 10:06 AM
Subject: [Vantage] Re: Run Capture WIP - effect on Gross Margin Report
>> non-stock, and average costed and...
>> never having received
>> into inventory
>> no costs will have been calculated.
>> This can bite you if you occasionally
This was biting a lot at one plant.
So much that we ended up changing most of the component parts to stock.
It fixed a lot of cost issues.
In some orders, stock parts also helped reduce the overall number of POs & jobs required. But it loses the links between source and demand.
Kind of a pain to track things down sometimes now.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Rob Bucek <rbucek@...<mailto:rbucek@...>> wrote:
> IMHO, if you are a plant that normally ships from the job and those parts sold are set as non-stock it is somewhat counter intuitive to the design intent with regards to cost flow to have those parts set as standard cost if it is your desire to manage margins from actual costs to sale price. I'm not saying there is only one way to manage margins from this approach, only that for us it has been a much more sane process when we didn't have to fight design intent. If you have your parts set as non-stock, ship from the job; best practice in my opinion should be to complete and close those jobs after shipment (you should still do a daily complete and close process to keep up with this) you'll find you have far less cost hitting your variance accounts, your margins as shipped will be far more accurate, and analyzing REC (realization of estimated cost - what did you leave on the table; the difference between price and cost, low REC being more desirable obviously) becomes an easy task of hitting job costs and tying them to the sales orders they were linked to. In this environment if you were to look at your part costs from an inventory standpoint they would normally be zero, because being non-stock, and average costed and under normal circumstances never having received them into inventory no costs will have been calculated. This can bite you if you occasionally for some reason accept those parts into stock and subsequently ship them, so you have to have some process in place to monitor that as well.. The only thing that prevents costs from being applied to the job after shipment is closing the job. If someone were to apply labor or issue material that may have been missed before shipment, after the part ships, those costs can be seen on the invoice detail table under the JCLbrUnitCost, JCBurUnitCost, etc.. These fields simply house all job costs at the time of job close, which may differ from costs rolled up at time of shipment which is housed in the LbrUnitCost, BurUnitCost etc.. So Vantage does do a good job in my opinion of catching up so to speak, and it does mitigate timing issues somewhat by directing those 'late coming costs' to the correct COS accounts.
> Rob Bucek
> FAX: (715)284-4084
> [Description: cid:1.234354861@...]<http://www.dsmfg.com/>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Manasa Reddy
> Sent: Tuesday, April 10, 2012 7:15 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Gary,
> If you ship from a job and close it before you invoice, the system won't let you invoice.
> I agree with everything else you said. You can complete a job and then if you add costs to the job than those costs hit a variance account because the job is complete. This is for average costing which I found out is not Ken's issue since they are Standard cost.
> HTH,
> M. Manasa Reddy
> manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com<mailto:manasa@...%3cmailto:manasa%40weldcoa.com%3e%3cmailto:manasa@...%3cmailto:manasa%40weldcoa.com>>>
> 630.806.2000 x1515
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Gary Parfrey
> Sent: Monday, April 09, 2012 5:15 PM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Manasa
> Just to ensure correct information being posted to the user group. At what point can you not close a job before invoicing?
> Although the invoice line stores cost information, it is the shipment and its resulting transaction that stores cost information
> The Invoice only deals with cost if you have an AR clearing account, but his has nothing to do with the job.
> Unless you have a configuration or process that differs, there is nothing to my knowledge in Epicor that stops you from closing a job post shipment and then invoicing it afterwards. The invoicing revenue will either catch up with the shipment transaction that has posted to COS, or will pull the cost from the AR clearing account to COS at point of invoice posting.
> Gary
> Gary Parfrey | Managing Director
> Mobile: +44 7765 234 934
> DDI: +44 121 314 1172
> Main: +44 121 314 1170
> Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
> This e-mail and any files transmitted with it are confidential and are intended solely for the use of the intended recipient(s). If you are not the intended recipient, you must not copy, distribute or take any action based on this communication. If you have received this communication in error please contact GaryP@...<mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk><mailto:GaryP@...<mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk<mailto:GaryP@...%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP@...%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk>>> and delete this communication and any copies of it. Any views or opinions presented are soley of those of the author and do not necessarily represent those of Dot Net IT Limited.
> Dot Net IT Limited, Reg No 4412519
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Manasa Reddy
> Sent: 09 April 2012 13:13
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> If you ship off the job, then the job CANNOT be closed before you invoice.
> M. Manasa Reddy
> manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com<mailto:manasa@...%3cmailto:manasa%40weldcoa.com%3e%3cmailto:manasa%40weldcoa.com%3e%3cmailto:manasa%40weldcoa.com%3e%3cmailto:manasa@...%3cmailto:manasa%40weldcoa.com%3e%3cmailto:manasa%40weldcoa.com%3e%3cmailto:manasa%40weldcoa.com>>>
> 630.806.2000 x1515
> Ex scientia, vera
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Gary Parfrey
> Sent: Saturday, April 07, 2012 12:37 PM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Ken
> Make sure your non stock manufactured items are quantity bearing on your part master.
> Make sure you check the COS/Mfg variance checkbox when running capture COS WIP
> Make sure you jobs are not closed before you have shipped the goods as you said, but jobs can be but do not have to be closed before invoicing
> Gary
> This e-mail and any files transmitted with it are confidential and are intended solely for the use of the intended recipient(s). If you are not the intended recipient, you must not copy, distribute or take any action based on this communication. If you have received this communication in error please contact GaryP@...<mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk><mailto:GaryP@...<mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk><mailto:GaryP%40dotnetit.co.uk<mailto:GaryP@...%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP@...%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk%3e%3cmailto:GaryP%40dotnetit.co.uk>>> and delete this communication and any copies of it. Any views or opinions presented are soley of those of the author and do not necessarily represent those of Dot Net IT Limited.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Ken Williams
> Sent: 06 April 2012 00:37
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Rob & Virginia - what if you find that no costs are getting captured at the invoice level (and thus the sales GM report shows zero costs)? There's definitely costs to our jobs....but 99% of them are not showing on invoicing, even after capturing WIP.
> For years I've been pulling transactional data to make my own reports, but I'd love to just get the system working. Any thoughts on what could cause this activity?
> We typically close our jobs out after shipment, is there a requirement that jobs be closed BEFORE invoicing? Please tell me no....
> Ken
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Virginia Joseph
> Sent: Saturday, March 24, 2012 7:38 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Sorry Rob, that was a typo. I meant invoice tables, not inventory tables. I completely agree with your statements about inventory costing.
> I have to say I did some more testing and you were right. The Inventory/WIP Reconciliation report seems to be more than just a report. I ran the sales gross margin report for Friday shipments and all the costs were blank (everything that shipped on Friday was make direct - no part number set-up in Vantage). Then I ran the Inventory/WIP Reconciliation report and then re-ran the sales gross margin report and now the job costs appear in the report. Thanks Rob! I now have a gross margin report we can use daily as long as we run Inventory/WIP recociliation on a daily basis!
> Ken: Your interest in the effects of capturing without posting to GL is something that I cannot speak to because I have never run the COS capture process without posting to the GL. The only reason I run the COS capture process is specifically to post the transactions to my GL. If there is anyone that rus the COS capture on a regular basis without posting to the GL, I would like to hear what this accomplishes and how either report or data accuracy benefits.
> Virginia Joseph
> Deep Hole Specialists, LLC
> CFO
> 440-708-5239
> 440-991-6714 cell
> vjoseph@...<mailto:vjoseph%40deephole.com><mailto:vjoseph%40deephole.com><mailto:vjoseph%40deephole.com><mailto:vjoseph%40deephole.com><mailto:vjoseph%40deephole.com><mailto:vjoseph%40deephole.com<mailto:vjoseph@...%3cmailto:vjoseph%40deephole.com%3e%3cmailto:vjoseph%40deephole.com%3e%3cmailto:vjoseph%40deephole.com%3e%3cmailto:vjoseph%40deephole.com%3e%3cmailto:vjoseph%40deephole.com%3e%3cmailto:vjoseph%40deephole.com>>
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Rob Bucek <rbucek@<mailto:rbucek@<mailto:rbucek@%3cmailto:rbucek@<mailto:rbucek@%3cmailto:rbucek@%3cmailto:rbucek@%3cmailto:rbucek@>>>> wrote:
> > Im curious about what you mean regarding items shipped from inventory.. you mentioned that the inventory tables don't have job cost information. This isn't my area of expertise, but I like this area so im interested. What tables specifically are you speaking of? For our shop, being average costing for inventory value, average cost of inventory is recalculated every time you receive inventory from a job (I believe, correct me if im wrong on that one, id hate to have that presumption wrong). Are you standard cost for inventory? Fundamentally theres a complete disconnect when shipping from inventory with respects to job costing. If you ship from inventory the cost is your average or standard cost based on the accumulated costs from the job at the time of receipt. Here we control that by placing strict rules on how a job gets receipted to inventory. As I was writing this I had an epiphany...
> > I went to my test environment, picked a job that had all its operations completed, materials issued and had not been shipped. This was a make direct job to a sales order. I shipped said job complete, opened the part in transaction history tracker and noted that for that transaction the columns Amount, Mtl Unit Cost, Lbr Unit Cost, Bur Unit Cost were all zero... doing nothing else, I ran WIP rec against that job, I then simply refreshed the transaction history tracker, and those columns were then populated with costs... so..that was were my perception of something is going on when you run that report..or some damn programmer is able to find a random temp table and is at the very least populating part tran records from this..remember..its our test environment.. hard to think it could be something else.. what are your thoughts...I can send you screen shots offline if you are interested.
> > Rob Bucek
> > FAX: (715)284-4084
> > [Description: cid:1.234354861@]<http://www.dsmfg.com/>
> Total Control Panel
> Login<https://asp.reflexion.net/login?domain=weldcoa.com>
> To: manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
> From: sentto-20369-109155-1333820195-manasa=weldcoa.com@...<mailto:sentto-20369-109155-1333820195-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><mailto:sentto-20369-109155-1333820195-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><mailto:sentto-20369-109155-1333820195-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><https://asp.reflexion.net/address-properties?aID=619865755&domain=weldcoa.com>
> Message Score: 60
> High (60): Fail
> My Spam Blocking Level: Low
> Medium (75): Pass
> Low (90): Pass
> Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=619865755&domain=weldcoa.com> this sender
> Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=619865755&domain=weldcoa.com> returns.groups.yahoo.com
> This message was delivered because the content filter score did not exceed your filter level.
> Total Control Panel
> To: manasa@...<mailto:manasa%40weldcoa.com><https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
> From: sentto-20369-109207-1334009708-manasa=weldcoa.com@...<mailto:sentto-20369-109207-1334009708-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><https://asp.reflexion.net/address-properties?aID=621633629&domain=weldcoa.com>
> Message Score: 30
> High (60): Pass
> Medium (75): Pass
> Low (90): Pass
> Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=621633629&domain=weldcoa.com> this sender
> Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=621633629&domain=weldcoa.com> returns.groups.yahoo.com
 Currently we run the capture WIP process at the end of the month only, we are considering running this process on a weekly basis, are there any consequences we should be aware of by changing the frequency of running the capture?
Thank you
Sandy Kleinschmidt
UMC, Inc.
sandrak@...
Because youre posting to the g/l count out adjusting any labor transactions against jobs that get hit with this.. though I cant say for sure because I haven't verified, you may also want to be sure if that applies to materials issued to a job as well, can you adjust or reverse those after they are posted.. Labor for certain is stuck as is. What are you trying to accomplish by doing this?
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Friday, March 23, 2012 1:16 PM
Subject: [Vantage] Run Capture WIP weekly vs once per month (any consequences) Epicor 9.05.607A
Thank you
Sandy Kleinschmidt
UMC, Inc.
sandrak@...<mailto:sandrak%40ultramc.com>
Our experience is labor is stuck (though adjusting via Job Adjustments is an option if it's a costing issue, as opposed to a payroll issue). Material is not stuck, it can still be returned post Capture.
We ran weekly for a while a couple years ago, but found trying to keep up on accurate labor made it unrealistic to rely on a weekly capture. We now do it as part of month end after a full audit by HR on labor.
Ken
Sent: Friday, March 23, 2012 12:32 PM
Subject: RE: [Vantage] Run Capture WIP weekly vs once per month (any consequences) Epicor 9.05.607A
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of melissa hietala
Thank you
Sandy Kleinschmidt
UMC, Inc.
sandrak@...<mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com>
Ill amend that by saying I was assuming you have the post to general ledger check box, checked.. if you weren't posting, then what I said shouldn't be true.. but..verify.
Rob Bucek
FAX: (715)284-4084
Sent: Friday, March 23, 2012 1:32 PM
Rob Bucek
FAX: (715)284-4084
Thank you
Sandy Kleinschmidt
UMC, Inc.
Were you posting when you ran capture ken?
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ken Williams
Sent: Friday, March 23, 2012 1:35 PM
Ken
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com><mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of melissa hietala
Thank you
Sandy Kleinschmidt
UMC, Inc.
sandrak@...<mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com>
Yes, nice amendment.
Received: Friday, 23 Mar 2012, 12:37pm
To: vantage@yahoogroups.com [vantage@yahoogroups.com]
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ken Williams
Ken
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com><mailto:1.234354861%40web65412.mail.ac4.yahoo.com><mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of melissa hietala
Thank you
Sandy Kleinschmidt
UMC, Inc.
sandrak@...<mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com>
We run the capture at end of month, but Inv/WIP reconciliation gets run daily just before we invoice... that keeps margins and WIP values fairly current..
Rob Bucek
FAX: (715)284-4084
Sent: Friday, March 23, 2012 1:39 PM
Rob Bucek
FAX: (715)284-4084
Ken
Rob Bucek
FAX: (715)284-4084
Thank you
Sandy Kleinschmidt
UMC, Inc.
Where is the 'Inv/WIP reconciliation' process?
> current..
> Rob Bucek
> FAX: (715)284-4084
> Of Ken Williams
> From: Rob Bucek [rbucek@...]
> Rob Bucek
> FAX: (715)284-4084
> Ken Williams
> Ken
> Of Rob Bucek
> Rob Bucek
> FAX: (715)284-4084
> Of melissa hietala
> capture?
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
C. J. (Carole Jo) Harner
Cost/Inventory Control Analyst
780 Keezletown Road
Weyers Cave, VA 24486
Work: 540-437-2126
Cell: 540-435-2040
Fax: 540-234-9768
ITAR NOTICE
This email and/or attachments may contain technical data as defined in the
U.S. international traffic in arms regulations (ITAR) section 22 C.F.R. �
120.10. The technical data may not be exported, disclosed or transferred to
any foreign person (including employees, consultants, or agents,
corporation or business association), as defined in the ITAR section 22
C.F.R. �120.16 whether in the United States or abroad, without the prior
written approval of the U.S. Department of State
Production management/job management/reports
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Harner, CJ
Sent: Friday, March 23, 2012 1:47 PM
Subject: Re: [Vantage] Run Capture WIP weekly vs once per month (any consequences) Epicor 9.05.607A
> fairly current..
> Rob Bucek
> FAX: (715)284-4084
> Rob Bucek
> FAX: (715)284-4084
> Of Ken Williams
> Ken
> Behalf Of Rob Bucek
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
780 Keezletown Road
Work: 540-437-2126
Cell: 540-435-2040
Fax: 540-234-9768
ITAR NOTICE
This email and/or attachments may contain technical data as defined in the U.S. international traffic in arms regulations (ITAR) section 22 C.F.R. § 120.10. The technical data may not be exported, disclosed or transferred to any foreign person (including employees, consultants, or agents, corporation or business association), as defined in the ITAR section 22 C.F.R. §120.16 whether in the United States or abroad, without the prior written approval of the U.S. Department of State
We are aware that by running the capture the labor will show as posted and labor changes in the time and expense entry will not be permitted, that is exactly what we want to accomplish. We want to be able to post our payroll and not allow any changes in the time and expense entry after we have posted payroll. We felt that if a change was needed, we could do it through job adjustments and it would leave a better trail to follow. Are there any other issues we should be aware of that you can think of?
Â
Thank you
Sandy Kleinschmidt
UMC, Inc.
sandrak@...
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Friday, March 23, 2012 1:37 PM
Â
Rob Bucek
FAX: (715)284-4084
Ken
Rob Bucek
FAX: (715)284-4084
Thank you
Sandy Kleinschmidt
UMC, Inc.
Oh, ok, it sounded like you performed some kind of process. Sorry.
> Rob Bucek
> FAX: (715)284-4084
> Of Harner, CJ
> > fairly current..
> > Rob Bucek
> > FAX: (715)284-4084
> > Rob Bucek
> > FAX: (715)284-4084
> > Of Ken Williams
> > Ken
> > Behalf Of Rob Bucek
> > Rob Bucek
> > FAX: (715)284-4084
> > Thank you
> > Sandy Kleinschmidt
> > UMC, Inc.
> 780 Keezletown Road
> Work: 540-437-2126
> Cell: 540-435-2040
> Fax: 540-234-9768
> ITAR NOTICE
780 Keezletown Road
Work: 540-437-2126
Cell: 540-435-2040
Fax: 540-234-9768
ITAR NOTICE
That's one thing I always thought was a little odd..putting capture cos/wip in the general ops folder of production management... not because of logical categorical reasons...which there are, but because of general security reasons..just one more discrete security change you have to chase down...put it in the gen ledger area where it belongs..
Rob Bucek
FAX: (715)284-4084
> fairly current..
> Rob Bucek
> FAX: (715)284-4084
> Rob Bucek
> FAX: (715)284-4084
> Of Ken Williams
> Ken
> Behalf Of Rob Bucek
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
780 Keezletown Road
Work: 540-437-2126
Cell: 540-435-2040
Fax: 540-234-9768
ITAR NOTICE
It is a process
Rob Bucek
FAX: (715)284-4084
Sent: Friday, March 23, 2012 1:53 PM
> Rob Bucek
> FAX: (715)284-4084
> > Rob Bucek
> > FAX: (715)284-4084
> > Rob Bucek
> > FAX: (715)284-4084
> > Of Ken Williams
> > Ken
> > Behalf Of Rob Bucek
> > Rob Bucek
> > FAX: (715)284-4084
> > Thank you
> > Sandy Kleinschmidt
> > UMC, Inc.
> 780 Keezletown Road
> Work: 540-437-2126
> Cell: 540-435-2040
> Fax: 540-234-9768
> ITAR NOTICE
780 Keezletown Road
Work: 540-437-2126
Cell: 540-435-2040
Fax: 540-234-9768
ITAR NOTICE
I have to disagree Rob or ask you to elaborate. I have found no evidence that Inventory/WIP Reconciliation is anything but a crystal report. (Remember in 6.1 it was a progress report.)You state that running it "keeps margins and WIP values fairly current.." What evidence have you seen that running the Inventory/WIP Reconciliation Report effects the accuracy of your data?
Virginia Joseph
CFO
440-708-5239
440-991-6714 cell
vjoseph@...
--- In vantage@yahoogroups.com, Rob Bucek <rbucek@...> wrote:
> It is a process
> Rob Bucek
> FAX: (715)284-4084
So what do people use as a good way to review Gross Margin on a daily or weekly basis? The Sales Gross Margin report (Accounts Receivable / Reports / Sales Gross Margin) for a make direct environment does not write the costs in the inventory table until you run the Capture COS/WIP process which means that the report is useless as a real time reporting tool and can only be used after I have captured costs for the prior month. However, sales & production need to be reviewing profitability on a daily and at a minimum a weekly basis. However, the report is great if you are a manufacturer that ships from inventory since the costs are recoreded in the inventory table when the invoice is created based on the part costs at the time of shipment.
Suggestions? We are a mixed mode plant and need a single report that shows profitability for make direct and inventory shipments. (Rob you shared you custom Gross Margin report with me but it suffers the same problem in that the inventory tables don't have the job cost information until COS capture has been ran at month end.)
Virginia Joseph
440-708-5239
440-991-6714 cell
vjoseph@...
> Ken
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
I ended up writing my own Excel file (via ODBC) to do this based on JobAsmbl.Ttl* table/fields, it wasn't pretty but it works well. I imagine the same could be done for Crystal, my Excel file has a lot more in it than would be necessary for a simple daily/weekly GM report.
I am curious on the discussion of the effects of capturing without posting to GL on the invoice table. We'll test ourselves, but Rob & yourself seem to have very different experiences here.
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Virginia Joseph
Sent: Friday, March 23, 2012 2:35 PM
Virginia Joseph
440-708-5239
440-991-6714 cell
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@...<mailto:kwilliams@...>> wrote:
> Ken
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
> sandrak@...<mailto:sandrak%40ultramc.com><mailto:sandrak%40ultramc.com<mailto:sandrak@...%3cmailto:sandrak%40ultramc.com%3e%3cmailto:sandrak%40ultramc.com>>
My observations on that extended to a job costing project that extended back to early 2009 (when I knew more than I do now about vantage) when we were chasing down gross margins on jobs shipped daily. Our goal for the project was to ensure margins were 95% accurate at the time of shipment. We thought at the time through the various scenarios that we ran and procedures we established that WIP/Rec had an impact on that. We did achieve our goal, but perhaps it was all the procedures and processes we put in place and had nothing to do with running Inv/WIP rec..
Now two years later could I recall conversations and remember those details..likely not. I wouldn't be shocked to find out I'm wrong on that, maybe someone in our accounting dept would love to know because its still a part of their daily procedure lol! So you won't find me interested in engaging you on this topic... you win. I'd have to step myself back through the whole thing, something in my memory tells me we kept seeing variances in the margin reports from when we did run before invoicing, and when we didn't.. maybe something else was going on and we were in error on cause and effect...
If you have some more recent data from your investigations I'll be happy to shamelessly plagiarize your efforts and apply that knowledge here to save ourselves the wasted time of running that report daily.. :)
Rob Bucek
FAX: (715)284-4084
Sent: Friday, March 23, 2012 3:41 PM
Ken
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Virginia Joseph
Virginia Joseph
440-708-5239
440-991-6714 cell
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@...<mailto:kwilliams@...>> wrote:
> Ken
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
And now that you have me thinking about that.. just to clarify, our goal was specifically relevant to getting the margins 'as shipped' as close as possible to margins 'as adjusted'
Rob Bucek
FAX: (715)284-4084
Sent: Friday, March 23, 2012 3:35 PM
Virginia Joseph
440-708-5239
440-991-6714 cell
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@...> wrote:
> Ken
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
Rob Bucek
FAX: (715)284-4084
Virginia Joseph
440-708-5239
440-991-6714 cell
> Ken
> Rob Bucek
> FAX: (715)284-4084
> Thank you
> Sandy Kleinschmidt
> UMC, Inc.
