Request for simple speed test/Change Log Housekeeping
Did u notice any difference running this?
--- In vantage@yahoogroups.com, "halm180" <Mis@...> wrote:
> Thank you sir!
> --- In vantage@yahoogroups.com, "Chris Robisch" <bluewine@> wrote:
> > Use the Database Purge and Summarize under System Management\Utilities. You can purge the Job Details, Indirect Labor, Journal Details and the Change Log.
> > ----- Original Message -----
> > From: "halm180" <Mis@>
> > To: <vantage@yahoogroups.com>
> > Sent: Friday, March 18, 2011 10:28 AM
> > Subject: [Vantage] Re: Request for simple speed test/Change Log Housekeeping
> > > --- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@> wrote:
> > >> One thing I have found useful is to use the D&L process as an opportunity to
> > >> flush tables like the Chglog table, which can speed things up considerably
> > >> since the DB as a whole is smaller up to 75% in some cases, but you do lose
> > >> your Change log Data up to that point.
> > > Ned:
> > > What steps are you following to flush the ChgLog table? Are you deleting records between the Dump and Load stages? I have considered doing this but need to build up the confidence. Any precautions or suggestions? Thank you for any and all suggestions.
> > > Peter Dunbar
> > > Halm Industries Co., Inc.
Good Day:
We continue to chase slowness in E9.
Sun went live on 11/29/10
on Epicor 9, 9.05.601B SQL-Unidata
Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
One specific item is: In Quote entry, Line-Entry, After you type in
the Part# and hit [Enter], it takes 15 seconds for the screen to cycle.
In Order-Entry it is only 2-4 seconds
1. Do have a similar delay on your system?
2. Version?
3. Progress, SQL, or SQL-Unidata
4. number of Part#s - we have 280,000
len.hartka@...
<blocked::mailto:len.hartka@...>
Sun Automation Group
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
I just did this test on the training database(it would be better to do it on
this DB for benchmarking because most of us have that)
about 4 seconds
9.05.603
SQL 64 non unidata
hope this helps.
also, we did notice a speed improvement after going to 603
Nick
On Thu, 17 Mar 2011 13:08:08 -0400
"Len Hartka" <len.hartka@...> wrote:
Good Day:
(Informix)
After you type in
screen to cycle.
2. Version?
len.hartka@...
Celebrating
25 Years of Service
Is your Quote Entry customized? Have you done a dump and load of the
database?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Len Hartka
Sent: Thursday, March 17, 2011 1:08 PM
Subject: [Vantage] Request for simple speed test
Good Day:
2. Version?
len.hartka@... <mailto:len.hartka%40sunautomation.com>
<mailto:len.hartka%40sunautomation.com> >
Celebrating
25 Years of Service
Good Day Blake:
Thanks for the suggestion - no, we have not done that.
Have you? Did it speed things up?
You did not indicate how long it takes on your system.
len.hartka@...
Of Blake Clemens
Sent: Thursday, March 17, 2011 1:26 PM
Subject: RE: [Vantage] Request for simple speed test
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
We've had similar problems when we first started using Vantage but we
aren't on E9. We're on Vantage 8.03.408B. A dump and load helped
significantly. I do them regularly... usually once every 3-4 months.
Another thing to confirm is that if you have Quote customized, open it
with the base form and see how long it takes to pull in a part. If it's
a lot faster then something is wrong with your customization, if it
takes just as long then a dump and load would be best. Currently it
takes about 1-2 seconds to pull a part into Quote. Like I said we
struggled with this type of behavior until we got settled in the version
we currently have... which is also when we started to administer the
dump and loads.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Len Hartka
Sent: Thursday, March 17, 2011 2:08 PM
Good Day Blake:
Behalf
Of Blake Clemens
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
Len,
if you want, I can run your system log through and analyzer
send me a zip file of your log
also, send me the tracing file for the quote transaction
thanks
motty
--- In vantage@yahoogroups.com, "Len Hartka" <len.hartka@...> wrote:
> Good Day:
> 2. Version?
> len.hartka@...
> Celebrating
> 25 Years of Service
9.05.602
Progress x64
Number of parts: 10256
Transaction time: 2 seconds
"Zac" Jason Woodward
Network Administrator
Intermountain Electronics, Inc.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced industry experts.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Len Hartka
Sent: Thursday, March 17, 2011 11:08 AM
Good Day:
2. Version?
len.hartka@...<mailto:len.hartka%40sunautomation.com>
<blocked::mailto:len.hartka@...<mailto:len.hartka%40sunautomation.com>>
Celebrating
25 Years of Service
Good Day Blake:
I am not sure what you mean by "Dump and Load".
Could you explain a little.
Len
Of Blake Clemens
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
In simplest terms, dump the contents of every table into a text file. Then one at a time load the contents back in to a empty db. Each table's data would then be located together instead of being scattered all over the place....
> Good Day Blake:
> Len
> Of Blake Clemens
> database?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Behalf
> Of Len Hartka
> Good Day:
> 2. Version?
> Celebrating
> 25 Years of Service
Sure... "Dump & Load" is a procedure done to the Vantage database.
Through various steps you take the database and run it through some
processes that clean out all the "bad" data. You then restore the newly
"cleaned" up data. It typically makes your Vantage wait times a lot
shorter. For example, there is a certain canned Vantage financial
report that takes about 3 minutes to run after a dump and load. After
about three months after the dump and load that same report takes 40
minutes. That is how I know its time to run a dump and load again.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Len Hartka
Sent: Friday, March 18, 2011 9:32 AM
Good Day Blake:
Len
Behalf
Of Blake Clemens
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
Good Day Motty:
1. "Zip of log file". Which log? which server?
2. Below is the trace for Quote # 1759, Part# ( ---010544--). Cust#
Le0979
Started with clicking "add-new-line" ended with adding quantity,
then save.
len.hartka@...
begin
cket>
<businessObject>Epicor.Mfg.BO.Quote</businessObject>
<methodName>GetNewQuoteDtl</methodName>
<returnType>void</returnType>
<localTime>3/18/2011 10:11:55:1580532 AM</localTime>
<executionTime>671.5095</executionTime>
<parameters>
<parameter name='cc'
type='Epicor.Mfg.Core.CallContext.CallContextDataSet'
><CallContextDataSet
xmlns="http://www.epicor.com/Mfg/100/BO.CallContext/CallContextDataSet"
/></parameter>
<parameter name='ds' type='Epicor.Mfg.BO.QuoteDataSet' ><QuoteDataSet
xmlns="http://www.epicor.com/Mfg/100/BO.Quote/Quote" /></parameter>
<parameter name='quoteNum' type='System.Int32'
><![CDATA[1759]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.ReportMonitor</businessObject>
<methodName>GetRowsKeepIdleTime</methodName>
<returnType>Epicor.Mfg.BO.ReportMonitorDataSet</returnType>
<localTime>3/18/2011 10:12:11:6334607 AM</localTime>
<executionTime>62.466</executionTime>
<parameters>
><CallContextDataSet
<http://www.epicor.com/Mfg/100/BO.CallContext/CallContextDataSet> "
/></parameter>
<parameter name='whereClauseSysRptLst' type='System.String'
><![CDATA[AutoAction <> '' AND AutoAction <> 'SSRSPrint' AND AutoAction
<> 'SSRSPreview' AND WorkStationID ='66ITW01 0']]></parameter>
<parameter name='pageSize' type='System.Int32'
><![CDATA[0]]></parameter>
<parameter name='absolutePage' type='System.Int32'
<parameter name='morePages' type='System.Boolean'
><![CDATA[]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetPartXRefInfo</methodName>
<localTime>3/18/2011 10:12:14:6162122 AM</localTime>
<executionTime>109.3155</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='partNum' type='System.String'
><![CDATA[---010544--]]></parameter>
<parameter name='sysRowID' type='System.String'
<parameter name='rowType' type='System.String'
<parameter name='uomCode' type='System.String'
<parameter name='serialWarning' type='System.String'
<parameter name='questionString' type='System.String'
<parameter name='multipleMatch' type='System.Boolean'
</parameters>
</tracePacket>
<tracePacket>
<methodName>CheckPrePartInfo</methodName>
<localTime>3/18/2011 10:12:14:7255277 AM</localTime>
<executionTime>234.2475</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='quoteLine' type='System.Int32'
<parameter name='fieldName' type='System.String'
><![CDATA[PartNum]]></parameter>
<parameter name='vMessage' type='System.String'
<parameter name='vBMessage' type='System.String'
<parameter name='vPMessage' type='System.String'
<parameter name='vSubAvail' type='System.Boolean'
<parameter name='vMsgType' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.Part</businessObject>
<methodName>PartIsSalesKit</methodName>
<returnType>bool</returnType>
<localTime>3/18/2011 10:12:14:9597752 AM</localTime>
<executionTime>78.0825</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='partNumber' type='System.String'
<parameter name='isSalesKit' type='System.Boolean'
<parameter name='isPhantom' type='System.Boolean'
</parameters>
</tracePacket>
<tracePacket>
<methodName>ChangePartNum</methodName>
<localTime>3/18/2011 10:12:15:0378577 AM</localTime>
<executionTime>687.126</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<http://www.epicor.com/Mfg/100/BO.Quote/Quote> " /></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>Update</methodName>
<localTime>3/18/2011 10:12:15:7874497 AM</localTime>
<executionTime>1686.582</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.TaskSet</businessObject>
<methodName>GetCRMTaskSetList</methodName>
<returnType>Epicor.Mfg.BO.TaskSetListDataSet</returnType>
<localTime>3/18/2011 10:12:17:6458132 AM</localTime>
<executionTime>31.233</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='taskSetId' type='System.String'
><![CDATA[DEF]]></parameter>
<parameter name='activeTaskId' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.Task</businessObject>
<methodName>GetRows</methodName>
<returnType>Epicor.Mfg.BO.TaskDataSet</returnType>
<localTime>3/18/2011 10:12:17:6926627 AM</localTime>
<executionTime>203.0145</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='whereClauseTask' type='System.String' ><![CDATA[Key1 =
'1759' AND RelatedToFile = 'QuoteHed']]></parameter>
<parameter name='whereClauseTaskCnt' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetByID</methodName>
<returnType>Epicor.Mfg.BO.TaskSetDataSet</returnType>
<localTime>3/18/2011 10:12:17:8956772 AM</localTime>
<executionTime>93.699</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='taskSetID' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.QuoteAsm</businessObject>
<methodName>GetDatasetForTree</methodName>
<returnType>Epicor.Mfg.BO.QuoteAsmDataSet</returnType>
<localTime>3/18/2011 10:12:18:0049927 AM</localTime>
<executionTime>187.398</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='ipQuoteNum' type='System.Int32'
<parameter name='ipQuoteLine' type='System.Int32'
><![CDATA[1]]></parameter>
<parameter name='ipStartAssemblySeq' type='System.Int32'
<parameter name='ipCurrentAssemblySeq' type='System.Int32'
<parameter name='ipCompleteTree' type='System.Boolean'
><![CDATA[False]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<returnType>Epicor.Mfg.BO.QuoteDataSet</returnType>
<localTime>3/18/2011 10:12:18:2548567 AM</localTime>
<executionTime>8183.046</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetDtlUnitPriceInfo</methodName>
<localTime>3/18/2011 10:12:31:4820322 AM</localTime>
<executionTime>406.029</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='skipDiscLookup' type='System.Boolean'
<parameter name='preserveAmt' type='System.Boolean'
<parameter name='changedColumn' type='System.String'
><![CDATA[SellingExpectedQty]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:12:36:5417782 AM</localTime>
<executionTime>936.99</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:12:37:6349332 AM</localTime>
<executionTime>46.8495</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:12:37:6817827 AM</localTime>
<executionTime>218.631</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:12:37:9004137 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:12:38:0097292 AM</localTime>
<executionTime>140.5485</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:12:41:6796067 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:13:03:2772262 AM</localTime>
<executionTime>515.3445</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:13:11:6945197 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:13:41:7406657 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:14:11:7749422 AM</localTime>
<executionTime>46.8585</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.SalesTer</businessObject>
<methodName>GetListPlusRO</methodName>
<returnType>Epicor.Mfg.BO.SalesTerListDataSet</returnType>
<localTime>3/18/2011 10:14:29:8310842 AM</localTime>
<executionTime>78.0975</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='whereClause' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.EpiSearch</businessObject>
<methodName>DoNamedSearch</methodName>
<returnType>Epicor.Mfg.BO.NamedSearchDataSet</returnType>
<localTime>3/18/2011 10:14:29:9248012 AM</localTime>
<executionTime>31.239</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='nswNamedSearch' type='System.String'
><![CDATA[ProductID = 'EP' AND SearchForm = 'Opportunity / Quote Search'
AND CalledFrom = 'Epicor.Mfg.UI.QuoteEntry.dll' AND DcdUserID =
'Len']]></parameter>
<parameter name='nswControlSetting' type='System.String'
<parameter name='nswWhereClause' type='System.String'
<parameter name='ds' type='Epicor.Mfg.BO.DashBdDefListDataSet'
><DashBdDefListDataSet
xmlns="http://www.epicor.com/Mfg/100/BO.EpiSearch/DashBdDefList
<http://www.epicor.com/Mfg/100/BO.EpiSearch/DashBdDefList> "
/></parameter>
<parameter name='pcProdID' type='System.String'
<parameter name='pcLike' type='System.String' ><![CDATA[]]></parameter>
<parameter name='ds1' type='Epicor.Mfg.BO.DynamicQueryListDataSet'
><DynamicQueryListDataSet
xmlns="http://www.epicor.com/Mfg/100/BO.EpiSearch/DynamicQueryList
<http://www.epicor.com/Mfg/100/BO.EpiSearch/DynamicQueryList> "
/></parameter>
<parameter name='piPage' type='System.Int32' ><![CDATA[0]]></parameter>
<parameter name='piAbsolutePage' type='System.Int32'
<parameter name='pbMore' type='System.Boolean'
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.QuickSearch</businessObject>
<methodName>GetBaseDefault</methodName>
<localTime>3/18/2011 10:14:29:9716597 AM</localTime>
<executionTime>15.6195</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='pcLikeField' type='System.String'
><![CDATA[QuoteHed.QuoteNum]]></parameter>
<parameter name='pcCallFrom' type='System.String'
><![CDATA[Epicor.Mfg.UI.QuoteEntry]]></parameter>
<parameter name='pcBaseSearchID' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetLikeFieldSearches</methodName>
<returnType>Epicor.Mfg.BO.QuickSearchListDataSet</returnType>
<localTime>3/18/2011 10:14:31:5336097 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.DynamicQuery</businessObject>
<methodName>GetListFromLike</methodName>
<returnType>Epicor.Mfg.BO.DynamicQueryListDataSet</returnType>
<localTime>3/18/2011 10:14:33:7203397 AM</localTime>
<executionTime>62.478</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='pcLikeTable' type='System.String'
><![CDATA[QuoteHed]]></parameter>
><![CDATA[QuoteNum]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:14:41:8112407 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<returnType>Epicor.Mfg.BO.QuickSearchDataSet</returnType>
<localTime>3/18/2011 10:14:55:0253377 AM</localTime>
<executionTime>109.3365</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='glbCompany' type='System.String'
<parameter name='quickSearchID' type='System.String'
><![CDATA[QuoteCost]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.Lib.ClassAttribute</businessObject>
<methodName>GetAttributes</methodName>
<returnType>Epicor.Mfg.Lib.ClassAttributeDataSet</returnType>
<localTime>3/18/2011 10:14:55:1346742 AM</localTime>
<executionTime>156.195</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='classNames' type='System.String'
><![CDATA[QuickSearch]]></parameter>
<parameter name='nameSpace' type='System.String'
><![CDATA[Epicor.Mfg.BO]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:14:55:3377277 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
><![CDATA[ProductID = 'EP' AND SearchForm = 'Search Form' AND CalledFrom
= 'Epicor.Mfg.UI.QuoteEntry.dll' AND DcdUserID = 'Len']]></parameter>
/></parameter>
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:14:57:9461842 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:14:58:0399012 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
AND CalledFrom = 'Epicor.Mfg.UI.QuoteEntry.QuickSearch.QuoteCost.dll'
/></parameter>
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:14:58:0867597 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
><![CDATA[Epicor.Mfg.UI.QuoteEntry.QuickSearch.QuoteCost]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetList</methodName>
<returnType>Epicor.Mfg.BO.QuoteHedListDataSet</returnType>
<localTime>3/18/2011 10:15:03:6316822 AM</localTime>
<executionTime>218.673</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
<parameter name='whereClause' type='System.String' ><![CDATA[QuoteNum
>= '1747' BY QuoteNum DESC]]></parameter>
><![CDATA[100]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:15:11:8319197 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:15:20:6569372 AM</localTime>
<executionTime>687.258</executionTime>
<parameters>
><CallContextDataSet
/></parameter>
>= '1700' BY QuoteNum DESC]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>3/18/2011 10:15:41:8525987 AM</localTime>
<parameters>
><CallContextDataSet
/></parameter>
</parameters>
</tracePacket>
**** end
Of Mordechai
Sent: Thursday, March 17, 2011 2:43 PM
Len,
thanks
motty
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Len
> Good Day:
cycle.
> 2. Version?
> len.hartka@...
> Celebrating
> 25 Years of Service
Blake, a Dump and Load does nothing to clean out any "Bad" data in the
Database, it does not affect data at all. The only thing a dump and load
does is to re-arrange the location of the data and put the data from all
tables together, closer to one another in order to make the accessing of the
data from the same table faster since it is more organize.
The data itself is not affected by the dump and load. Bad data is still bad
data.
your Change log Data up to that point. Although many people have Change Logs
setup and not even realize how much more data that is putting into the DB,
especially if it's change log data that you don't actually need.
Blake Clemens
Sent: Friday, March 18, 2011 9:39 AM
Cc: len.hartka@...
shorter. For example, there is a certain canned Vantage financial report
that takes about 3 minutes to run after a dump and load. After about three
months after the dump and load that same report takes 40 minutes. That is
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Len Hartka
Good Day Blake:
Len
Behalf Of Blake Clemens
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
One specific item is: In Quote entry, Line-Entry, After you type in the
2. Version?
Celebrating
25 Years of Service
viruses.
viruses.
You are on SQL - Have you setup and populated the Full Text Catalogs for the
Database correctly?
You will see a jump in performance if you are able to get those setup. Same
goes for a whole bunch of other screens as well.
Len Hartka
Good Day:
2. Version?
len.hartka@...
Celebrating
25 Years of Service
viruses.
God Day Ned and Blake:
Speed is the question.
We have a large db -- 18 gig.
We have 298,000 Part#'s
How long does D&L take?
How long did your data download take - ours took 50 hours with
continuously running 8 processors.
len.hartka@...
Of Ned
Sent: Friday, March 18, 2011 11:32 AM
the
bad
data.
opportunity to
considerably
lose
Logs
DB,
Behalf Of
Blake Clemens
Cc: len.hartka@... <mailto:len.hartka%40sunautomation.com>
three
is
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Len Hartka
Good Day Blake:
Len
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
confidential
sender
message
viruses.
confidential
sender
message
viruses.
have
and
email the files to mseal@... - I can't copy this with the extra lines
and yes, the server logs
thanks
motty
> Good Day Motty:
> Le0979
> then save.
> len.hartka@...
> begin
> cket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> /></parameter>
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> /></parameter>
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> /></parameter>
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><CallContextDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> **** end
> Of Mordechai
> Len,
> thanks
> motty
> Hartka" <len.hartka@> wrote:
> > Good Day:
> cycle.
> > 2. Version?
> > len.hartka@
> > <blocked::mailto:len.hartka@>
> > Celebrating
> > 25 Years of Service
Our DB is 22GB
At first the Dump and Load process took me an entire weekend. I spent
the night here at work. But after the 3rd or 4th time I was able to get
that time down to about 12-16 hours. I now can perform it remotely. If
you worked on it straight through from start to finish I wouldn't be
surprised if it only took you 8-9 hours. What data download are you
speaking of?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Len Hartka
Sent: Friday, March 18, 2011 12:34 PM
Behalf
Of Ned
the
bad
data.
opportunity to
considerably
lose
Logs
DB,
Behalf Of
Blake Clemens
three
is
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Len Hartka
Good Day Blake:
Len
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
confidential
sender
message
viruses.
confidential
sender
message
viruses.
have
and
Good Day Blake:
So you do it one file at a time? So you could do it over several
nights?
Our download was : The migration download, by Epicor, using the DMT
tool, and having broken up the files into 20,000 record files.sp 8
processors could be working on one file during the Migration. We
actually did a Passive-Active migration - "Fixed" data one weekend -
Active data 2 weeks later.
len.hartka@...
Of Blake Clemens
Sent: Friday, March 18, 2011 1:08 PM
Our DB is 22GB
speaking of?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Behalf
Of Ned
the
bad
data.
opportunity to
considerably
lose
Logs
DB,
Behalf Of
Blake Clemens
three
is
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Len Hartka
Good Day Blake:
Len
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
confidential
sender
message
viruses.
confidential
sender
message
viruses.
have
and
Ned:
Peter Dunbar
Ah, the migrations download.
Nope, do the whole thing at once. Follow the process from start to
finish.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Len Hartka
Sent: Friday, March 18, 2011 1:22 PM
Good Day Blake:
nights?
Behalf
Of Blake Clemens
Our DB is 22GB
speaking of?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Behalf
Of Ned
the
bad
data.
opportunity to
considerably
lose
Logs
DB,
Behalf Of
Blake Clemens
three
is
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Len Hartka
Good Day Blake:
Len
database?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Good Day:
2. Version?
Celebrating
25 Years of Service
confidential
sender
message
viruses.
confidential
sender
message
viruses.
have
and
