While developing a dashboard, I sorted one of the columns by clicking its header, and now the dashboard defaults to using that as a sort, overriding the sort order in the BAQ.
How can I remove that sort at the dashboard level, so the BAQ one is used by default?
FWIW - The BAQ has several levels of the sort, so just clicking the column I want as the default to sort by, doesn’t cut it.
I’ve also gone into developer mode and tried all the various “Reset Layouts…” under Tools->Layouts, but with no change.
Open the dashboard, arrange columns and sort as desired. Then go to Tools > Layouts > Save Layouts As Default. Redeploy the dashboard and all should be good!
When I open the dashboard in Developer mode, it still shows that column as sorted. So doing the “Save Layouts As Default” appears to save that sort as well.
During the Deploy process, when I test the dashboard, it gives me the option to clear the grid sort. Which I do. But the eventual deployed dashboard still has the sort.
I edited the BAQ (just added an extra column) to make sure it really changed, and it still launches with the grid sorted.
Launched by opening “Dashboard” and then loading the specific dashboard.
I can clear the sort on my personalized view of the deployed dashboard, but if I launch the “base only”, it shows the grid sort. I don’t want every user to have to do the Clear Grid sort thing. I should be able to have that cleared in the base configuration.
I had this exact issue on v10.1.400.14 (not sure which version you are on currently) and submitted a case to Epicor Support on 2017-08-14. After about 2 weeks of analysis, Epicor came to the conclusion that this was a development issue, as depicted here in the copied case notes from the support rep:
I tested the current baseline Epicor 10.1.400.33 and 10.1.600.9 software systems and duplicated the problem. Since this is no longer a Support Issue, but now a Development Problem, I created a New, Development Problem Case.
The Problem Case Number is PRB0187996 and has the following Description:
PROBLEM DESCRIPTION: When a Dashboard is created with a Tracker View, selecting a Column in the Tracker View will cause that Column to be sorted. If this was done be accident, there is no way to un-do the Sort, as Grid Option “Clear Grid Sort” is not available.
PROGRAM ID: Dashboard
EXPECTED BEHAVIOR: Clear Grid Sort should be an available Grid Option, just like it is in Base Grids.
Apparently, this issue exists up to, at least, v10.1.600.9.
I did not follow up on PRB0187996, so I do not know what the current disposition might be at this time.
