I did not do a save layouts.
Opened Dashboard in developer mode
Group by offending column
Remove Group
Refresh
Save dashboard
So far seems to be working as intended everywhere deployed.
Remove Group
Refresh
Save dashboard
I need to have multiple sort criteria. So this wonât work for me. @Chris_Conn, can I sort the dashboard by multiple fields using your customization?
Yes, you can add multiple sorts to an UltraGrid.
https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/93046/multi-sorted-columns-programmatically-ultragrid
Will it keep the sorting even if they hit refresh?
@Chris_Conn , but how do I reference the grid and event that you posted within epicor? I canât seem to find the event that I should run that code you posted.
The link you posted shows the code below. When I try to add a system event handler for the intializelayout event for Infragistics.Win.UltraWinGrid.UltraGrid it says âError: CS0123 - line 45 (136) - No overload for âplannedworkgrid_InitializeLayoutâ matches delegate âSystem.EventHandlerâ.â
This is what I have so far
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
using Infragistics.Shared;
using Infragistics.Win;
public class Script
// ** Wizard Insert Location - Do Not Remove âBegin/End Wizard Added Module Level Variablesâ Comments! **
Infragistics.Win.UltraWinGrid.UltraGrid plannedworkgrid;
// Add Event Handler Code
plannedworkgrid = (Infragistics.Win.UltraWinGrid.UltraGrid)csm.GetNativeControlReference("18279620-4c0e-401e-89c1-5a0a8081f639");
this.plannedworkgrid.InitializeLayout += new System.EventHandler(this.plannedworkgrid_InitializeLayout);
this.plannedworkgrid.InitializeLayout -= new System.EventHandler(this.plannedworkgrid_InitializeLayout);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void plannedworkgrid_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
// InitializeLayout gets fired for the UltraGrid's layout as well as when printing.
e.Layout.Appearance.BackColor = Color.Red;
It doesnt expect a generic System.EventHandler, it expects the handler specific to that event:
InitializeLayoutEventHandler
So would I just write this?
this.plannedworkgrid.InitializeLayout += new EventHandler(this.plannedworkgrid_InitializeLayout);
this.plannedworkgrid.InitializeLayout -= new EventHandler(this.plannedworkgrid_InitializeLayout);
When I do I get this message. What Am I doing wrong?
Error: CS0123 - line 53 (144) - No overload for âplannedworkgrid_InitializeLayoutâ matches delegate âSystem.EventHandlerâ
this.plannedworkgrid.InitializeLayout += new InitializeLayoutEventHandler(this.plannedworkgrid_InitializeLayout);
@Chris_Conn that compiles nicely. Thank you for your time and effort!
For some reason it still does not sort⌠Am I doing anything wrong in my code? Any explanation would be awesome.
public class Script
UltraGridLayout layout = e.Layout;
UltraGridBand band = layout.Bands[0];
UltraGridOverride ov = layout.Override;
band.SortedColumns.Add("JobAsmbl_PartNum", false);
@hkeric.wci , I have seen some of your grid filtering, do you have any examples of how to do grid sorting?
Is there a reason not to just do it in the BAQ before it gets to your dashboard?
This post was originally created to call out an issue with dashboards where it ignores the BAQ sorting. That is what is happening and so I am trying to fix it via code.
The issue was resolved by getting rid of the sort that was applied to the dashboard then saved. That was Chrisâs original fix on post 14. The code you posted didnât use that code. You are attempting to re-create the sorting in the BAQ.
Itâs probably going to be an easier fix to add the row numbers in the BAQ and then have that column available to sort by.
@Banderson I went back to the BAQ to ensure my sorting was working only to find that it isnât even sorting by what I chose. I will start a new topic.
@Banderson I figured out that the BAQ sorting was not working because we had a table joined to the query that was using the legacy summation. This was not allowing the sorting to work. When I created a subquery and summed that table there and then joined the subquery, the sorting proceeded to work.
A little late but here is another trick that Iâve used.
