I have not had need to use the Spector Soft program in quite awhile. It worked really well but had the side effectof triggering all the usual anti-spyware software we run (Symantec and Webroot back then and TredMicro now). Because basically it IS spyware. It is supposed to have some features to slip under the radar of inhouse tools but the user I was monitoring did get messages from time to time and I just said to ignore them. So it is not quite as "stealth" as I would have liked. There are at least a couple newer versions sicne then (as evidenced by frequent upgrade emails I get) so perhaps they have evolved with the anti-spyware products. It does what it claims to be able to do and was not overly expensive.
We never used it in conjunction with Citrix so I don't know about that. As far as processing overhead I did not notice much but it did fill up a fair sized logging file with the screens and sites visited.
BTW...the user being monitored was vindicated...not that he ever knew there was a question. We have not had to use it since but do occasionally dump out the web traffic "packets by user" report from our SonicWall firewall....just to see who the big users are. Lately this has been skewed by increased use of streaming radio stations on weekends (when they are allowed).
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bbvantage
Sent: Tuesday, April 01, 2008 10:44 AM
Subject: [Vantage] Re: [OT] Web Usage Logging
Todd C.,
I too am asked to do some sniffing. I found this message, and was
wondering how the Spector Soft selection went for you. I am pretty
sure from other postings I have seen from you that you use Citrix.
Does this specific product work ok with Citrix? Are there a lot of
processing overhead for this tracker?
Bruce
-Todd C.
Todd C.,
Bruce
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Lee Ingalls" <eli3@...> wrote:
> offer that is... Is it still Monday?
> Todd,
> Let me over my 2cents worth... as the local "internet nazi" I use
Red Line
> Software's - Internet Access Monitor
> http://www.internetaccessmonitor.com/eng/products/iam/
> I point the application (IAM) at my Squid Proxy log, configured for
4
> different reporting groups and it compiles all internet activity
for the
> department(s) and emails the logs to the department supervisors
> automatically... I only get involved for discoveries and evidence
> documentation.
> Also, a good Acceptable Use Policy clearly spelling out what is and
is NOT
> acceptable internet use helps eliminate the grey areas.
> Happy Hunting! Lee
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
Behalf Of
> Todd Caughey
> Sent: Monday, May 08, 2006 1:46 PM
> Subject: RE: [Vantage] [OT] Web Usage Logging
> Thanks to all for the suggestions. I think we will go with
Rebecca's
> suggestion for Spector Soft. At $99 it is affordable and does
everything
> they were looking for (expecially total duration on sites). Only
drawback
> is it is installed on the Client. But I think we can use it as
a "tool kit"
> utility and install/ininstall when needed for a particular case. A
network
> wide logging system would be better so we could monitor overall
usage trends
> for everyone but for now this will do.
> BTW - we already have a companywide (and signed by each employee)
> notification that usage monitoring may be done.
> -Todd C.
> -----Original Message-----
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>]On
Behalf Of
> Butch Menge
> Sent: Monday, May 08, 2006 12:38 PM
> We use Squid running on Linux (free) for our proxy server. A
reporting
> tool called Sarg gives information on usage. We also use Group
Policy
> to disable the history button on some users computers (User
> Configuration/Administrative Templates/Windows Components/Internet
> Explorer) and totally disable the tab for others (User
> Explorer/Internet Control Panel). If you don't have Group Policy
> capabilities, you can disable the tabs by [carefully] doing a
registry
> change:
> [HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Internet
> Explorer\Control Panel]
> "GeneralTab"="1"
> Butch
Behalf
> Of Andrew Reed
> Sent: Monday, May 08, 2006 10:26 AM
> The complete IE history is not wiped clean when a user clicks "Clear
> History". In fact, a good majority of the history is still held in
an
> encrypted/locked file called index.dat. I have a VB program which
> interprets this file and prints it out.
> Also, I have a piece of sample code that would become the owner
> application of all instances of IE on a computer, thus enabling not
only
> logging, but complete interpretation of entire html sessions that
users
> are in. This sample application "hooks" into windows itself and
claims
> ownership of each new instance of IE. The beauty behind this app is
> that we had intended to develop it into a utility that would block
page
> access by detected content. Since the app had control of IE, it
could
> also close it.
> Im sure I have access to other file/system utilities in windows
that can
> help log things like that. Some coding sites have alot of source-
code
> for DIY'ers if your up to the task of developing your own stuff,
> www.planet-source-code.com is an excellent starting point.
Otherwise,
> there are $nooping apps out there (as Rebecca suggested) that will
> handle what your talking about as well.
> Andrew Reed
> Office Automation Specialist
> Crestview Aerospace Corporation
Behalf
> Of Todd Caughey
> Sent: Monday, May 08, 2006 11:59 AM
> Subject: [Vantage] [OT] Web Usage Logging
> I have been asked to find a way to log web usage. Not necessarily
to
> block or control....just log web sites visited and if possible the
> amount of time connected. I've used our SonicWall before but it
does
> not record as much detail as desired....just the total MB
transferred by
> user. We are trying to pin down some late night high volume usage
> possibly related to game playing (MUDs, etc...) by people supposedly
> working. Especially by users savvy enough to wipe IE history, temp
> files and cookies. Any suggestions?
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
must have
Builder and
> SPONSORED LINKS
> Manufacturing software
> <http://groups.yahoo.com/gads?
t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=P
da+database+software&w5=Database+management+software&w6=Database+marke
ting+s
> oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> Membership
database
> software
t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marke
> ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage
> software
t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+sof
tware&
w4=Pda+database+software&w5=Database+management+software&w6=Database+m
arketi
> ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
> Pda database software
t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+market
ing+so
> ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
t=ms&k=Database+management+software&w1=Manufac
oftwar
+marke
> ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing
> software
t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+so
ftware
&w4=Pda+database+software&w5=Database+management+software&w6=Database+
market
> ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
> YAHOO! GROUPS LINKS
> * Visit your group "vantage
> <http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com<mailto:vantage-unsubscribe%40yahoogroups.com>
> <mailto:vantage-unsubscribe@yahoogroups.com<mailto:vantage-unsubscribe%40yahoogroups.com>?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/> .
