Importing a Field to SSRS Report
Hello there!
I seem to be confusing myself with this one. I am working on a report for invoices. This report needs to display the Sales Order Number linked to it. I noticed that field is not included in the standard ssrs report so I must import it. I loaded up an invoice and have Field Help enabled. I also have open report definitions and the SSRS query.
Here I see the DB Field starts with InvcHead and the one I need (Sales Order) is called OrderNum.
Now I looked in Data Def and found something called OrderNum under exclusions for CashDtl. OrderNum is under exclusions but the box is not checked.
I also see it in CashHead but there is an Exclude Label checked
Here is the SSRS Query. I see the InvcHead again and it is linked to T1.
So I thought all I had to do was, since InvcHead was T1, at the top put
T1.OrderNum
However running the report just crashes.
Did you create a field for it under the dataset inside the SSRS report?
Yes, I did. I wasn’t sure if it was a calc field or query field, but I made the one and it crashed, then made the other but still crash.
Can you share the full query in text format not a screen shot?
You say it crashes, but do you get an error message you can share?
Do you know how to get the error? You want to go to your system monitor, click History Tasks, and then you should see a list of reports you’ve ran starting with most recent. Your report should show in the list with an error for the status. If you select that row in the grid, you should be able to click the Report/Task Logs tab and see what the error details are. (In my case it’s because there were no records but you should see an error that helps to identify the issue).
Yes the sys monitor says error. Here it was working earlier today as I messed with it but now doesn’t since I added T1.OrderNum
Here is the error of the most recent one.
T1.Company,
T1.CreditMemo,
T1.Calc_ExtPriceTotal,
T1.CustNum,
T1.DocDepositCredit,
T1.DocInvoiceAmt,
T1.Calc_TotalMiscChrg,
T1.Calc_TotalAdvBillCred,
T1.DocRounding,
T1.DocumentPrinted,
T1.Posted,
T1.InvoiceComment,
T1.InvoiceDate,
T1.InvoiceNum,
T1.InvoiceType,
T1.LegalNumber,
T1.PONum,
T1.SoldToInvoiceAddress,
T1.Calc_BillToAddressList,
T1.Calc_BottomAddress,
T1.Calc_CompanyAddressList,
T1.Calc_CurrDocDesc,
T1.Calc_CurSymbol,
T1.Calc_CustContactName,
T1.Calc_CustPartOpts,
T1.Calc_DteOrdrd,
T1.Calc_fFOB,
T1.Calc_MulPackNum,
T1.Calc_mulponum,
T1.Calc_MulShipDate,
T1.Calc_MulShipTo,
T1.Calc_MulShipVia,
T1.Calc_MultSoldTo,
T1.Calc_MultTaxID,
T1.Calc_NumRecordPerPage,
T1.Calc_NumTotalParts,
T1.Calc_PackNum,
T1.Calc_PrintBottomAddress,
T1.Calc_SalesPerson,
T1.Calc_SalesTerms,
T1.Calc_ShipDate,
T1.Calc_ShipToAddressList,
T1.Calc_ShipToContactName,
T1.Calc_ShipVia,
T1.[Calc_Voucher-String] as Calc_Voucher_String,
T1.CurrencyCode_CurrencyID,
T1.CurrencyCode_DecimalsGeneral,
T1.CurrencyCode_DecimalsPrice,
T1.Calc_SEBankRef,
T1.Calc_CustResaleID,
T1.CHISRCodeLine,
T1.Calc_CHBankAcctIBANCode,
T1.Calc_CHBankAcctISRPartyID,
T1.Calc_DocDspTaxAmt,
T1.Calc_IsDraftCopy,
T1.FirstPrintDate,
T1.Calc_ReverseChargeTax as Calc_ReverseChargeTaxTotal,
T1.DocCopyNum,
T1.PayDiscDays,
T2.Calc_TrackByAttribute,
T2.AttributeSetShortDescription,
T2.Company as InvcDtl_Company,
T2.DocAdvanceBillCredit,
T2.DocDiscount,
T2.DocUnitPrice,
T2.InvoiceComment as InvcDtl_InvoiceComment,
T2.InvoiceLine,
T2.InvoiceNum as InvcDtl_InvoiceNum,
T2.PackLine,
T2.PackNum,
T2.DropShipPackSlip,
T2.PartNum,
T2.POLine,
T2.PricePerCode,
T2.RevisionNum,
T2.SalesUM,
T2.SellingOrderQty,
T2.SellingShipQty,
T2.ShipDate,
T2.XPartNum,
T2.XRevisionNum,
T2.Calc_ActDate,
T2.Calc_BackOrdQty,
T2.Calc_UnitPrice,
T2.Calc_ExtPrice,
T2.Calc_Duration,
T2.Calc_GetNextLegalNum,
T2.Calc_InvcComment,
T2.Calc_InvoiceDisplayLine,
T2.Calc_IsKitParent,
T2.Calc_JobNumber,
T2.Calc_LabDur,
T2.Calc_LabMod,
T2.Calc_Labor,
T2.Calc_LineDesc,
T2.Calc_LineSoldToAddressList,
T2.Calc_MatDur,
T2.Calc_Mate,
T2.Calc_MatMod,
T2.Calc_Misc,
T2.Calc_MiscDur,
T2.Calc_MiscMod,
T2.Calc_Modifier,
T2.Calc_NextLegalNumID,
T2.Calc_NumLineByInv,
T2.Calc_ponum,
T2.Calc_PSLegalNum,
T2.Calc_Reference,
T2.Calc_SerialNumber,
T2.Calc_SerialNumber2,
T2.Calc_SerialNumber3,
T2.Calc_SerialNumber4,
T2.Calc_SerialNumber5,
T2.Calc_SerialNumber6,
T2.Calc_SerialNumber7,
T2.Calc_ShipToAddressList as InvcDtl_Calc_ShipToAddressList,
T2.Calc_ShipToContactName as InvcDtl_Calc_ShipToContactName,
T2.Calc_ShipToShipVia,
T2.Calc_WarrDesc,
T2.Calc_WhseCode,
T2.OrderLine_KitFlag,
ISNULL(T2.OrderLine_KitPricing,'') AS OrderLine_KitPricing,
ISNULL(T2.OrderLine_KitPrintCompsInv,0)AS OrderLine_KitPrintCompsInv,
ISNULL(T2.OrderLine_KitShipComplete,0)AS OrderLine_KitShipComplete,
T2.OrderLine_KitsLoaded,
T2.PartNum_PartDescription,
T2.EpicorFSA,
T3.CallComment,
T3.CallQty,
T3.PartNum as FSCallDt_PartNum,
T3.RevisionNum as FSCallDt_RevisionNum,
T3.XPartNum as FSCallDt_XPartNum,
T3.XRevisionNum as FSCallDt_XRevisionNum,
T3.Calc_CProb,
T3.Calc_fCallLine,
T3.Calc_InvoiceLine,
T3.Calc_InvoiceNum,
T4.Calc_InvoiceNum as FSCallMt_Calc_InvoiceNum,
T4.Calc_MatNum,
T4.Calc_MtPaNum,
T4.Calc_MtQty,
T4.Calc_MtBillPrice,
T4.Calc_MtExtPrice,
T4.Calc_MtLinedesc,
T4.Calc_MtRevNum,
T4.ResReasonCode,
T4.Calc_MtCount,
T5.RptLanguageID as Label_RptLanguageID,
T5.Calc_ActDate  as Label_Calc_ActDate,
T5.Calc_CreditMemo as Label_Calc_CreditMemo,
T5.Calc_Duration as Label_Calc_Duration,
T5.Calc_JobNumber as Label_Calc_JobNumber,
T5.Calc_LabDur as Label_Calc_LabDur,
T5.Calc_Labor as Label_Calc_Labor,
T5.Calc_MatDur as Label_Calc_MatDur,
T5.RptLiteralsLMaterial as Label_Calc_Mate,
T5.Calc_Misc as Label_Calc_Misc,
T5.Calc_MiscDur as Label_Calc_MiscDur,
T5.Calc_MtExtPrice as Label_Calc_MtExtPrice,
T5.Calc_SerialNumber as Label_Calc_SerialNumber,
T5.DocUnitPrice as Label_DocUnitPrice,
T5.InvoiceLine as Label_InvoiceLine,
T5.PONum as Label_PONum,
T5.ProbReasonCode as Label_ProbReasonCode,
T5.RptLiteralsLDescription as Label_Reference,
T5.RptLiteralsLBckOrd,
T5.RptLiteralsLBillTo,
T5.RptLiteralsLTWTotalTax,
T5.RptLiteralsLComeFrom,
T5.RptLiteralsLContinueInNext,
T5.RptLiteralsLCusPart,
T5.RptLiteralsLDate,
T5.RptLiteralsLEMaila,
T5.RptLiteralsLExtPrice,
T5.RptLiteralsLFax,
T5.RptLiteralsLFOB,
T5.RptLiteralsLHdng,
T5.RptLiteralsLInvoice,
T5.RptLiteralsLLegNum,
T5.RptLiteralsLLine,
T5.RptLiteralsLLineRef,
T5.RptLiteralsLof,
T5.RptLiteralsLOurPart,
T5.RptLiteralsLPackSlp,
T5.RptLiteralsLPage,
T5.RptLiteralsLPartDesc,
T5.RptLiteralsLPartRev,
T5.RptLiteralsLPhone,
T5.RptLiteralsLPONum,
T5.RptLiteralsLAULessDeposit,
T5.RptLiteralsLQty,
T5.RptLiteralsLQtyOrd,
T5.RptLiteralsLRev,
T5.RptLiteralsLLinesSubtotal,
T5.RptLiteralsLRounding,
T5.RptLiteralsLMiscChgs,
T5.RptLiteralsLSalesKit,
T5.RptLiteralsLSeeBelow,
T5.RptLiteralsLShipTo,
T5.RptLiteralsLShpVia,
T5.RptLiteralsLSlsTxID,
T5.RptLiteralsLSoldToL,
T5.RptLiteralsLTotal,
T5.RptLiteralsLWarrantyA,
T5.RptLiteralsLWHCode,
T5.ShipDate as Label_ShipDate,
T5.UnitPrice as Label_UnitPrice,
T5.RptLiteralsLSEOCR,
T5.RptLiteralsLNOKID,
T5.RptLiteralsLDiscountPercent,
T5.RptLiteralsLVatNr,
T5.RptLiteralsLlessAdvBill,
T5.RptLiteralsLAttributeSet,
T5.RptLiteralsLFSAEquipmentPartNum,
T5.RptLiteralsLFSAServiceOrderNum,
T1.Calc_CustFax,
T6.EMailAddress,
T6.FaxNum,
T6.ResaleID,
T5.RptLiteralsLOrdered as Label_Calc_DteOrdrd,
T5.RptLiteralsLSalsRep as Label_Calc_SalesPerson,
T5.RptLiteralsLTrms as Label_Calc_SalesTerms,
T1.Calc_CustEMailAddress,
T1.Calc_DropShipPackSlip,
T7.InvoiceComment as FSContDt_InvoiceComment ,
T7.ContractQty,
T7.PricePerUnit,
T7.DocPricePerUnit,
T7.Calc_ContPrice,
T5.PricePerCode as Label_PricePerCode,
T5.PartNum as Label_PartNum,
T5.ExtPrice as Label_ExtPrice,
T1.Calc_PELegalText,
T5.RptLiteralsLAmt,
T5.Calc_SEBankRef as Label_Calc_SEBankRef,
T1.Calc_TaxMethod,
T1.SEBankRef,
T1.Calc_LessPrepaidDeposits,
T5.RptLiteralsLLessPrepDeposits,
T5.Calc_ReverseChargeTax as RptLiteralsLReverseChargeTax,
T7.ContractLine,
T7.PartNum as ContractPartNum,
T7.PartNum_PartDescription as ContractPartDescription,
T7.ContractNum as ContractNum,
(CASE WHEN EXISTS(SELECT 1 FROM   InvcChrg_" + Parameters!TableGuid.Value + " Tmp WHERE  Tmp.Company = T1.Company AND    Tmp.InvoiceNum= T1.InvoiceNum AND    Tmp.InvoiceLine = T2.InvoiceLine) THEN 1 ELSE 0 END) AS 'HasFinCharges',
(CASE WHEN T8.Description IS NOT NULL  THEN 1 ELSE 0 END ) AS 'HasMiscCharges',
T8.[Description],
T8.DocMiscAmt,
T8.SeqNum,
T5.[Description] AS Label_Description,
(CASE WHEN T8.SeqNum = T9.MinSeqNum THEN 1 ELSE 0 END ) AS DisplayLineInfo,
T5.RptLiteralsLCopy,
T5.RptLiteralsLPrintedAt,
T5.RptLiteralsLFirstPrinted,
T5.RptLiteralsLDraftCopy,
T5.RptLiteralsLInternalUse,
T10.FSAEquipmentPartNum,
T10.FSAServiceOrderNum,
T5.Calc_PLWasteRegisterNum as Label_Calc_PLWasteRegisterNum,
T8.MiscCode,
T8.Calc_ChargeDesc,
T5.Calc_CompanyEORINumber as Label_Calc_CompanyEORINumber,
T1.Calc_CompanyEORINumber,
T1.Calc_CustShipToEORINumber,
T2.ServiceSource,
T5.RptLiteralsLServiceSource
          ,T11.PayerRef as BankAcct_PayerRef, T11.TypeCode as BankAcct_TypeCode
          FROM InvcHead_" + Parameters!TableGuid.Value + " T1
          LEFT OUTER JOIN InvcDtl_" + Parameters!TableGuid.Value + " T2
          ON T1.Company = T2.Company AND T1.InvoiceNum = T2.InvoiceNum
          LEFT OUTER JOIN FSCallDt_" + Parameters!TableGuid.Value + " T3
          ON T2.Company = T3.Company AND T2.InvoiceLine = T3.Calc_InvoiceLine AND T2.InvoiceNum = T3.Calc_InvoiceNum
          LEFT OUTER JOIN FSCallMt_" + Parameters!TableGuid.Value + " T4
          ON T3.Company = T4.Company AND T3.CallNum = T4.CallNum AND T3.Calc_fCallLine = T4.Calc_fCallLine AND T3.Calc_InvoiceLine = T4.Calc_InvoiceLine AND T3.Calc_InvoiceNum = T4.Calc_InvoiceNum
          LEFT OUTER JOIN RptLabels_" + Parameters!TableGuid.Value + " T5
          ON T1.RptLanguageID = T5.RptLanguageID LEFT OUTER JOIN Customer_" + Parameters!TableGuid.Value + " T6
          ON T1.Company = T6.Company AND T1.CustNum = T6.CustNum AND T1.InvoiceNum = T6.Calc_InvoiceNum
          LEFT OUTER JOIN FSContDt_" + Parameters!TableGuid.Value + " T7
          ON T2.Company = T7.Company AND T2.InvoiceLine = T7.Calc_InvoiceLine AND T2.InvoiceNum = T7.Calc_InvoiceNum
          LEFT OUTER JOIN InvcMisc_" + Parameters!TableGuid.Value + " T8
          ON T1.Company = T8.Company AND T1.InvoiceNum = T8.InvoiceNum AND T2.InvoiceLine = T8.InvoiceLine
          LEFT OUTER JOIN FSAExtData_" + Parameters!TableGuid.Value + " T10
          ON T2.Company = T10.Company AND T2.SysRowID = T10.ForeignSysRowID
          LEFT OUTER JOIN ( SELECT  temp.Company, temp.InvoiceNum, temp.InvoiceLine, MIN(temp.SeqNum) as MinSeqNum
          FROM InvcMisc_" + Parameters!TableGuid.Value + "  temp
          GROUP BY     temp.Company, temp.InvoiceNum, temp.InvoiceLine) T9
          ON T1.Company = T9.Company
          AND T1.InvoiceNum = T9.InvoiceNum
          AND T2.InvoiceLine = T9.InvoiceLine
          LEFT OUTER JOIN (SELECT DISTINCT Company, BankAcctID, PayerRef, TypeCode FROM BankAcct_" + Parameters!TableGuid.Value + ") T11
          ON T1.Company = T11.Company AND T1.OurBank = T11.bankacctid
          ORDER BY  T1.InvoiceNum, T2.Calc_NextLegalNumID, T2.InvoiceLine, T8.SeqNum, T3.Calc_fCallLine, T4.Calc_MtCount"
I took out the T1.OrderNum but I just put that at the top, after the first entry.
In your original post, you mention that you found OrderNum on CashDtl, but then state you tried to add the field to T1 which is InvcHead. That is why it is erroring.
You actually want to get OrderNum from InvcDtl as an Invoice can be cut for multiple orders, it is not a 1 to 1 relationship.
CashDtl has it as an exception and checked. I should uncheck that box then?
For me to edit that, I need to make a duplicate. How should I go about duping it? From data def maintenance, I can click on ARForm and it has a copy thing but not like how you can copy a report it has a different button to actually make a duplicated copy.
You can go to actions and then select copy report style. You should also be editing a copy of your base report and then creating a new report style and pointing it towards the edited report/rdd.
The best way to edit an out of the box report is to do the following:
  • You have to make a duplicate of the RDD as you cannot edit the ones that Epicor made.
  • You should create a new Report Style and select the new RDD you created. If you just change the RDD on the standard report, it will get overridden on any upgrade.
  • You should create a new RDL under Custom Reports. Again, if you just change the standard report, it will get overridden on an upgrade.
I have a new report I am working on. I just mean if I’m supposed to change the exclusions in DataDef Main, it tells me I need to dup the data definition
Make this box clear right?
If I do, it tells me this.
@Creese , you do not need to change the RDD as the standard one already has OrderNum included on the InvcDtl table. If you add T2.OrderNum to the RDL, it should work.
I will try that, but why is it T2 and not T1 if T1 says InvcHead which is what the field help says it uses?
I am not understanding how to read the code I guess.
I still got an error. Is it supposed to be a Query field or a calculated field?
I didn’t know so I tried both. I noticed with the Query Field, the expression said “First” so I got rid of it but still crashed. The Calc field had a “Sum” in front, deleting that also did nothing. And just to check when I put the field in, I gave it Calc_OrderNum. Also did not work. All errors. Which one was I supposed to do so I dont do a bunch of checks again?
T2 is the InvcDtl table, which is the table that has the field in it that you want. You want to add it as a Query Field and enter OrderNum in both of the fields. If you are getting errors when running it, you need to post them so we can help. Without the error we do not know where to point you.
