There are some valid points in all the comments, and in the most part I agree, but I also disagree. Epicor ERP does try to be all things in one system, and in some areas, functionality is it better than other parts. Like a lot of aspects with Epicor ERP, just like other complicated software, is that the configuration and understanding how it works is critical. CRM is no exception.
In a past life, the company I was at we implemented Epicor 9 with CRM and used it for not only Sales, but for helpdesk for customer support and also for escalation to our development team changing a Helpdesk Case into an ECO and assigning it to the appropriate workforce. At the time the local expertise with the CRM module was very very limited even to the point of having consultant flown in from Europe!
For the most part it worked, but getting the users (and myself) understand the configuration, and the process, addition of an additional dashboard to act as a queue monitor (although we could have used tasks) and the solution works and as far as I’m aware still working today. It was implemented in 2013! Not sure what that really says actually.
My point is, before discounting built in functionality, investigate thoroughly, as the hidden benefits with regards to the way cases link to other parts of the system may outweigh the benefits and ongoing costs of adding to the ever increasing library of software maintenance.
Epicor offer Saleforce integration, I have no experience of it, so it is hard to comment. As always, it’s all about what is the best fit, but remember asking the users what they want to use, they will always go with what they know and you are then left potentially having to build an interface for it.
Three options I guess:
- If they use saleforce now and wish to continue, look at the Epicor Integration
- Your company is willing to invest in review, configuration and potential process change. Look at Epicor CRM out of the box.
- Have a good development team or an in house CRM/Mobile CRM solution, then look at the custom integration route (with REST).
@Mark_Wonsil
Epicor have ITSM which is an offshoot of eFrontOffice/Clientele for IT Service Management. It is a third partly product built by mProof in the Netherlands. When I last used it, it had all the functionality of Clientele, but with the added ITIL bent including things like remote access from a button, and AD integration, as well as a SharePoint Support Portal. The client app was lightening fast. An interesting fact SLS was originally developed as a module for eFrontOffice/Clientele.
Apologies for the longwinded post, I’ve written it over a period of time.
