SOLVED!!!!!!!!!!!
Back when I originally had this issue, i just threw a button on there and gave up on the EpiCombo. Recently, I ran into this issue again on the Job Entry screen. By pure luck, I found a fix:
While in Developer Mode, open the screen that contains your Glitched EpiCombo.
Do not open the Customization Tools Dialog, simply navigate to, and select the tab that contains your glitched EpiCombo.
Move the tab that contains your EpiCombo around, while doing so, save the layouts (toolsà Save Layouts) (Note: when you save the layouts while IN Developer mode, it is NOT a personalization; you are actually customizing the screen).
Then, put the tabs back in their original order and Save the layouts one more time. The Glitch should now be gone.
Note: If by chance this does not fix the issue for you, there is a sloppy way to fix this as well. I noticed that the ReadOnly anomaly would not happen if I opened the screen, navigated to where the dropdown was and then entered a value that would get the screen to load. So what I did was loaded the screen in developer mode grabbed the tab that my dropdown was in, and moved the tab to be the first tab. That way, whenever the screen would open the dropdown that was messed up would be displayed first. For some reason displaying the glitched EpiCombo, before the screen loaded any data fixed the ReadOnly issue.
I discovered the fix above because I got curious thinking that changing the layouts in developer mode (thereby saving the changes to the customization itself), might have something to do with this glitch. So I played around with moving the tabs and Saving the Layouts while doing so. All of a sudden I noticed that the ReadOnly glitch just went away, whether the tab was displayed first or not.
---In vantage@yahoogroups.com, <chan213419@...> wrote:LOL! that's what I'm about to say!!!
OK after taking everyone's input and hitting this again, I got a tiny step further but it's still not working.
I disabled the dropdown in the Cust Tools Dialog, and wrote script that enables/disables the dropdown in regards to 2 UD fields being NULL or not. My idea was if the screen thinks it should be disabled all the time, then I'll force it to enable/disable to get around it.
Result: It worked the first time, but went back to being readonly
after closing/opening again: didn't work. Went and checked to Cust
Tools Dialog and found that Epicor switched it back to being Enabled.
So then I created a Load event that Disabled the dropdown.
Result: It works... but not really. Get this, BEFORE loading any customers into the screen, I navigate to the tab that this dropdown is located. There I see that it is disabled. Then, I load a customer and navigate back and the dropdown WORKS. If I load the Customer Maintenance screen, load a customer, and navigate to the dropdown... it's read only...
So it works, but the users would have to go to the tab where the dropdown is located each time before loading a customer... which is ridiculous. I also need to add, that the tab that this dropdown is located in is a Customized tab that I added with the Sheet Wizard
(could this be the smoking gun?).
This dropdown is about to become a search button... just REAL frustrating! This doesn't make sense to me.
Everyone is awesome on here though! Thanks for all your help!
Chan
--- In vantage@yahoogroups.com, Greg Payne <gpayne@...> wrote:
> No, I told the users to quit telling me about it and use the text field.
> Greg
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
> Sent: Wednesday, April 17, 2013 8:30 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Re: Customization Strangeness
> When you say it kept moving, you mean you would place it where you wanted it and it would bounce back to the same location every time at runtime?
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> From: "Greg Payne" <gpayne@...<mailto:gpayne%40compulink-usa.com>>
> Sent: Tuesday, April 16, 2013 11:08:02 PM
> Subject: RE: [Vantage] Re: Customization Strangeness
> I have a one that is like that. I recreated it numerous times. It is an epicombo that pulled users codes fields.
> I just put a text box bound to the same field under it and kept moving.
> wish I had a solution for you.
> Greg
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> ] On Behalf Of chan213419
> Sent: Tuesday, April 16, 2013 8:08 PM
> Subject: [Vantage] Re: Customization Strangeness
> Well... it's getting even stranger now.
> I created other Customizations and tested to root out anything that could be causing it. Once I determined that I couldn't find anything, I deleted those customizations and set the origional to open by default in Menu Maintenance.
> As soon as I changed it to the original in Menu Maintenance I opened it. I noticed that my dropdown was now available. Before getting too excited, I closed it and opened again and to my dimay, it went back to being Read Only.
> I am beyond confused now.
> Any suggestions would be much appreciated.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>, "chan213419" <chan213419@<mailto:chan213419@<mailto:chan213419@%3cmailto:chan213419@>>> wrote:
> > Thanks for the help! Unfortunately, it's still doing it... i cleared the personalizations, cleared cache, and closed/opened Epicor...
> > Still doing it.
> > Do you think I should restart the server?
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>, "noor.fazli@" <noor.fazli@> wrote:
> > > It looks like you have some personalization layer on top of customization that seems to make them different.
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>, "chan213419" <chan213419@> wrote:
> > > > Has anyone ever created a customization that when loaded in Developer mode it behaves one way, and when you load that same customization out of Developer it behaves differently?
> > > > I created a dropdown in the Customer Maintenance screen and when I load that customization in developer mode it is NOT Read Only, but when I load that same customized screen out of developer it IS Read Only.
> > > > Again, the customization I open in developer is the same customization that loads by default.
> > > > I cleared Client Cache, closed/opened epicor and it's still doing this.
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
