I got excited for a bit b/c changing "retrieve on activate" to false stopped the dropdown from being readonly. However, now the dropdown doesn't work (i.e. doesn't display any values for the user to select).
This dropdown is filtered by two other fields on my screen.
--- In vantage@yahoogroups.com, "jckinneman" <jckinneman@...> wrote:
> Since you mentioned this is happening on a dropdown/combo you might try adjusting the retrieve on activate setting. Flip it from whatever it is to the other choice.
> Jim Kinneman
> Encompass Solutions, Inc
> --- In vantage@yahoogroups.com, Joe Englert <englertj@> wrote:
> > I’ve had similar problems. Setting the position of the control on form load has worked. Though, even that has not been 100%
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
> > Sent: Wednesday, April 17, 2013 8:58 AM
> > Subject: Re: [Vantage] Re: Customization Strangeness
> > Have you tried setting the readonly extendedproperty of the bound epiDataView field on the forms load event? What field is the control bound to?
> > ________________________________
> > From: chan213419 <chan213419@<mailto:chan213419%40yahoo.com>>
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Sent: Tuesday, April 16, 2013 8:09 PM
> > Subject: [Vantage] Re: Customization Strangeness
> > I removed personalizations, unfortunately this didn't work...
> > I have no idea why this is happening. Do you think I should restart the epicor box?
> > --- In mailto:vantage%40yahoogroups.com, Joshua Giese <jgiese@<mailto:jgiese@>> wrote:
> > > I have had to clear personalizations for that customization before, because for some reason it decided to tweak out
> > > Joshua Giese
> > > CTO
> > > 920.437.6400 Ext. 337
> > > Site ID: 27450-E905700B2-SQL64
> > > ----- Original Message -----
> > > From: "chan213419" <chan213419@<mailto:chan213419@>>
> > > To: mailto:vantage%40yahoogroups.com
> > > Sent: Tuesday, April 16, 2013 4:05:46 PM
> > > Subject: [Vantage] Customization Strangeness
> > > Has anyone ever created a customization that when loaded in Developer mode it behaves one way, and when you load that same customization out of Developer it behaves differently?
> > > I created a dropdown in the Customer Maintenance screen and when I load that customization in developer mode it is NOT Read Only, but when I load that same customized screen out of developer it IS Read Only.
> > > Again, the customization I open in developer is the same customization that loads by default.
> > > I cleared Client Cache, closed/opened epicor and it's still doing this.
