BAQ Expression help (LIKE function)
Super dumb question… How do you use the ‘like’ function in a BAQ calculated field?
I have a calculated field of type bit (boolean), and want to check if the Part.PartNum field is in a certain format. My format is ss-nnnn where ss is two letters, and nnnn is 4 number characters.
Ignoring the requirement for character types for the moment, I want to check if the PN is like ‘__-____’ (using SQL wildcards in my example)
Any of the following give a syntax error
PartCost.PartNum like '__-____'
(PartCost.PartNum like '__-____' )
(PartCost.PartNum like '__-____' ) = 1
(PartCost.PartNum like '__-____' ) = TRUE
Double clicking the function to insert it, just inserts
like '%%'
And the function tip just states:
While I’d still like to know the syntax for using the like function, i ended up just implementing it as
(case when Len(PartCost.PartNum)=7
  AND  substring(Upper(PartCost.PartNum), 1, 1)>= 'A' AND  substring(Upper(PartCost.PartNum), 1, 1)<= 'Z'
  AND  substring(Upper(PartCost.PartNum), 2, 1)>= 'A' AND  substring(Upper(PartCost.PartNum), 2, 1)<= 'Z'
  AND  substring(PartCost.PartNum, 3, 1)= '-'
  AND  substring(PartCost.PartNum, 4, 1)>= '0' AND  substring(PartCost.PartNum, 4, 1)<= '9'
  AND  substring(PartCost.PartNum, 5, 1)>= '0' AND  substring(PartCost.PartNum, 5, 1)<= '9'
  AND  substring(PartCost.PartNum, 6, 1)>= '0' AND  substring(PartCost.PartNum, 6, 1)<= '9'
  AND  substring(PartCost.PartNum, 7, 1)>= '0' AND  substring(PartCost.PartNum, 7, 1)<= '9'
then 1 else 0 end)
And is there really no
If ... Then ... Else
Hi Calvin,
The hyphen is a range operator, so if you want to look for a hyphen, you have to escape it. I believe your pattern will be:
[-]_’
Mark W.
Looking at your second email, the pattern would be:
‘[A-Z][A-Z][-][0-9][0-9][0-9][0-9]’
Mark W.
It wasn’t the pattern I was having problems with, It was the syntax for a calculated field. (even the pattern ‘%’ would give me a syntax error.
Turns out you can’t have an expression that just evaluates to TRUE or FALSE, you have to test for TRUE or FALSE and then return a true or false. But not really ‘true’ or ‘false’, you must return a 1 or 0
This yields an error
(PartCost.PartNum like '__-____')
But this works:
(case when (PartCost.PartNum like '__-____') then 1 else 0 end)
So much time wasted on syntax …
:rage:
Case is the SQL equivalent to IF. As for the like function, it is pretty basic.
Like would be either Begins with, Contains or Ends with on a static string.
like ‘05-%’ would list all that began with 05-
like ‘%05-%’ would list all that contains 05-
like ‘%05-’ would list all that end with 05-
there’s also
CASE
WHEN SUBSTRING(PartCost.PartNum, 1, 1) like ‘%[a-z]%’
WHEN SUBSTRING(PartCost.PartNum, 2, 1) like ‘%[a-z]%’
WHEN SUBSTRING(PartCost.PartNum, 3, 1) = ‘-’
WHEN SUBSTRING(PartCost.PartNum, 4, 1) like ‘%[0-9]%’
THEN ‘True’ ELSE ‘False’ END
Ah, I see. Yes. I’ve had to use the CASE statement to do the exact same thing too.
Mark W.
Whoa, whoa whoa …
So
(case when then else end)
is like an IF THEN ELSE, but uses Multiple ‘when < expressions >’ as an AND ??
and
case
    when  then
    when  then
    else
end
Is like a switch … case in C ??
Oops my bad. I didn’t proof read that.
CASE
AND SUBSTRING(PartCost.PartNum, 2, 1) like ‘%[a-z]%’
AND SUBSTRING(PartCost.PartNum, 3, 1) = ‘-’
AND SUBSTRING(PartCost.PartNum, 4, 1) like ‘%[0-9]%’
Why are there the percent signs in the expressions?
Wouldn’t that always match? The opening percent sign would always match the one character result of SUBSTRING(PartCost.PartNum, 1, 1)
mess around with this in the sql editor first. Then translate once you get your desired results.
The like expression in BAQ needs “%” not single quotes. In SQL editor it will be single quotes.
select left(PartNum,(charindex('-',PartNum)-1)) as BeforeDash, right(PartNum,(charindex('-',PartNum)-1)) as AfterDash, len(replace(PartNum, '-', '')),  len(PartNum)-1 ,  PartNum
from Part
where
-- one dash only
len(replace(PartNum, '-', '')) = len(PartNum)-1
-- characters before the dash
and left(PartNum,(charindex('-',PartNum)-1)) like '%[a-zA-Z]%'
-- digits only after the dash
and right(PartNum,(charindex('-',PartNum)-1))  like '%[0-9]%'
It wouldn’t always match since % is not a character wildcard itself but only shows when the wild card begins or ends. But you are correct that with dealing with only one character the % sign is unnecessary.
Unfortunately, for Knash’s example if the prefix or suffix is alphanumeric it will show true because it contains not equals.
This will return all items that match the criteria. You can then use the this as a subquery to your main query to show which parts are valid and which are not.
I just validated that only two records are returned.
CREATE TABLE #TempTable (PartNum Varchar(50));
INSERT INTO #TempTable
VALUES
     ('aa-1234'),
     ('BB-1235'),
     ('443-asdf'),
     ('aq-123-12'),
     ('erew-123')
from #TempTable
where
-- one dash only
-- length of left is only two
 and len(left(PartNum,(charindex('-',PartNum)-1))) = 2
DROP TABLE #TempTable
Yes, it works in that case but a1-1234 will also show.
keep the coming Dan :wink:
This code was not final. The users will still need to tweak as needed. This is getting closer to what is needed. There may still be some situations that need to be fixed. This returns 3 rows.
AA, BB, and er
VALUES
     ('aa-1234'),
     ('BB-1235'),
     ('443-asdf'),
     ('aq-123-12'),
     ('er-1223'),
      ('BC-12f35'),
     ('B7-1235')
SUBSTRING(PartNum,CHARINDEX('-',PartNum)+1,LEN(PartNum)) as AfterDash,
len(PartNum)-1 ,
PartNum
from #TempTable
where
-- one dash only
and left(PartNum,(charindex('-',PartNum)-1))   like '[a-zA-Z][a-zA-Z]'
and ISNUMERIC(SUBSTRING(PartNum,CHARINDEX('-',PartNum)+1,LEN(PartNum))) = 1
 and len(SUBSTRING(PartNum,CHARINDEX('-',PartNum)+1,LEN(PartNum))) = 4
Oooo I didn’t know this was possible. Very nice.
Hate to be a party pooper, but the original question was about BAQ calculated field syntax, not SQL query syntax. :wink:
But always good to know more than you asked. :grinning:
I guess there is no RegEx equivalent in SQL (or BAQ calculated expressions) ?
in regex the pattern would be ‘^[a-zA-Z][a-zA-Z]-[0-9][0-9][0-9][0-9]$’
I was getting there…
:slight_smile:
Is this what you are looking for?
I grew up on programming C (K&R standard) and became way too dependent on the definitions of TRUE and FALSE.
False is 0. True is anything that is not False.
So…
int i=3
if(i) {....}
was perfectly acceptable. Now I have to do…
int i=3
if(i<>0){...}
Sorry we high jacked your thread. :kissing_heart:
I know the original question was about like ‘%%’ which does have to equal a true/false which was answered but… this might be the simplest solution for your calculated field?
CASE WHEN PartCost.PartNum like ‘[a-zA-Z][a-zA-Z]-[0-9][0-9][0-9][0-9]’ and LEN(PartCost.PartNum) = 7 THEN 1 ELSE 0 END
