Dan - Is there no “start” and “end” (like the ^ and $ in RegEx)? If there were, you could eliminate the check for length.
As long as you don’t put % in front of it, it’s looking at the start. Same with the end.
So in the Statement
PartCost.PartNum like '[a-zA-Z][a-zA-Z]-[0-9][0-9][0-9][0-9]' and LEN(PartCost.PartNum) = 7
the and LEN(PartCost.PartNum) = 7
is superfluous ?
So PartCost.PartNum like '[a-zA-Z][a-zA-Z]-[0-9][0-9][0-9][0-9]'
evaluates as true for AB-1234, but false for ab-12345 ??
This is a calculated field in the baq.
case when (Part.PartNum like '[0-9][0-9][0-9][-][0-9][0-9][0-9]') then 1 else 0 end
this is getting hard for me to debug as our partnum are different
this works so I would think you would want
case when (Part.PartNum like '[a-zA-Z][a-zA-Z][-][0-9][0-9][0-9][0-9]') then 1 else 0 end
Add the brackets around the - to be [-]
Mark had this all along.
