Just got a Zebra 2844 Printer (came from UPS) and was using the UPS
Worldship drivers. Everything seemed to be going good until a
problem came up. Now Crystal Report will not show the fields and
Vantage will not print to any printer that has Crystal Report
associated with it. I called support and they told me it was either
the Report (if modified) is bad or the Runtime has went bad. I have
uninstalled the Runtime and it didnt fix the problem. I placed the
original form... same thing again. Below is the error that Epicor is
giving me... If I need to open another thread, I will.
Error Detail
Specified method is not supported.
Stack Trace
at
CrystalDecisions.CrystalReports.Engine.Migration.PrintOptionsConverter
.DNETPaperSourceToEROMPaperSource(PaperSource ePaperSource)
at
CrystalDecisions.CrystalReports.Engine.PrintOptions.set_PaperSource
(PaperSource value)
at Epicor.Mfg.Lib.Report.EpiCrystalViewer..ctor(String rptFile,
String dataFile, PrinterSettings ps, String rTitle)
String dataFile, String rTitle)
at
Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.previewCrystalReport()
Error Detail
Stack Trace
at
at
(PaperSource value)
at
