Xp sp2
We are using Symantec corp ver 9 here, I have not had any problems with
sp2.
Judd
Custom Hoists, Inc.
Sent: Wednesday, October 13, 2004 5:42 PM
Subject: [Vantage] XP SP2
Are there any problems with running Vantage and XP service pack 2?
Also, someone mentioned earlier that there was a problem with SP2 and
Symantec Corporate Edition. Is there a fix for this?
Thanks!
Sandy Morse
BVR Technologies Company
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129fs8l5q/M=315388.5497957.6576270.3001176/D=gr
oups/S=1705007183:HM/EXP=1097790375/A=2372354/R=0/SIG=12id813k2/*https:/www.
orchardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21004SS> click
here
<http://us.adserver.yahoo.com/l?M=315388.5497957.6576270.3001176/D=groups/S=
:HM/A=2372354/rand=270928063>
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
Anyone running Vantage on SP2? Any issues?
Does progress have an official position?
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.20.322, Progress 9.1D, Windows 2003 Server, Crystal 8.5.3.975
I'm running version 4 without any problems. I am working an Excel issue
right now somehow related to SP2 but it is isolated.
I started rolling it out slowly at first to see what would happen and would
recommend that to you as well.
I really like the built in pop up blocker for IE. The firewall is ok, but
Zonealarm is better.
Jim Moore
Sent: Monday, August 23, 2004 11:24 AM
Patrick Winter
Yahoo! Groups Links
Patrick,
This might help - ...
Worried about SP2 incompatibilities?
Many of you are likely to be concerned about potential problems caused by
the installation of Windows XP SP2, and with good reason. Though the upgrade
will make your PC more secure, it definitely causes issues in some cases.
We'll be tracking the problems as they arise. But so far, the issues are
relatively minor, with more serious problems confined to a few specific
programs.
First, Microsoft has published a list of third-party applications called
<http://support.microsoft.com/default.aspx?kbid=884130&product=windowsxpsp2>
Programs that behave differently in Windows XP Service Pack 2. Of the three
dozen or so apps on this list, most of them exhibit symptoms that are
irritating but not fatal. In other cases, such as Adobe LiveMotion 1.0,
Softwin BitDefender 7.2, and ScanSoft PaperPort Deluxe 8.0, the programs no
longer install and/or run. You should definitely examine the list in this
document to check for programs you may be using.
The document links to three other Knowledge Base articles with related
information about known incompatibilities. The most interesting of these is
KB article <http://support.microsoft.com/?scid=kb;en-us;842242> 842242.
This document currently lists about 50 programs that require exceptions to
be made in the Windows Firewall. Some major Microsoft apps are in here, such
as VisualStudio.Net, SQL Server, and SMS 2003 Server. Other well-known
programs on the list are Symantec AntiVirus Corporate Edition 8.0, AutoCAD
2000 (and higher), and Veritas BackupExec. This is yet more required reading
for harried Windows admins.
These and other programs will need upgrades or other tweaks to operate
successfully with XP SP2. If you're using XP, you should collect the names
of the vendors whose programs you depend on, and start checking their Web
sites for SP2-specific downloads, many of which are already available
online.
Second, while problems actually installing and running SP2 seem to be rare,
it's wise to approach this update as if it were a full-blown Windows
upgrade. That means you should backup your important data before installing
SP2. You should also use the upgrade for a few days before installing any
other applications on top of it.
Third, remember that SP2 isn't a panacea. It's not going to suddenly fix all
of your problems or cure all of your security concerns. As we've noted
previously, one obvious deficiency in SP2 is that it includes only a one-way
firewall, not two-way. This means XP's renamed Windows Firewall has no
ability to prevent applications on your system from communicating with
online servers and services. This can be a problem if you inadvertently
catch a nasty worm or Trojan horse.
_____
Patrick Winter
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129e3h4gp/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705007183:HM/EXP=1093364661/A=2319498/R=0/SIG=11thfntfp/*http://www.
netflix.com/Default?mqso=60185352&partid=5285298> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
:HM/A=2319498/rand=369024550>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Thanks!
Sandy Morse
I am running both XP SP2 and Corp Edition clients and have experienced no issues (knock on wood). No problems with Vantage either. Have been using XP SP2 for several weeks. (since it became available to SUS users).
Sent: Wed 10/13/2004 5:42 PM
Thanks!
Sandy Morse
Yahoo! Groups Links
SP2 works fine with Vantage. If there is any question about the
compatability of any software and xp sp2, contact the vendor.I'm sure
any major problems have been brought to their attention by now
because SP2 has been out for a while.
Brandon
> From: Sandy Morse [mailto:smorse@b...]
and
> Thanks!
> Sandy Morse
access. )
> Yahoo! Groups Links
Both the Epicor and BusinessObjects web pages indicate there is a problem
with SP2 and Crystal Decisions. I have experienced it. With SP2 I could
edit any existing CD reports but could not create a new one using ODBC.
Only help from Epicor or BO was to uninstall SP2.
Jerry Boyle, Controller
Sipco Molding Technologies
Meadville, PA. 16335
p 814.724.2243 x53
f 814.724.2244
Vantage 6.10.506
and
Epicor site says Crystal 8.5 will not work.
Sent: Thursday, October 14, 2004 9:55 AM
Subject: RE: [Vantage] Re: XP SP2
edit any existing CD reports but could not create a new one using ODBC. Only
p 814.724.2243 x53
f 814.724.2244
Vantage 6.10.506
Are there any problems with running Vantage and XP service pack 2? Also,
someone mentioned earlier that there was a problem with SP2 and Symantec
Yahoo! Groups Links
The 'workaround' for sp2 is to go to control panel and turn off the
firewall. Your pop up stopper and other browser functions work ok. After you
turn off the firewall crystal reports will work.
Judd
Custom Hoists, Inc.
Sent: Thursday, October 14, 2004 10:02 AM
p 814.724.2243 x53
f 814.724.2244
Vantage 6.10.506
Yahoo! Groups Links
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129m3k45f/M=315388.5497957.6576270.3001176/D=gr
oups/S=1705007183:HM/EXP=1097848914/A=2372354/R=0/SIG=12id813k2/*https:/www.
here
:HM/A=2372354/rand=160350065>
_____
Yahoo! Groups Links
