Wrong operation
Bart,
If it was just labor entry records: Delete them & re-enter against correct OP.
Once inspection processed though, it is a one way street. You can't reverse.
What if you edit your job op details (reordering them so incorrectly reported OP is the current WIP OP - and edit the details so it represents the OP that should have been reported - also changing the details on the other OP).
Never tried it (and your actual cost cums will require adjustment) - but that might work.
Rob
To: Vantage Group <vantage@yahoogroups.com>
Sent: Monday, June 15, 2009 9:40:14 AM
Subject: [Vantage] Wrong operation.
Good Morning,
We have a situation when operators logged in for wrong operation. They made some pieces and put data into the system.
Also, we have some pieces accepted by inspection. Now , we are looking smart way to move everything from that operation to another or just remove pieces from that operation. Is any way to do that?
Thank you.
Bart.
Good Morning,
Thank you.
Bart.
Job Adjustment
Of Bartosz Niemczewski
Sent: Monday, June 15, 2009 9:40 AM
To: Vantage Group
Good Morning,
Thank you.
Bart.
