However, when I use the cdata example in Excel, it works beautifully, gives you a list of the available odata ‘tables’, you can pick one or more and work with it.
When I use the epicor url, I get an error of ‘an item with the same key has been added’. The only way i can pull in BAQ data is via the direct BAQ syntax of **https://epicorsi/ERP10/api/v1/BaqSvc/{BAQName}?
However, I need to pull multiple baq’s in, but without being able to get to the ‘catalog’ view (like the cdata example), it’s somewhat useless. I’m using 10.2.200
Am I doing something wrong or is there a bug? @Olga
Olga this comes from the Epicor SE image (Sales Engineer) (I’m a partner). Is there a way to filter on company in the URL syntax to avoid the duplicates? Is the duplicates possible to create or is this bugged data due to the long history of the SE Image database/
I’m trying to use a client’s Epicor SaaS Odata feed. I can see it in the browser fine.
If I use excel’s LEGACY Odata connection, it shows me the list of baq’s like a list of tables and i can select 1 or more and build Excel reports from that.
However, if I use Excel’s newer (power query) based “Get Data” functions, i get the following:
Details: “OData: Request failed (404): The remote server returned an error: (404) Not Found.”
I get the same problem in Power BI (Both use the same engine) and Power BI doesn’t support the Legacy odata driver that excel does (only after you expose it in the newest versions buried in options)
There appears to be something wrong with the way epicor (10.2.200 and 10.2.300) expose the list of BAQ’s or something that is not compatible with the way Microsoft expects to read odata. Microsoft is an Odata v4 compatible driver but I assume it’s backward compatible to Epicor’s older V3 implementation.
Has anyone been able to use Excel to see a list of baq’s and pull them into sheets?
I don’t think there is a built-in browser like that Mark. You could do a REST call that returns all BAQs (probably a long list, so you might want to filter it) and put that into a Combo Box.
The trickier part is once selected, I would do another REST call on that BAQ to get any required parameters and create labels and fields on the form.
Finally, I would call the BAQ through REST supplying the parameters and returning the results into a tab OR create an OData connection with the URL you made up.
So, not out of the box, but it is possible to write.
don’t assume backward compatibility. OData v3 and v4 are not compatible. Every Excel version works differently.
you can look into IIS log to see what exact query causes 404. Probably it will give more info about what went wrong.
