Words of Caution - OpenEdge 10.1b SP3
I should have said 10.1B305HF.exe for the 10.1B service pack 3.
Steve
From: Randy Vander Galien [mailto:rvandergalien@...]
Sent: February 07, 2008 1:55 PM
Subject: RE: [Vantage] Words of Caution - OpenEdge 10.1b SP3
Steve,
I was at the 10.0B SP5 level and had applied the sp100b532hf.exe hot fix
and had both 10.0b and 10.1b running concurrently. The fact that each
version of OpenEdge installs in its own directory makes my question how
a hot fix for 10.0b would have any effect on 10.1b. I am not typically a
skeptic but...
Regards
Randy Vander Galien
ACH Foam Technologies
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of vantage
Sent: Thursday, February 07, 2008 1:02 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Randy,
What I have found out is that OpenEdge hot fix 305 for service pack 3
has
part of the fix for this problem. Support has Security.r that will have
to
go with this that fixes the problem.
Steve
<mailto:rvandergalien%40achfoam.com> achfoam.com
<mailto:rvandergalien%40achfoam.com> ]
Sent: February 07, 2008 12:30 PM
Steve,
Interesting that support told you that it was fixed in 305. 305 was
still on Progress OpenEdge 10.0B.
I have not revisited the issue since my failed attempt and would be real
skeptical that it has been resolved.
Regards
Randy Vander Galien
Behalf
Of vantage
Sent: Thursday, February 07, 2008 8:46 AM
Randy,
Support has said that this was fixed on 305 hot patch, but I still see
the
problem on my data base. Have you received any more info from them on
this?
Steve
Sent: January 01, 2008 7:08 PM
Subject: [Vantage] Words of Caution - OpenEdge 10.1b SP3
For those who may be planning on applying OpenEdge 10.1 SP03 you may
want to consider holding off as there is a known bug. I ended up
reverting back to SP2 as it affected the ability to change menu
security. Support was very helpful in identifying the problem and
providing me with the resolution. The bug involves the Menu Security
control where the group names do not display properly in the UI. The bug
number is SCR 28162 with no defined fix date.
Regards
Randy Vander Galien
IT Manager
Regards
Randy Vander Galien
IT Manager
Randy,
Support has said that this was fixed on 305 hot patch, but I still see the
problem on my data base. Have you received any more info from them on this?
Steve
Regards
Randy Vander Galien
IT Manager
Steve,
Regards
Randy Vander Galien
Of vantage
Randy,
the
this?
Steve
Regards
Randy Vander Galien
IT Manager
Randy,
What I have found out is that OpenEdge hot fix 305 for service pack 3 has
part of the fix for this problem. Support has Security.r that will have to
Steve
Steve,
Regards
Randy Vander Galien
Behalf
Of vantage
Randy,
the
this?
Steve
Regards
Randy Vander Galien
IT Manager
Steve,
skeptic but...
Regards
Randy Vander Galien
Of vantage
Randy,
has
to
Steve
Steve,
Regards
Randy Vander Galien
Behalf
Of vantage
Randy,
the
this?
Steve
Regards
Randy Vander Galien
IT Manager
