Hi, I am new to the forum and new to Epicor. We have just implemented a couple of months ago. We have run COS/WIP capture as of March 31, 2018, but the WIP report as of 3-31-18 does not match the WIP balances on the general ledger. Does anyone have advice on where to begin reconciling the discrepancies?
Any general journal entries going through these accounts? Did you load starting WIP when you went live to jobs or did you just put in a journal entry. Any other adjustments you made via journal entry to your WIP accounts.
If you run Inv/WIP recon since you went live for your WIP accounts only, do those tie to the G/L? This would help you rule out the first point.
Do you see any other rouge transaction types going to that account that should not like a PO to other or inventory. Try running the inv/wip report for all transaction types less what you would think should go to WIP, e.g., remove PUR-MTL, ADJ-PUR, etc. Then also filter for your WIP G/L account and see if the report errors out. This will only help you with the inventory journal though.
