Sue
Sue
Sue
We run the capture process overnight, using the system agent to set it to run automatically. When we talked to Epicor I'm pretty sure they said this was the best practice. Another thing we found is that the posting rules are set automatically to detail, and it should take a little less time if they are set to summary. That's if you don't need to have each line item entered into the GL. We're on 701 also, but we were told this since we upgraded to 905 from 803. As far as what other areas to stay clear of while it's running, I'm not sure but I would think it would be anything that touches inventory. The only thing Epicor said when we had trouble was to make sure MRP wasn't running at the same time. (Our problem that time turned out to be some BPMs that were slowing things down.)
I hope this helps!
Sue
Did you have a BPM running that might affect the Capture?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of snielsen.hipco@...
Sent: Monday, May 05, 2014 11:18 AM
Subject: [Vantage] Re: WIP capture and record locking
Thanks! I placed a call with Epicor first thing Friday morning, but haven't heard anything yet. I'm hoping to get enough verification that I can get backing from management to stop the practice of running WIP capture during work hours. I found the setting about detail and summary when capturing WIP and gave the info to the controller in February. He was supposed to talk to an E9 financial consultant about the settings after we got books closed for the year and hasn't done it yet. I reminded him about that last week. I really appreciate your reply, I was beginning to wonder if I was wrong to ask that it be run after hours.
Sue
Sue
We’re on 905.702A. We had originally intended to schedule the Capture process to run at night, once a week. However, we never scheduled it and I prefer to keep it that way. I run the Inventory WIP Reconciliation Report for a week’s worth of data. After I’m satisfied there’s nothing to fix (posting to non-existent GL Accounts or wrong GL accounts, usually), I run the Capture process for the same time period. I run it during the day, but haven’t heard it causing any issues. It does take awhile, but not 2 hours.
Bill Kingsley
Controller
Compulink Corp.
ComDesign Inc.
Voice (727) 578-6503
Fax (727) 578-0120
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
