I am running Vantage 8.03.404B with SQL Server 2005 on a Windows Server 2008
Std. I prpbably would not have gone this route if I had known about it not
being certified yet, but our Sales person said that is. I didn't find out
until the Epicor install Tech was 10 minutes into the install and asked why
my desktop looked the way it did. Luckily, the Epicor Tech went ahead and
installed it. It has worked flawlessly since. I have zero issues with it.
Basically, WS2008 is a supercharged version of Windows Vista, as long as you
are familiar with the differences between Windows XP and Windows Vista you
should be fine. I have even begun preliminary testing running Vantage using
Terminal Server 2008's Remote Application feature, and it has worked
perfectly so far.
perfectly so far.
On Thu, Jun 12, 2008 at 4:39 PM, RSN <rsnsfi@...> wrote:
> Are there any users on the forum who may have tried testing or are
> currently using Vantage 8.03.404 with an OpenEdge installation on a Windows
> Server 2008 O/S?
> Epicor indicates that OpenEdge has not certified Progress to run on Server
> 2008 so they will not support it.
> I wanted to check.
> Thanks in advance
> RSN
