Why does this BAQ not produce records?
Your field joins between tables is incorrect then.
--- On Mon, 8/4/08, Tony Hughes <thughes281@...> wrote:
Subject: Re: [Vantage] why does this BAQ not produce records?
Date: Monday, August 4, 2008, 2:11 PM
I tried yes/no, that is accepted when you "Analyze"
I also did integer, 0/1 but this is not accepted by BAQ when you "Analyze", datatype mismatch error
Strangely, I actually reduced the query to just: for each TFOrdDtl no-lock .
and still no results...
----- Original Message ----
To: vantage@yahoogroups .com
Sent: Monday, August 4, 2008 1:02:20 PM
Try using 'yes/no' or '1/0' for your boolena test( .Shipped)
--- On Mon, 8/4/08, Tony Hughes <thughes281@ yahoo. com> wrote:
Subject: [Vantage] why does this BAQ not produce records?
Date: Monday, August 4, 2008, 1:57 PM
I made a BAQ with this:
for each TFOrdDtl where ( TFOrdDtl.Shipped = TRUE AND TFOrdDtl.ReceivedQt y < TFOrdDtl.OurStockSh ippedQty) no-lock by TFOrdDtl.TFOrdNum.
Analyze says "syntax OK", but a test produces no results.
If I run the same thing on my SQL server, I get hundreds of results (select * from tforddtl where Shipped = 1 AND (TFOrdDtl.ReceivedQ ty < TFOrdDtl.OurStockSh ippedQty) )
is there something wrong with my BAQ query?
Thank you,
Anthony Hughes
ERP Manager
Logan Oil Tools, Inc.
Houston, Texas
for each TFOrdDtl where ( TFOrdDtl.Shipped = TRUE AND TFOrdDtl.ReceivedQty < TFOrdDtl.OurStockShippedQty) no-lock by TFOrdDtl.TFOrdNum.
If I run the same thing on my SQL server, I get hundreds of results (select * from tforddtl where Shipped = 1 AND (TFOrdDtl.ReceivedQty < TFOrdDtl.OurStockShippedQty) )
Thank you,
Anthony Hughes
ERP Manager
Houston, Texas
Thank you,
Anthony Hughes
ERP Manager
Houston, Texas
Thank you,
Anthony Hughes
ERP Manager
Houston, Texas
I found it, it was my syntax error in the Calc field I made.
I did not put table name in front of the fields
I had a calc field with ourstockshippedqty - receivedqty but has to have table names (even when there's just the one table)
should be: tforddtl.ourstockshippedqty - tforddtl.receivedqty as intransit
Thanks for your help
Sent: Monday, August 4, 2008 1:11:51 PM
Thank you,
Anthony Hughes
ERP Manager
Houston, Texas
