I hear you brother!
Rob
Rob
--- On Mon, 4/6/09, Rob Bucek <rbucek@...> wrote:
Subject: RE: [Vantage] why do i get this error....
Date: Monday, April 6, 2009, 6:23 PM
Never mind, I'm a bone head, *#%*!! typos..... sometimes a guy gets
cross eyed typing and reading this code..
Rob Bucek
Manufacturing Engineer
PH: ext 311
FAX:
<http://www.dsmfg com/>
(Click the logo to view our site)
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Rob Bucek
Sent: Monday, April 06, 2009 4:58 PM
To: vantage@yahoogroups .com
Subject: [Vantage] why do i get this error....
Working in the Receiving entry form I am attempting to search for a UD
record, if I do not find the record I want to create a new record. I
have only gotten as far as coding for the creating a new record but when
I save the receipt the I get the following error;
Error Detail
Object reference not set to an instance of an object.
Stack Trace
at Script.GetNewUDReco rd()
at Script.UDrecord( )
at Script.oTrans_ receiptAdapter_ AfterAdapterMeth od(Object sender,
AfterAdapterMethodA rgs args)
at Epicor.Mfg.UI. FrameWork. EpiBaseAdapter. OnAfterAdapterMe thod(String
MethodName)
at Epicor.Mfg.UI. Adapters. ReceiptAdapter. CheckDtlBeforeUp date(Int32
vendorNum, String purPoint, Int32 packLine, String packSlip, String&
qMessageStr, String& sMessageStr)
here is my customization (I got a lot of 'stuff' goin on):
Private Sub RcvDtl_AfterFieldCh ange(ByVal sender As object,
ByVal args As DataColumnChangeEve ntArgs) Handles
RcvDtl_Column. ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldNam e]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column. ColumnName
Case "VendorQty"
Dim strIUM As String =
edvRcvDtl.DataView( edvRcvDtl. Row)("IUM" )
If strIUM = "SF" Then
Dim edvPart As EpiDataView =
CType(oTrans. EpiDataViews( "Part"), EpiDataView)
Dim edvRcvDtl As EpiDataView =
CType(oTrans. EpiDataViews( "RcvDtl") , EpiDataView)
Dim nbrtags As EpiNumericEditor =
ctype(csm.GetNative ControlReference ("ef040ebc- 3f52-48c7- b199-a73d86679ca
4"),EpiNumericEdito r)
Dim nbrSF As EpiNumericEditor =
ctype(csm.GetNative ControlReference ("449261b6- 618c-4b02- 8b7e-937a9728d8f
d"),EpiNumericEdito r)
Dim nbrArea As Decimal =
edvPart.DataView( edvPart.Row) ("Number01" )
Dim nbrTag As Decimal =
edvRcvDtl.DataView( edvRcvDtl. Row)("Number02" )
Dim nbrQty As Integer =
edvRcvDtl.dataView( edvRcvDtl. Row)("OurQty" )
Dim nbr01 As Decimal =
edvRcvDtl.dataView( edvRcvDtl. Row)("Number01" )
edvRcvDtl.DataView( edvRcvDtl. Row)("Number02" ) = nbrTag
If nbrArea <> 0 Then
'messagebox. show("no part area")
'messagebox. show(nbrarea)
edvRcvDtl.DataView( edvRcvDtl. Row)("Number01" ) =
FormatNumber( nbrQty/nbrArea, 0)
Else
If nbrTag <> 0 Then
'messagebox. show("no part area & area entered within no.01")
'messagebox. show(nbrSF. value)
FormatNumber( nbrQty/nbrSF. value,0)
Else
messagebox.show( "Please click the save button and then enter
the square foot value for plate size and recheck the Print Labels Check
box.")
chkPrint.Checked = False
'messagebox. show("Please enter Total Square Feet for one
sheet or plate")
nbrSF.focus
End If
End If
End IF
Case "ShortChar01"
Dim Carbon As String = InputBox("Enter carbon content of
Heat Number", "Carbon Content")
'MsgBox("Your Input is " & Carbon)
edvRcvDtl.DataView( edvRcvDtl. Row)("ShortChar0 2") = Carbon
Case Else
End Select
End Sub
Private Sub oTrans_receiptAdapt er_AfterAdapterM ethod(ByVal
sender As object, ByVal args As AfterAdapterMethodA rgs) Handles
oTrans_receiptAdapt er.AfterAdapterM ethod
'// args.MethodName
'MessageBox. Show(args. MethodName) ' use this to
find method
Select Case args.MethodName
Case "CheckDtlBeforeUpda te"
'messagebox. show(strIUM)
Dim nbrQty As Decimal =
UDrecord()
Else
If nbrTag <> 0 Then
edvRcvDtl.DataView( edvRcvDtl. Row)("Number01" )=
UDrecord()
Else
box.")
sheet or plate")
nbrSF.focus
End If
End If
End IF
Case Else
End Select
End Sub
Sub UDrecord ()
Dim recSelected As Boolean
Dim strHt As String =
Dim whereClause As String = "Key1 = '" + strHt + "'"
Dim dsUD06 As DataSet
dsUD06 =
Epicor.Mfg.UI. FormFunctions. SearchFunctions. listLookup( oTrans,
"UD06Adapter" , recSelected, False, whereClause)
If (recSelected) Then
adaptUD06.GetByID( dsUD06.Tables( 0).Rows(0) ("strHt") ,"","","" ,"")
End If
GetNewUDRecord ()
End Sub
Sub GetNewUDRecord ()
messagebox.show ("get new record")
Dim strVen As String =
edvRcvDtl.dataView( edvRcvDtl. Row)("VendorNumN ame")
Dim dteRec As Date =
edvRcvDtl.dataView( edvRcvDtl. Row)("ReceiptDat e")
Dim strPO As String = edvRcvDtl.dataView( edvRcvDtl. Row)("PONum" )
Dim strPart As String =
edvRcvDtl.dataView( edvRcvDtl. Row)("PartNum" )
Dim strHeat As String =
edvRcvDtl.dataView( edvRcvDtl. Row)("ShortChar0 1")
Dim strCarbon As String =
edvRcvDtl.dataView( edvRcvDtl. Row)("ShortChar0 2")
messagebox.show( strCarbon)
Dim adpaptUD06 As UD06Adapter = New
UD06Adapter( ReceiptEntryForm )
adaptUD06.BOConnect ()
adaptUD06.GetaNewUD 06()
adaptUD06.UD06Data. Tables("UD06" ).Rows(0) .BeginEdit( )
adaptUD06.UD06Data. UD06(0)(" Key1" ) = strHeat
adaptUD06.UD06Data. UD06(0)(" Character01" ) = strVen
adaptUD06.UD06Data. Tables("UD06" ).Rows(0) .EndEdit( )
adaptUD06.Update( )
adaptUD06.dispose( )
End Sub
End Module
Rob Bucek
PH: ext 311
FAX:
<http://www.dsmfg com/ <http://www.dsmfg com/> >
