I am going to do the upgrade from V8 to E10, can anybody provide the patch of 409c? thanks so much in advance. It seems can’t be found in EpicWeb.
It is the file - PA803409C-s.exe. Did anyone ever download it ? thanks.
Does the client not have active maintenance on their V8? If not than E10 must be a “new install”. I’d like to think Epicor would help out their customer in making the transition from some “other” ERP system.
What you are going to attempt is very difficult. I strongly suggest you talk with your CAM about our Cirrus Upgrade program. That will be a mucher easier approach and more cost effective. Trying this on your own will most likely not turn out well.
