What is the Report ID for Count Cycle Maintenance?
I am new to Epicor and I am trying to make a modification to a report style, however I don’t know which it is. Can someone please direct me to the appropriate one?
Thanks!
Hello and welcome! I think the report styles you are looking for begin with “CC”. Good luck!
Hey I appreciate that, I did try that search earlier, but there is nothing that eludes to the fact that it is connected to the Report ID I am searching for.
Cycle Count Maintenance is a form, not a report. Is there a part of the cycle count form that produces a report that you are trying to edit?
Right, what I am look for the is the report ID for when you choose to print the report. I need to make some adjustments because longer text gets cut off.
When you go to actions to print the report, which report are you printing?
The standard report style
I think I just figured it out… I believe it was the Count Variance Report…
To print a report from Cycle Count Maintenance, you click Actions, then what next? There are lots of reports (all pointing to different styles) available from the actions menu.
Great! That is the “CntVar” Report ID.
