What determines Job Assembly Order?
What determines Job Assembly order?
I noticed that Job Entry and Job Tracker sometimes don’t match. And they aren’t in order…
The Erp.JobAsmbl table has the parent/child/peer relationships specified. Assuming the Entry and Tracker screens are using those table correctly, it looks like there might be a little bug in the data or that tree view not sorting correctly (because of a customization or personalization thing?)
The structure / hierarchy is correct. Just the order is inconsistent. Issue is present in base form without personalizing the tree lines.
I would open a support ticket and see what they say/
They will tell you to clear the cache and reset layouts to base
