I am in the Mass Issue to Mfg screen and am trying to create a Button Click event to auto print the Job Traveler. I manually added the references (Erp.Contracts.Rpt.JobTrav and Erp.UIRpt.JobTrav) using the Assembly Reference Manager and I keep on getting this compile error. Not sure what I am missing.
Error: CS0246 - line 58 (240) - The type or namespace name ‘JobTravAdapter’ could not be found (are you missing a using directive or an assembly reference?)
// Custom code for MassIssueForm
// Created: 4/2/2021 7:04:03 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
this.epiBttn_PrintTrav.Click += new System.EventHandler(this.epiBttn_PrintTrav_Click);
this.epiBttn_PrintTrav.Click -= new System.EventHandler(this.epiBttn_PrintTrav_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void epiBttn_PrintTrav_Click(object sender, System.EventArgs args)
JobTravAdapter jt = new JobTravAdapter(oTrans);
Not an answer to your question (sorry!), but you might consider using Context Menu Maintenance to add the Job Traveler print screen to the list of menus available when right-clicking → Open With:
The Job Traveler print screen would load with your job already filtered.
It’s a few more clicks than what it sounds like you might be going for, but if you can sell it as a workable solution it will make your life much much easier… I have been down the road of trying to launch a report from customizations and it has never gone well for me. Also, with Kinetic on the horizon we should try to shy away from creating new customizations like this when possible…
A BPM handling auto print could be another option too - maybe it is triggered when the user issues material.
Taking a second look at this, I don’t even think you need to reference any Job Traveler assemblies. The one time I added a custom button to launch another form, I used the ProcessCaller.LaunchForm method. The code on Mass Issue should look, more or less, like this.
This was, however, a button to launch a UD form from a stock form. To @TomAlexander 's point, I’m not sure I’d go that route for something like this. I might look at a BPM. Then again, after looking at Kinetic, I’m staying away from it for the next year so I might go the form button route again.
@jtownsend you are right, there was nothing else needed. I don’t know if it is a bug or something, but it is working fine today. Friday it would not compile and the odd thing was that the references were completely in lower case. Today it compiles fine and is in the correct case. Might be one of those things where you need to completely close out and go back into.
