Weird error posting cash receipts
I have two users that can’t post cash receipts or run inv/wip reconciliation. Here is the error message. Has anyone seen anything like this?
Epicor10: An error occurred trying to run task ID 532 for agent SystemAgent on the application server (User: richarln, Task Description: Cash Receipt Post).
Error Detail:
An error occurred while updating the entries. See the inner exception for details.
Stack Trace:
at System.Data.Mapping.Update.Internal.UpdateTranslator.Update(IEntityStateManager stateManager, IEntityAdapter adapter)
at System.Data.Objects.ObjectContext.SaveChanges(SaveOptions options)
at Ice.IceDataContext.SaveChanges(SaveOptions options) in C:_Releases\ICE\3.1.500.12\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 328
at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in C:_Releases\ICE\3.1.500.12\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 295
at Ice.Security.UserActivityLog.LogonFailedLog(String companyID, String userID, String message) in C:_Releases\ICE\3.1.500.12\Source\Framework\Epicor.Ice\Security\UserActivityLog.cs:line 73
at Ice.Manager.Security.LogOn(IceContext dataContext, String userID, Guid sessionType) in C:_Releases\ICE\3.1.500.12\Source\Framework\Epicor.Ice\Manager\Security.cs:line 506
at Epicor.Hosting.CallContext.Create(Operation op) in C:_Releases\ICE\3.1.500.12\Source\Framework\Epicor.Ice\Hosting\CallContext.cs:line 178
at Ice.Security.AuthorizationManager.CheckAccess(OperationContext operationContext, Message& message) in C:_Releases\ICE\3.1.500.12\Source\Framework\Epicor.Ice\Security\AuthorizationManager.cs:line 75
at System.ServiceModel.Dispatcher.AuthorizationBehavior.Authorize(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Inner Trace:
String or binary data would be truncated.
The statement has been terminated.
: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
Hi Matt, this seesm to be quite old, but I´m just having the same behavior and was wondering how did you solve this.
I unchecked require single sign-on from the affected users. I can still point them to a single sign-on enabled app server, which works fine with that box unchecked.
Rubén Corral Yruretagoyena via Epicor Help Forum — [EXT] [Epicor Help Forum] [E10] Weird error posting cash receipts —
“Rubén Corral Yruretagoyena via Epicor Help Forum” forum@epiusers.help
To:
bradleym@keystonesteel.com
Date:
Fri, Jan 25, 2019 5:38 PM
Subject:
