Web MES App Studio Layer
I have created a new layer for the web MES production layer. I have saved it and published. Now how do I have only Web MES point to this new layer?
I should clarify it’s for the data collection piece.
You can turn on the MES customization in Menu Maintenance.
If you’re using the Kinetic web version of Menu Maintenance, you can select “Process” on the main landing page.
Turn your filters on, and then type “MES” into the name filter.
If you haven’t previously, you’ll have to copy the Menu to Current Company (in overflow menu).
Module may default to “UD” once you copy it, if not, set it to “UD”.
Program Type: Kinetic App
You can search for your customized layer in the “Kinetic Customization” search.
Save. Test.
Thanks!
