Hello All,
We’re looking to track small changes on Part revisions and we thought that doing an “Engineering Rev” field would be a good way to do so. The idea is that we don’t want to create a whole new revision if we just change out a screw for example but we still want to see those changes. I thought that we would be able to create a few custom fields on PartRev_UD, Eng Rev, ECN, and Eng Rev effective date on Part Rev sheet with ECN being a unique identifier. When we go from Part - Rev - EngRev we want to see each change. For example if we went from XXXXA1 to XXXXA2 we want to be able to see that. Currently when I change from 1 to 2, 2 just saves over the current row because I can’t assign ECN field as a unique identifier. Is there a way to set a custom field as a unique identifier? I also thought about using a UD table for this however I can’t seem to bind fields from the UD table to the Part Rev sheet.
