VNC is a great option. www.tightvnc.com I use this extensively at work.
One of the things that you might want to do is set up a linux box on both
ends with ssh running on the machine. That way you can securely connect to
your computer at work. I use a combination of cigwin on the windows machine
and sshd on the linux box. You can read more about this setup here:
http://www.uk.research.att.com/archive/vnc/sshvnc.html
Good luck!
Michael
Sent: Wednesday, October 08, 2003 3:52 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] VPN office to office
I use WinVNC for this exact reason. I have T1 at work and cable at home.
With the WinVNC client on both ends I can log into either machine from the
other. The only trick is with my cable, I need to make sure I know my
current IP at home to connect to. With this you select a port to connect
through and a password. Using the port and instance (winvnc.exe) I set a
rule in the firewall to allow traffic for this program. Works great for
work that I did at home and left there, or vice versa.
Jim MacMillan
IT Manager
AR Manager
Synergy Manufacturing
303-790-9200
Sent: Wednesday, October 08, 2003 2:18 PM
Subject: [Vantage] VPN office to office
I've got a new one for me.
Location # 1 - Owner's home with Cable Internet link using Linksys
router/switch/firewall
Location # 2 - Business using DSL Internet link using Linksys
Goal: Use PcAnywhere or a clone to link up PC at home to PC in the office
for remote control.
Does anyone know how to do this ?
Todd Anderson
Good luck!
Michael
Jim MacMillan
IT Manager
AR Manager
303-790-9200
for remote control.
Todd Anderson
