Worked Great!!!
THanks,
Jasper
Sent: Wednesday, November 05, 2003 11:21 AM
Subject: RE: [Vantage] Visual Basic - Progress question
Basically copy the VTG file information into a long format. There are piles
more of parameters, but if you use the ones Epicor has decided to use in
their VTG setup, you shouldn't have any problems.
Example:
in Visual Basic, set a string equal to the following line (change any
settings to match your server and Vantage install):
F:\PROGRESS\bin\prowin32.exe F:\VANTAGE\db\vantage.db -ininame
F:\VANTAGE\vantage.ini -pf F:\VANTAGE\db\Vantage.pf -N TCP -H ntserver -S
vantage -ld vantage -p yourapp.p -rand 2 -q -basekey ini
Then just
x = shell string
Sent: Wednesday, November 05, 2003 9:52 AM
What parameters/identifiers do I need?
Can you give me an example of the long hand method?
Jasper
Sent: Wednesday, November 05, 2003 10:42 AM
You're not using the correct parameters/identifiers for prowin32.exe.
no identifier for the DataBase (this is what your program thinks you are
suppling it)
to load a procedure (.p, .w or .r) you need to specify it. Add a "-p "
before your procedure name.
Just a suggestion, I usually configure the entire long hand command line
before shelling it out. This way I know I'm using the correct database, INI
settings file, parameter file, etc....
Sent: Wednesday, November 05, 2003 9:31 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Visual Basic - Progress question
I'm not sure if anybody has every come across this problem but I'll give it
a go.
I am using Visual Basic to execute a procedure. When you click on the
button, it's supposed to run this program and automatically run the
VendorShipping.p procedure:
Dim Path As Object
Dim Report As Object
Path = "d:\ReportBuilder\VendorShipping.p"
Report = Shell("""V:\PROGRESS\bin\prowin32.exe"" """ & Path & """", 1)
When it tries to run I get this error:
Error
**Your database name is longer than 11 characters.(448)
If I run the procedure without going thru Visual Basic it works great, but
when Visual Basic tries to execute it I get that error.
Any ideas on what this might be?
Jasper
THanks,
Jasper
Example:
Then just
x = shell string
Jasper
suppling it)
a go.
Dim Path As Object
Error
Jasper
