Hi Chris,
I am re-running the conversion again, and depending on the results, I will go ahead with your suggestion right after and let you know if has worked for me.
Daniel Dell'Aquila
---In vantage@yahoogroups.com, <cwineinger@...> wrote :
#ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801
filtered #ygrps-yiv-1006798512ygrps-yiv-1407599801 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
#ygrps-yiv-1006798512 filtered #ygrps-yiv-1006798512ygrps-yiv-1407599801 {font-family:Pristina;panose-1:3 6 4 2 4 4 6 8 2 4;}
#ygrps-yiv-1006798512ygrps-yiv-1407599801 p.ygrps-yiv-1006798512ygrps-yiv-1407599801MsoNormal, #ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 li.ygrps-yiv-1006798512ygrps-yiv-1407599801MsoNormal, #ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 div.ygrps-yiv-1006798512ygrps-yiv-1407599801MsoNormal
{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
#ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 a:link, #ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 span.ygrps-yiv-1006798512ygrps-yiv-1407599801MsoHyperlink
{color:blue;text-decoration:underline;}
#ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 a:visited, #ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 span.ygrps-yiv-1006798512ygrps-yiv-1407599801MsoHyperlinkFollowed
{color:purple;text-decoration:underline;}
#ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 span.ygrps-yiv-1006798512ygrps-yiv-1407599801EmailStyle17
{font-family:"Calibri", "sans-serif";color:windowtext;}
#ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 .ygrps-yiv-1006798512ygrps-yiv-1407599801MsoChpDefault
{font-family:"Calibri", "sans-serif";}
#ygrps-yiv-1006798512 filtered #ygrps-yiv-1006798512ygrps-yiv-1407599801 {margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1006798512 #ygrps-yiv-1006798512ygrps-yiv-1407599801 div.ygrps-yiv-1006798512ygrps-yiv-1407599801WordSection1
Uninstall Admin console including the files in the c:\program files\common files\Epicor Software Corporation\Admin console
Then reinstall. You might have to redo the migration. I had to do mine 6x until it was there.
Epicor has an SCR and the admin console is going away or changing in 10.1 to something Java based.
Regards,
Chris Wineinger
ERP Specialist
Interior Systems, Inc.
241 N Broadway Ste 600
Milwaukee, WI 53202
Office # 414.224.0957 X2051
Direct# 414.847.0701
Cell # 414.840.6594
IT related problem? Contact
helpdesk@...
