Conversion went very well. It took about 12 hours total. We converted from
3.0 to 4.0 to 5.0.
Now it is just a matter of finding things.
Make sure that if you are converting you absolutely need to add the current
patch. If you don't there will be many problems, specifically with data
colleciton for Job entry and with purchasing for approvals.
Thank goodness for support. I was on the phone probably 5 times yesterday,
but they were very helpful.
So far the only major problem seems to be in data collection. The employees
cannot determine the exact time they clocked in. We can only see a portion
of the clock in time. The screen needs to be readjusted. You can only read
the hour and a little bit of the minute portion.
But so far so good.
Sent: Tuesday, January 09, 2001 7:16 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Version 5.0
So how did the conversion go? Well I hope.
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
Winnipeg, MB R3H 0C4
http://www.neon-products.com/
mailto:rnewell@...
Sent: Friday, January 05, 2001 4:40 PM
We are converting this weekend from 3.0 to 5.0. Wish us luck
3.0 to 4.0 to 5.0.
But so far so good.
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
mailto:rnewell@...
