So I do not know if what you mentioned, Jose, was actually the case, but what I did do to get the actual report to work was not age the report as of today (which we tend to do), I aged it for a date into the future and all of the invoices came through.
I will definitely go through our customer terms set up and make sure it is correct.
Thanks to all of those that gave me suggestions!
M
Sent: Tuesday, July 28, 2015 6:26 PM
Subject: [Vantage] RE: version 10.700.3 - AR Aging does not show all invoices
Do a BAQ and look at the invcHead table and look at one of the invoices not showing up and look at the fields PayDates,Payamounts and DocPayAmounts. You might find you’re missing data in one of those fields which the report uses to display data. For example, you might have 2 paydates but 3 payamounts which are separated by a ~. When I went live with E10 I had about 5 invoices that didn’t show up and it was because of this.
Below is a sample of a correctly formatted records..
Sent: Monday, July 27, 2015 11:32 AM
So upon further investigation on this, I did find two customers on an open invoice report I created that is not on the aging report. What makes these two customers interesting is that if I go to customer tracker and go to aging there…the invoices do not exist. But if I go to the open Invoice tab, they are there.
What would cause this out of sync business? Is there a conversion to run?
M
Sent: Monday, July 27, 2015 12:27 PM
Scratched my head a bunch on this with 700.4. Then noticed that there is a radio button selection for how it does aging (relative to what date to start). If set one way it will ignore invoices before a certain date (1st of month?). Normal USA mode is to age from the date of the invoice but other countries (I ran into this for Australia) age from the 1st of the month following the date of the invoice so don’t show those. I can’t recall what the setting are but they are on the aging report settings screen.
-Todd C.
Sent: Monday, July 27, 2015 11:04 AM
Subject: [Vantage] version 10.700.3 - AR Aging does not show all invoices
Has anyone experienced this before? According to tech support I have to give access to a BAQ…that in itself seems very weird to me. Con someone confirm, please?
TIA, Manasa
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
