General Question: If we are needing to change the Vendor price in Epicor for all open Po’s, what is the best way to do this? If you are doing this or have done this, What process/methods are you using to do this?
I would do some combination of BAQ and DMT to accomplish this. There is an override price list check box that would need checked and then unchecked if the price list has been loaded into epicor.
IF it has not been loaded then I would load it first.
Could it be done via Updatable dashboard?
