VB.NET customization - nudge needed
Bernie,
I am a sponge... any examples would be appreciated. Always helps with
learning new concepts.
I am still hoping to launch my own VB window as it may be something
that I would like to use from more than one module - I don't like
tying it down to a particular tab/panel of a module.
Bill
--- In vantage@yahoogroups.com, Bernie Walker <bwalker@...> wrote:
> What I have done, to make a custom application within Vantage, is to
use one of the UD Entry forms and hide all the base fields then add
all of my own fields, call the adapters I need and do whatever. The
downside is the standard menu buttons are still there but remain tied
to the base form adapters. I could send you an example if you would
like....
> Bernie
> -----Original Message-----
Behalf Of hoomail4me
> Sent: Friday, September 21, 2007 4:43 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: VB.NET customization - nudge needed
> I knew that it was possible to launch a ".exe" and there is an
example in the customization help but I didn't see how to launch a VB
application that I could use input-output parameters. Not just launch
a application.
> I have searched the help and couldn't find a good example of a
method to create a VB window (maybe it cannot be done). I didn't want
to limited to a panel. Maybe I am expecting too much.
> Bill
> --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > You definitely add panels (tabs) and collect your information, bind to
> > fields within data views and update.
> > You can launch darn near any application via .net code
> > Searching the help can reveal many code examples too.
> > Any external apps that connect to Vantage will consume a license, so
> > it is probably best to try and do what you need through customization
> > of exisitng forms.....
> > --- In vantage@yahoogroups.com, "hoomail4me" <hoomail4me@> wrote:
> > > I am new to V8.03 customization and limited VB.NET experience - some
> > > VB 6 coding experience, quit a bit of 4GL experience.
> > > Can anyone supply some sample code to help me get started with V8
> > > customization and VB.NET. I need a nudge to get me started. Once I
> > > see an example, I can hopefully get a better understanding of the
> > > proper way to communicate between V8 and .NET.
> > > What I really would like to see is how (if it can be done) a new VB
> > > form can be launched from within V8. This form would have input
> > > fields to collect additional data and return that data to one or
> > more
> > > V8 UI field/object.
> > > Also, can a VB.NET application be launched from within V8?
> > > Any takers to the experts out there... Nothing fancy...
> > > Thanks in advance...
> > > Bill
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
fields to collect additional data and return that data to one or more
V8 UI field/object.
Bill
to fields within data views and update.
more
> V8 UI field/object.
> Bill
I knew that it was possible to launch a ".exe" and there is an example
a application.
I have searched the help and couldn't find a good example of a method
to create a VB window (maybe it cannot be done). I didn't want to
Bill
> more
> > V8 UI field/object.
> > Bill
What I have done, to make a custom application within Vantage, is to use one of the UD Entry forms and hide all the base fields then add all of my own fields, call the adapters I need and do whatever. The downside is the standard menu buttons are still there but remain tied to the base form adapters. I could send you an example if you would like....
Bernie
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of hoomail4me
I knew that it was possible to launch a ".exe" and there is an example in the customization help but I didn't see how to launch a VB application that I could use input-output parameters. Not just launch a application.
I have searched the help and couldn't find a good example of a method to create a VB window (maybe it cannot be done). I didn't want to limited to a panel. Maybe I am expecting too much.
Bill
> more
> > V8 UI field/object.
> > Bill
Yahoo! Groups Links
