Thanks so much Wayne. I knew I was forgetting something, as soon as I read
it I remembered!
Judy
Message: 8
Date: Wed, 20 Feb 2002 19:34:44 -0500
Subject: Re: VB forms in packing slip
At 05:11 PM 2/20/2002 -0600, you wrote:
into its properties, there should be a blank titled "external name" or
something similar. Fill that in with a name appropriate to the data you're
storing. Run a print preview of the form to regenerate the .DBF files in
\VntgWork Then in Crystal, open your form and run the menu item Database
-> Verify Database The VB form field should show up in Crystal now.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
it I remembered!
Judy
Message: 8
> Please tell me I am missing something. Is there a way to get theIn the VB Form configuration screen, when you double click on a field to go
>information from a VB form in the packing slip onto the Crystal packing
>slip? I don't see the field available in Crystal, could this be true?
-Wayne Cox
828-685-2338
