Vb form
Hi Troy,
I check in my program .w, if my program is set to run "on entry"
or "on ok" in the frame attributes window. Where is the "on entry" or
"on ok" in the frame ? I don't know ! Thanks !!
Nancy
Sent: Friday, June 28, 2002 9:30 AM
To: 'vantage@yahoogroups.com'
Subject: Re: [Vantage] VB FORM
Nancy,
Try explicitly stating the path in your 'runprog' command like this:
runprog v:\vantage\vbp\myprog.w Also, is the program set to run "ON
ENTRY" or "ON OK" in the frame attributes window?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, June 28, 2002 9:20 AM
Subject: RE: [Vantage] VB FORM
I Place my program in v:\vantage\vbp\myprog.w. When I click on the
buttons, doesn't works. My screen not appear.
Sent: Wednesday, June 26, 2002 4:24 PM
Nancy,
What is the error message you are getting? It may be that your
'myprog.w' is not in the correct path. Try placing a copy of it in
the
vantage folder as well as the vantage\vbp folder.
Troy Funte
Liberty Electronics
Sent: Tuesday, June 25, 2002 11:32 AM
Subject: [Vantage] VB FORM
Hi,
My problem is: when I create a VB FORM, if I can insert a
buttons and in my buttons I can insert a command. If in my command
I
insert this command : RUNPROG myprog.w, if possible. Because I make
a test, but doesn't works.
Thanks for help !
Nancy
Yahoo! Groups Sponsor
ADVERTISEMENT
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
have already linked your email address to a yahoo id to enable access.
(1) To access the Files Section of our Yahoo!Group for Report
Builder
http://docs.yahoo.com/info/terms/
Hi,
buttons and in my buttons I can insert a command. If in my command I
Thanks for help !
Nancy
Nancy,
What is the error message you are getting? It may be that your 'myprog.w' is not in the correct path. Try placing a copy of it in the vantage folder as well as the vantage\vbp folder.
Troy Funte
Liberty Electronics
Hi,
Thanks for help !
Nancy
ADVERTISEMENT
Nancy,
Troy Funte
Liberty Electronics
Hi,
Thanks for help !
Nancy
ADVERTISEMENT
Nancy,
Try explicitly stating the path in your 'runprog' command like this: runprog v:\vantage\vbp\myprog.w
Also, is the program set to run "ON ENTRY" or "ON OK" in the frame attributes window?
Troy Funte
Liberty Electronics
Nancy,
Troy Funte
Liberty Electronics
Hi,
Thanks for help !
Nancy
ADVERTISEMENT
I've been working on the same general thing, (with much help from the
group) the effort got lost in the heat of battle, so I'm glad you're
revisiting the topic. (I want to create a report that will give me the
state of the part at the push of a button) IE: current/last orders,
current/last shipments, on hand, etc etc.) Kind of a part dossier at a
given moment. I had the same difficulties as you, but never completely
followed through with it.
Shirley
Nancy,
Troy Funte
Liberty Electronics
Hi,
Thanks for help !
Nancy
ADVERTISEMENT
