Wow, thanks Wayne, that will be a great help for us.
Guess I better read my help a little bit better.
~Thaddeus
Sent: Monday, May 21, 2001 8:56 AM
Subject: RE: [Vantage] VB Form and Crystal Reports
At 09:50 AM 5/21/2001 , you wrote:
length higher. I just checked the help, and it says it will go clear to
256 chars. There's also a editor window, with multiple lines and scroll
bars that's a little nicer than the single box for comments and other long
text
-Wayne Cox
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
~Thaddeus
>is less than optimal with the vantage basic fields is that you are limitedYou can make them longer. Just go into the field's format and set the
>to like 8 or ten characters per string field, so these internal notes will
>need to be somewhat abbreviated.
text
-Wayne Cox
