Todd,
What I did was create a VB form in order entry with check boxes for
different quality requirements. Long Form Certification, Short Form
Certification, Source Inspection, & etc.
I created a sub report to display the Boolean check box results formatted as
Y/N. So that this information shows on the order acknowledgement.
Wayne
Sent: Tuesday, May 18, 2004 9:51 AM
Subject: RE: [Vantage] VB field in Crystal
Just took a look at the help to refresh my memory. The UD aprt was for
something else. Here is text from help:
The External Name is the name of this field when it is exported to a .DBF
file for use in Crystal reports. The two letter prefix for the external name
is predefined: this identifies the data table with which the form is
associated. The external name can be no longer than eight characters.
Wayne - Why the subreport? I've used many VB Form fields without needing
one. But not a logical type field (check box) that I can recall, is it due
to that type that a subreport is needed?
-Todd C.
Yahoo! Groups Links
Wayne
-Todd C.
Yahoo! Groups Links
