Beautiful, works like a charm. Thanks.
Of Stephen Edginton
Sent: Tuesday, January 29, 2008 10:39 AM
Subject: RE: [Vantage] VB Code to Save?
oTrans.Update()
Behalf
Of Ken Williams
Sent: Tuesday, January 29, 2008 5:29 PM
Subject: [Vantage] VB Code to Save?
Is there a function to have custom code initiate a save of the entry
you're on?
I've setup a checkbox on order entry that when checked and the document
is saved triggers a BAM to print a special report for me. This works
great, but if someone needs to re-print they have to uncheck the box,
save, check the box, save. Not the end of the world obviously.
However, I'm thinking creating a button and some code like this would
work great if there's a way to call a save:
Private Sub btnPrnReport_Click(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnPrnReport.Click
'// ** Place Event Handling Code Here **
if
(edvOrderHed.dataView(edvOrderHed.Row)("CheckBox10")=="True") then
edvOrderHed.dataView(edvOrderHed.Row)("CheckBox10")="False"
*savefunction()
endif
edvOrderHed.dataView(edvOrderHed.Row)("CheckBox10")="True"
*savefunction()
Of Stephen Edginton
oTrans.Update()
Behalf
Of Ken Williams
you're on?
if
*savefunction()
endif
*savefunction()
