VB Code help - referring to a Foreign Key
Never tried it on a ud field... Interesting idea.
If you try it (and it works) let us know... it sure does open up some easy ways to fill in some holes in Vantage (sans code - all the better!)
Rob
--- Original Message ---
Sent:Fri 5/15/09 9:18 am
To:<vantage@yahoogroups.com>
Subj:RE: [Vantage] Re: VB Code help - referring to a Foreign Key
Could this could be a solution for the perennial question of "how do I inactivate a PartBin"? Define PartBin.Checkbox01 (or whatever) to signify "inactive" and use this to filter.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Robert Brown
Sent: Thursday, May 14, 2009 4:38 PM
Subject: Re: [Vantage] Re: VB Code help - referring to a Foreign Key
The control has a BO method associated with it - In the case of Rev (for Part) - it is probably a GetByID method.
When you fill in this info (Approved=True), you are essentially passing GetByID() an additional search criteria argument.
Rob
Sent: Thursday, May 14, 2009 3:40:03 PM
Subject: RE: [Vantage] Re: VB Code help - referring to a Foreign Key
I'm not quite getting this. What does the SearchFilter property of a Vantage control do?
    bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Rob Bucek
Sent: Thursday, May 14, 2009 3:35 PM
To: vantage@yahoogroups .com
That's a tidy little trick...where did you learn that? Are there other
fields that works well with?
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg com/>
(Click the logo to view our site)
____________ _________ _________ __
Of Robert Brown
Sent: Thursday, May 14, 2009 2:02 PM
I think you guys are overcomplicating things.
Open sales order entry and go into customization.
Navigate to the Lines Tab & click on the part rev control.
In the properties window for that control (Datasource: OrderDtl,
Datafield: RevisionNumber) , look for a properties line called
"SearchFilter" . I'm betting the value is null.
Try entering (without the quotes) "Approved=True" and save the
customization.
Reopen sales entry & look at the same control. If the parameters you
entered (Approved=True) are still there - great: Just test the app with
a partnumber causing you entry problems (entry of an unapproved rev) and
verify the filtering has solved your problem.
If it hasn't, then you're back to hard coding a VB subroutine (as you
are doing below).
Most part rev entry fields are capable of having this parameter entered.
Rob
I am trying to validate that the Rev on a part is approved during order entry. I have customized the form to display a foreign key from the PartRev table.
I want to display an alert if the Rev is not approved. I'm not sure if I am going about this the best way, but here's what I am trying:
Private Sub OrderDtl_AfterFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles OrderDtl_Column.ColumnChanged
'here I want to check to see if the PartRev is approved such as:
If args.Row("[Approved]") = False Then...
but this field is not part of the OrderDtl table. How can I refer to the field PartRev.Approved which is part of a foreign key?
End Sub
Also, I am a newbie at VB.Net but a long time VBA programmer. Where might I find good documentation that would help me answer questions like this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
Randy,
You need to declare the partrev view as a variable i.e.
Dim edvPR As EpiDataView = CType(oTrans.EpiDataViews("PartRev"),
EpiDataView)
This will allow you to then declare individual fields within that
view...
Dim vAprv As Boolean = edvPR.dataView(edvPR.Row)("Approved")
Maybe that will help you get going in the right direction..let me know
if you need more..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/>
Of Randy
Sent: Wednesday, May 13, 2009 11:26 AM
Subject: [Vantage] VB Code help - referring to a Foreign Key
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
Rob,
Thanks for your help. I think I am close but I got an error: Error
Detail
Object reference not set to an instance of an object.
The error went away when I remmed out the second statement: Dim vAprv As
Boolean...
I placed the code inside my Private Sub OrderDtl_AfterFieldChange...
Is this the right location for both lines or do they have to be declared
elsewhere?
Randy Weber
Of Rob Bucek
Sent: Wednesday, May 13, 2009 11:42 AM
Subject: RE: [Vantage] VB Code help - referring to a Foreign Key
Randy,
EpiDataView)
view...
if you need more..
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
It should all be under your sub try:
If edvPR.dataView(edvPR.Row)("Approved") = False Then....
With those Boolean ones Im not sure if at times a 1 or 0 may be
appropriate as that is actually the value you will see in the tables
themselves.
Rob Bucek
FAX: 715-284-4084
Of Randy Weber
Sent: Wednesday, May 13, 2009 1:34 PM
Rob,
Detail
Boolean...
elsewhere?
Randy Weber
Behalf
Of Rob Bucek
Randy,
EpiDataView)
view...
if you need more..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Behalf
Of Randy
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
Dear Randy:
I need to do exactly the same thing. I'm on 8.03.404.
Assuming that you can get this to work, would you be willing to share any part of it?
Lynn
> End Sub
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
Rob,
I got it - sort of. The problem was that I was referring to PartRev as
the ViewName when I should have been using the name of the foreign key I
created called 'Rev'. Below works, but with another issue.
'Rev is a Foreign Key I created tying OrderDtl.PartNum to the
PartRev table.
Dim edvPR As EpiDataView = CType(oTrans.EpiDataViews("Rev"),EpiDataView)
vAprv = edvPR.dataView(edvPR.Row)("Approved")
My other issue is that what gets returned is the previous value as
opposed to the current value. For example:
Rev 2 is current on the order.
I change to Rev 1 - not Approved. Return value=true
I choose Rev 2 - Approved. Return value=false
I tried changing from BeforeFieldChange to AfterFieldChange and I get
the same result - it always returns the previous value. Any suggestions?
Randy
Of Rob Bucek
Sent: Wednesday, May 13, 2009 1:58 PM
themselves.
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy Weber
Rob,
Detail
Boolean...
elsewhere?
Randy Weber
Behalf
Of Rob Bucek
Randy,
EpiDataView)
view...
if you need more..
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
My apologies Randy, when I gave that example I should have mentioned
that you need to modify that by the name given to your view. Perhaps I
could have saved you some time. Have you done any trace logging with
data changes to see what methods are being called? This might point you
to a more appropriate trigger for what you are trying to do.
If I struggle anywhere its usually finding an event on a particular form
that is good for what I'm trying to capture, change, or what have you.
Try setting up some message boxes with the variables you are trying to
get and see what methods are firing and what the value is at the time.
Course the more that I think about it, if it were me I'd be using a BPM
to do what you're trying to accomplish..
Rob Bucek
FAX: 715-284-4084
Of Randy Weber
Sent: Thursday, May 14, 2009 8:06 AM
Rob,
PartRev table.
Randy
Behalf
Of Rob Bucek
themselves.
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy Weber
Rob,
Detail
Boolean...
elsewhere?
Randy Weber
Behalf
Of Rob Bucek
Randy,
EpiDataView)
view...
if you need more..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> <http://www.dsmfg.com/
<http://www.dsmfg.com/> > >
Behalf
Of Randy
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
Rob,
I got it. Honestly, I'm not sure what I did different, but this is
working. Thanks again for your help.
As
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "RevisionNum"
messagebox.show("Approved = " & vAprv)
Case Else
End Select
End Sub
Of Rob Bucek
Sent: Thursday, May 14, 2009 8:31 AM
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy Weber
Rob,
PartRev table.
Randy
Behalf
Of Rob Bucek
themselves.
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy Weber
Rob,
Detail
Boolean...
elsewhere?
Randy Weber
Behalf
Of Rob Bucek
Randy,
EpiDataView)
view...
if you need more..
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
Rockin!
Rob Bucek
FAX: 715-284-4084
Of Randy Weber
Sent: Thursday, May 14, 2009 9:14 AM
Rob,
As
Case "RevisionNum"
Case Else
End Select
End Sub
Behalf
Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy Weber
Rob,
PartRev table.
Randy
Behalf
Of Rob Bucek
themselves.
Rob Bucek
FAX: 715-284-4084
Behalf
Of Randy Weber
Rob,
Detail
Boolean...
elsewhere?
Randy Weber
Behalf
Of Rob Bucek
Randy,
EpiDataView)
view...
if you need more..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/> > <http://www.dsmfg.com/ <http://www.dsmfg.com/>
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > > >
Behalf
Of Randy
PartRev table.
End Sub
this.
thanks in advance,
Randy Weber
IT Manager
TLC Electronics
I have a BAQ that uses one table (the JobHead table). I have several
different criteria that I need to pass through the BAQ. I need it to only
show Jobs that are not Closed, Jobs that are Released, Jobs that are Ready
for Mass Print. I have all of these criteria set up with the AND condition.
Then I also need it to show only for a list of Part Numbers that I have
(there are 9 different Part Numbers).
When I run the BAQ, I receive Unreleased Jobs, Closed Jobs and Jobs not
ready for Mass Print (MRP Jobs). I have tried the AND condition fields at
the top of the BAQ and the bottom of the BAQ. I only have one table, so I
know it is not a Join issue.
Is there a known problem in BAQ under Vantage 803.407C?
Thank you
Jeff
With all those conditions how are you joining them? I assume you
control your list by partnum = xxx and or partnum = yyy. Do you have an
'AND' join between all the others, then try a left paren before your
part list, use or conditions between part numbers followed by a right
paren? Or do I have it all mucked up with how you're setting it up?
JobClosed = False AND JobReleased = True And MassPrint = True And
(PartNum = 123 OR PartNum = ABC Or PartNum = etc)
only
Ready
condition.
at
I
Rob Bucek
FAX: 715-284-4084
Of Jeff Stockard
Sent: Thursday, May 14, 2009 9:39 AM
Subject: [Vantage] BAQ Odd behavior
only
Ready
condition.
at
I
Thank you
Jeff
That did it. I didn't know what the column LeftP was used for. Then I
looked over on the other side and there was a RightP column. I didn't know
that you could use them for grouping.
Thanks for the help and the lesson Rob!
Jeff
Rob Bucek
Sent: Thursday, May 14, 2009 10:57 AM
Subject: RE: [Vantage] BAQ Odd behavior
only
Ready
condition.
at
I
Rob Bucek
FAX: 715-284-4084
Behalf
Of Jeff Stockard
only
Ready
condition.
at
I
Thank you
Jeff
In the properties window for that control (Datasource: OrderDtl, Datafield: RevisionNumber), look for a properties line called "SearchFilter". I'm betting the value is null.
Try entering (without the quotes) "Approved=True" and save the customization.
Reopen sales entry & look at the same control. If the parameters you entered (Approved=True) are still there - great: Just test the app with a partnumber causing you entry problems (entry of an unapproved rev) and verify the filtering has solved your problem.
If it hasn't, then you're back to hard coding a VB subroutine (as you are doing below).
Rob
Sent: Wednesday, May 13, 2009 1:17:59 PM
Subject: [Vantage] Re: VB Code help - referring to a Foreign Key
Dear Randy:
Lynn
> Private Sub OrderDtl_AfterField Change(ByVal sender As object, ByVal args As DataColumnChangeEve ntArgs) Handles OrderDtl_Column. ColumnChanged
> If args.Row("[Approved ]") = False Then...
> End Sub
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
Thanks, Rob. That's a nice shortcut. I'm a newbie at this so I had no
idea this was available. Our situation requires that we sometimes book
an order with an un-approved rev, so I still needed to learn how to give
a warning if it's not approved, yet allow them to book it. But this is a
nice way to accomplish the same thing in other places.
Randy Weber
Of Robert Brown
customization.
are doing below).
Rob
<mailto:lynn.khalife%40core-mfg.com> >
Dear Randy:
any part of it?
Lynn
the PartRev table.
ColumnChanged
> End Sub
this.
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
Rob Bucek
FAX: 715-284-4084
Of Robert Brown
customization.
are doing below).
Rob
Dear Randy:
any part of it?
Lynn
the PartRev table.
ColumnChanged
> End Sub
this.
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
What you are doing should be easy. Can't tell where you went astray without seeing your BAQ code.
Rob
Sent: Thursday, May 14, 2009 10:39:23 AM
Thank you
Jeff
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Of Robert Brown
customization.
are doing below).
Rob
Dear Randy:
any part of it?
Lynn
the PartRev table.
ColumnChanged
> End Sub
this.
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
This is new to me but I can tell you how it behaved.
I set the search filter to Approved=True per Robert Brown's advice.
After that, when entering a part on a sales order, the Rev combo
displayed only Approved Revisions. Pretty slick - huh?
Randy Weber
Of Brian W. Spolarich
Sent: Thursday, May 14, 2009 2:40 PM
Vantage control do?
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
Behalf Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Behalf
Of Robert Brown
customization.
are doing below).
Rob
Dear Randy:
any part of it?
Lynn
the PartRev table.
ColumnChanged
> End Sub
this.
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
Rob
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg. com/>
Of Robert Brown
customization.
are doing below).
Rob
<mailto:lynn. khalife%40core- mfg.com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Dear Randy:
any part of it?
Lynn
the PartRev table.
ColumnChanged
> End Sub
this.
> thanks in advance,
> Randy Weber
> IT Manager
> TLC Electronics
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
