VB Code help... looks sloppy to me
Jeremy,
As I stated before do the code in a BPM and it will be as efficient as
possible in terms of Performance.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Wed, Mar 27, 2013 at 2:16 PM, chan213419 <chan213419@...> wrote:
> Thanks for all your help everyone!
> This UD will have CustID's saved to it that are considered "Return To
> Customers". I believe Mr. Giese is correct in that these records should be
> built into the Customer Maintenance screen negating the need for the
> Bor.GetRows portion of the code. The code below, thanks to Mr. tkoch77,
> worked. After brainstorming more over this and paying close attention to
> Jose's mention of performance issues I am beginning to wonder if the code
> below is efficient. Certainly it's more efficient than my fist crack, but
> now I am wondering if I have to use the BoReader at all. What do you guys
> think?
> Private Sub edvCustomer_EpiViewNotification(ByVal view As EpiDataView,
> ByVal args As EpiNotifyArgs)
> If (args.Row > -1 AndAlso
> edvCustomer.DataView(edvCustomer.Row)("ShortChar05") <> "" AndAlso
> edvCustomer.DataView(edvCustomer.Row)("ShortChar06") = "") Then
> Dim bor As BOReader = New BOReader(oTrans.Session.ConnectionPool)
> Dim wc as String = String.Format("CustID = '{0}'",
> edvCustomer.DataView(edvCustomer.Row)("ShortChar05"))
> Dim ds as DataSet = bor.GetRows("Customer", wc,
> ("Name,Address1,Address2,Address3,City,State,Zip,Country"))
> If ds.Tables(0).Rows.Count > 0 Then
> txtboxLIMSRetToAddr.Value = ds.Tables(0).Rows(0)("Name") &
> Environment.NewLine & ds.Tables(0).Rows(0)("Address1") &
> ds.Tables(0).Rows(0)("Address2") & Environment.NewLine &
> ds.Tables(0).Rows(0)("Address3") & Environment.NewLine &
> ds.Tables(0).Rows(0)("City") & Environment.NewLine &
> ds.Tables(0).Rows(0)("State") & Environment.NewLine &
> ds.Tables(0).Rows(0)("Zip") & Environment.NewLine &
> ds.Tables(0).Rows(0)("Country")
> End If
> End IF
> End Sub
> --- In vantage@yahoogroups.com, Joshua Giese <jgiese@...> wrote:
> > What will the UD field be used for? Epicor already has linking from
> customer record to customer record built in depending on what you are
> trying to do
> > Joshua Giese
> > CTO
> > 920.437.6400 Ext. 337
> > Site ID: 27450-E905700B2-SQL64
> > ----- Original Message -----
> > From: "chan213419" <chan213419@...>
> > Sent: Wednesday, March 27, 2013 8:33:30 AM
> > Subject: [Vantage] Re: VB Code help... looks sloppy to me
> > Customer Maintenance screen. Goal: populate a UD field (ShortChar05)
> with another CustID, and display address information for that UD-CustID
> (need to keep UD-CustID totally separate with CustID loaded in Customer
> Maintenance screen).
> > It does work... but as Jose pointed out, I am hitting the server
> multiple times for the same thing... I don't want to slow their system down
> with something so simple.
> > Thanks sir!
> > --- In vantage@yahoogroups.com , Joshua Giese <jgiese@> wrote:
> > > Ha it's certainly a good attempt but a bit sloppy yes. Let's start
> with what screen that is in? Depending what you have available to you you
> might be able to really sand this down to something simple
> > > Joshua Giese
> > > CTO
> > > From: "chan213419" <chan213419@>
> > > Sent: Wednesday, March 27, 2013 8:06:35 AM
> > > Subject: [Vantage] VB Code help... looks sloppy to me
> > > Good morning!
> > > I achieved creating a textbox that displays multiple fields (address
> fields). The code below is how I got it to work. As you can see I am
> linking/writing column individually (see dim ds1-7). I believe there should
> be a simpler way. Instead of coding each column, can I condense this into
> one line? Like I said, the code works but I am looking for a simpler way to
> code this.
> > > Dim ds as DataSet = bor.GetRows("Customer", wc, "Name")
> > > Dim ds1 as DataSet = bor.GetRows("Customer", wc, "Address1")
> > > Dim ds2 as DataSet = bor.GetRows("Customer", wc, "Address2")
> > > Dim ds3 as DataSet = bor.GetRows("Customer", wc, "Address3")
> > > Dim ds4 as DataSet = bor.GetRows("Customer", wc, "City")
> > > Dim ds5 as DataSet = bor.GetRows("Customer", wc, "State")
> > > Dim ds6 as DataSet = bor.GetRows("Customer", wc, "Zip")
> > > Dim ds7 as DataSet = bor.GetRows("Customer", wc, "Country")
> > > txtboxLIMSRetToAddr.Value = ds.Tables(0).Rows(0)(0) &
> Environment.NewLine & ds1.Tables(0).Rows(0)(0) & Environment.NewLine &
> ds2.Tables(0).Rows(0)(0) & Environment.NewLine & ds3.Tables(0).Rows(0)(0) &
> Environment.NewLine & ds4.Tables(0).Rows(0)(0) & Environment.NewLine &
> ds5.Tables(0).Rows(0)(0) & Environment.NewLine & ds6.Tables(0).Rows(0)(0) &
> Environment.NewLine & ds7.Tables(0).Rows(0)(0)
> > > End If
> > > End IF
> > > If (args.Row > -1)
> > > IF edvCustomer.DataView(edvCustomer.Row)("ShortChar05") = ""
> > > txtboxLIMSRetToAddr.Value = ""
> > > End IF
> > > End If
> > > End Sub
Good morning!
I achieved creating a textbox that displays multiple fields (address fields). The code below is how I got it to work. As you can see I am linking/writing column individually (see dim ds1-7). I believe there should be a simpler way. Instead of coding each column, can I condense this into one line? Like I said, the code works but I am looking for a simpler way to code this.
Private Sub edvCustomer_EpiViewNotification(ByVal view As EpiDataView, ByVal args As EpiNotifyArgs)
If (args.Row > -1 AndAlso edvCustomer.DataView(edvCustomer.Row)("ShortChar05") <> "" AndAlso edvCustomer.DataView(edvCustomer.Row)("ShortChar06") = "") Then
Dim wc as String = String.Format("CustID = '{0}'", edvCustomer.DataView(edvCustomer.Row)("ShortChar05"))
txtboxLIMSRetToAddr.Value = ds.Tables(0).Rows(0)(0) & Environment.NewLine & ds1.Tables(0).Rows(0)(0) & Environment.NewLine & ds2.Tables(0).Rows(0)(0) & Environment.NewLine & ds3.Tables(0).Rows(0)(0) & Environment.NewLine & ds4.Tables(0).Rows(0)(0) & Environment.NewLine & ds5.Tables(0).Rows(0)(0) & Environment.NewLine & ds6.Tables(0).Rows(0)(0) & Environment.NewLine & ds7.Tables(0).Rows(0)(0)
End If
End IF
If (args.Row > -1)
End IF
End If
End Sub
A few pointers
1) You can re-use a variable they are not final so you can use the same
data set and assign multiple values
A variable such as
Dim i AS Integer
i=0
can also be
i=2
i=3 etc... no need to decalre 7 different integers to use it just once.
2) Bo.GetRows takes a list of fields so you don't have to call that
function more than once, simply pass it a list of the fields you want and
it will return a table with all the fields. After that you can loop through
the fields concatenating them into one string using a basic for loop or
while loop
4) Also it should be noted (I dont know what screen you are on) but you
already have edvCustomer so usually all these fields are available in the
data view, and if they are not you can add an FKV which will bring these
fields to you instead of doing a lookup yourself.
5) If you are not familiar with data views and how they work they ahve a
flew classes at insights that might help
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Mar 27, 2013 at 9:06 AM, chan213419 <chan213419@...> wrote:
> Good morning!
> code this.
> End If
> End IF
> If (args.Row > -1)
> End IF
> End If
> End Sub
Ha it's certainly a good attempt but a bit sloppy yes. Let's start with what screen that is in? Depending what you have available to you you might be able to really sand this down to something simple
Joshua Giese
CTO
Good morning!
End If
End IF
If (args.Row > -1)
End IF
End If
End Sub
I also forgot to point out that by called Bo.GetRows multiple times you are
making a trip to the server and back every time, the performance hit of
this is huge! Try to go to the server only once and get as much as what
you'll need! Performance is king when it comes to Epicor.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Mar 27, 2013 at 9:18 AM, Jose Gomez <jose@...> wrote:
> A few pointers
> A variable such as
> Dim i AS Integer
> i=0
> can also be
> i=2
> while loop
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> Good morning!
>> code this.
>> End If
>> End IF
>> If (args.Row > -1)
>> End IF
>> End If
>> End Sub
Thanks so much Jose!
I follow you on not having to run the BO.GetRows more than once, what I don't understand is how to code returning multiple fields from that result. I tried below but I got many different errors, and when I didn't get errors it would only return the FIRST (Name) result and display that only.
Dim ds as DataSet = bor.GetRows("Customer", wc, "Name" & "City" & "Country")
If ds.Tables(0).Rows.Count > 0 Then txtboxLIMSRetToAddr.Value = ds.Tables(0).Rows(0)(0)
Do you know where I went wrong above?
Thanks sir!
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> A few pointers
> A variable such as
> Dim i AS Integer
> i=0
> can also be
> i=2
> while loop
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Good morning!
> > code this.
> > End If
> > End IF
> > If (args.Row > -1)
> > End IF
> > End If
> > End Sub
the Signature on the BO should tell you this, but it is
Adapter, WhereClause, FieldListCommaSeparated
*Jose C Gomez*
*Software Engineer*
E: jose@...
> "Country")
> Thanks sir!
> > A few pointers
> > A variable such as
> > Dim i AS Integer
> > i=0
> > can also be
> > i=2
> through
> > while loop
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > <http://www.linkedin.com/in/josecgomezhttp://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomezhttp://www.twitter.com/joc85>
> > > Good morning!
> should
> into
> way to
> > > code this.
> Environment.NewLine
> > > End If
> > > End IF
> > > If (args.Row > -1)
> > > End IF
> > > End If
> > > End Sub
Do a search on the user group for GetRows and you will find tons of examples of it's proper use :)
http://lmgtfy.com/?q=Epicor+GetRows
Joshua Giese
CTO
Sent: Wednesday, March 27, 2013 8:28:37 AM
Thanks sir!
--- In vantage@yahoogroups.com , Jose Gomez <jose@...> wrote:
> A few pointers
> A variable such as
> Dim i AS Integer
> i=0
> can also be
> i=2
> while loop
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> < http://www.linkedin.com/in/josecgomez http://www.facebook.com/josegomez >
> < http://www.google.com/profiles/jose.gomez http://www.twitter.com/joc85 >
> < http://www.josecgomez.com/professional-resume/ >
> < http://www.josecgomez.com/feed/ >
> < http://www.usdoingstuff.com >
> > Good morning!
> > code this.
> > End If
> > End IF
> > If (args.Row > -1)
> > End IF
> > End If
> > End Sub
Customer Maintenance screen. Goal: populate a UD field (ShortChar05) with another CustID, and display address information for that UD-CustID (need to keep UD-CustID totally separate with CustID loaded in Customer Maintenance screen).
It does work... but as Jose pointed out, I am hitting the server multiple times for the same thing... I don't want to slow their system down with something so simple.
Thanks sir!
> Joshua Giese
> CTO
> Good morning!
> End If
> End IF
> If (args.Row > -1)
> End IF
> End If
> End Sub
What will the UD field be used for? Epicor already has linking from customer record to customer record built in depending on what you are trying to do
Joshua Giese
CTO
Thanks sir!
> Joshua Giese
> CTO
> Good morning!
> End If
> End IF
> If (args.Row > -1)
> End IF
> End If
> End Sub
Try this... not tested
 Dim ds as DataSet = bor.GetRows("Customer", wc, "Name,Address1,Address2,Address3,City,State,Zip,Country")
   If ds.Tables(0).Rows.Count > 0 Then                             Â
txtboxLIMSRetToAddr.Value = ds.Tables(0).Rows(0)("Name") & Environment.NewLine & ds.Tables(0).Rows(0)("Address1") & Environment.NewLine & ds.Tables(0).Rows(0)("Address2") & Environment.NewLine & ds.Tables(0).Rows(0)("Address3") & Environment.NewLine & ds.Tables(0).Rows(0)("City") & Environment.NewLine & ds.Tables(0).Rows(0)("State") & Environment.NewLine & ds.Tables(0).Rows(0)("Zip") & Environment.NewLine & ds.Tables(0).Rows(0)("Country")Â Â Â Â Â Â Â Â
Sent: Wednesday, March 27, 2013 9:33 AM
Thanks sir!
> Joshua Giese
> CTO
> Good morning!
> End If
> End IF
> If (args.Row > -1)
> End IF
> End If
> End Sub
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Jeremy
Ideally since ShortShar05 already contains the other customer id, you
should not have to go to the server at all. On the Actual Customers Get By
Id Call, you should within a Post Proc BPM Gather the information you want
(since you are already on the server) This will improve performance and
make the code ubiquitous across the board.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> From: chan213419 <chan213419@...>
> screen).
> Thanks sir!
> > Joshua Giese
> > CTO
> > Good morning!
> code this.
> > End If
> > End IF
> > If (args.Row > -1)
> > End IF
> > End If
> > End Sub
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
Alternatively you could set the dataview field instead of the textbox.
DataRow drEdvCust = edvCustomer.DataView(edvCustomer.Row);
If (args.Row > -1 && dr Edv Cust[ "ShortChar05"] != "" && dr Edv Cust[ "ShortChar06"] == "")
BOReader boReader = new BOReader(oTrans.Session.ConnectionPool);
string where = string.Format("CustID = '{0}'", dr Edv Cust[ "ShortChar05"]);
DataSet dsCust = boReader.GetRows("Customer", where, "Name,Address1,Address2,Address3,City,State,Zip,Country");
If (dsCust.Tables[0].Rows.Count > 0)
DataRow drOtherCust = ds.Tables[0].Rows[0];
dr Edv Cust[ "ShortChar06"] = string.Format("{0} \r\n{1} \r\n{2} \r\n{3} \r\n{4}, {5} {6} \r\n{7}", drOtherCust[ "Name"], drOtherCust[ "Address1"] , drOtherCust[ "Address2"], drOtherCust[ "Address3"], drOtherCust[ "City"], drOtherCust[ "State"], drOtherCust[ "Zip"], drOtherCust[ "Country"]);
edvCustomer.Notify(new EpiNotifyArgs(oTrans, edvCustomer.Row, edvCustomer.Column);
Joshua Giese
CTO
Sent: Wednesday, March 27, 2013 8:51:50 AM
Subject: Re: [Vantage] Re: VB Code help... looks sloppy to me
Thanks sir!
> Joshua Giese
> CTO
> Good morning!
> End If
> End IF
> If (args.Row > -1)
> End IF
> End If
> End Sub
(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo ! Groups Links
This UD will have CustID's saved to it that are considered "Return To Customers". I believe Mr. Giese is correct in that these records should be built into the Customer Maintenance screen negating the need for the Bor.GetRows portion of the code. The code below, thanks to Mr. tkoch77, worked. After brainstorming more over this and paying close attention to Jose's mention of performance issues I am beginning to wonder if the code below is efficient. Certainly it's more efficient than my fist crack, but now I am wondering if I have to use the BoReader at all. What do you guys think?
Dim ds as DataSet = bor.GetRows("Customer", wc, ("Name,Address1,Address2,Address3,City,State,Zip,Country"))
txtboxLIMSRetToAddr.Value = ds.Tables(0).Rows(0)("Name") & Environment.NewLine & ds.Tables(0).Rows(0)("Address1") & ds.Tables(0).Rows(0)("Address2") & Environment.NewLine & ds.Tables(0).Rows(0)("Address3") & Environment.NewLine & ds.Tables(0).Rows(0)("City") & Environment.NewLine & ds.Tables(0).Rows(0)("State") & Environment.NewLine & ds.Tables(0).Rows(0)("Zip") & Environment.NewLine & ds.Tables(0).Rows(0)("Country")
End If
End IF
End Sub
> Joshua Giese
> CTO
> Thanks sir!
> > Joshua Giese
> > CTO
> > Good morning!
> > End If
> > End IF
> > If (args.Row > -1)
> > End IF
> > End If
> > End Sub
Thank you very much Mr. koch! This worked wonderfully!
> Â Dim bor As BOReader = New BOReader(oTrans.Session.ConnectionPool)
> Â Dim wc as String = String.Format("CustID = '{0}'", edvCustomer.DataView(edvCustomer.Row)("ShortChar05"))
> Â Dim ds as DataSet = bor.GetRows("Customer", wc, "Name,Address1,Address2,Address3,City,State,Zip,Country")
> Thanks sir!
> > Joshua Giese
> > CTO
> > Good morning!
> > End If
> > End IF
> > If (args.Row > -1)
> > End IF
> > End If
> > End Sub
> >Â
