Vantage Webservices Errors with Windows 2008 64bit Installation
It looks like I've got my problem fixed with the aid of Epicor support.
I needed to go into the Server roles and install IIS 6 compatibility.
The do an IIS reset and re-install the vantage webservices.
Best Regards,
Steve Patterson
IT Programmer
Connection Technology Center
7939 Rae Boulevard
Victor, NY 14564
1-800-999-5290 ext. 802
1-585-924-5900 ext. 802
pattersons@... <blocked::mailto:pattersons@...>
www.ctconline.com <https://www.ctconline.com/>
Of Steven Patterson
Sent: Friday, March 05, 2010 10:57 AM
Subject: [Vantage] Vantage Webservices Errors with Windows 2008 64bit
Installation
Hi everyone,
I'm installing Vista 8.03.408 running progress on a new Windows 2008
64bit server and I was able to get the system up and running, however,
I've been having a lot of trouble with getting the vantage web services
working.
I was unable to get the WS-Configuration tool to work, so Epicor support
recommended I install the web services onto a different computer and
then copy them to the new server. So, I've done that, and after copying
it over, I edited the web.config file to reference the new appserverurl.
Next I configured IIS to run in 32 bit compatibility mode and set up the
vantage services directory in IIS to run as an application.
I can view all of the web services and methods through the web browser.
When I try to execute one I get an error message (I tried in both
Service Connect and the WS-Tester; same error in both).
The error I received is
"Web service error : The type initializer for
'Epicor.Mfg.WS.Framework.WSSettingsHandler' threw an exception."
Has anyone encountered this before, or done a similar installation? Any
help would be appreciated. Thanks.
Best Regards,
Steve Patterson
IT Programmer
7939 Rae Boulevard
Victor, NY 14564
pattersons@... <mailto:pattersons%40ctconline.com>
<mailto:pattersons%40ctconline.com> >
<https://www.ctconline.com/> >
Hi everyone,
working.
Best Regards,
Steve Patterson
IT Programmer
7939 Rae Boulevard
Victor, NY 14564
