Vantage via VPN
Hi Erik
I have used 33K modems before into a modem pool and it is not a nice
user experience as it is the srceens are slow to refresh
Now we are using 1M download and 256K upload and client sites are using
512K download and 256K upload
Gary
_____
Sent: 18 January 2005 21:04
Subject: [Vantage] Vantage via VPN
Anyone using the Vantage client through a VPN connection? If so, how
well does it work or not work? How fast are you connections and what
kind of problems have you run into?
We are running Vantage 6.0 with a fractional T1, 384K dedicated to
data and the clients have cable modems.
Thanks!
Erik Smalley
IT Manager
Milford Enterprises Inc.
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Thanks!
Erik Smalley
IT Manager
Erik,
Set up terminal server and run Vantage locally (at your shop) at a minimum.
You will not like the results of running Vantage over a VPN directly.
Running via TS or some other remote desktop is the only real solution I have
seen work reasonably.
Good luck,
Aaron Hoyt
Vantage Plastics
Sent: Tuesday, January 18, 2005 4:04 PM
Thanks!
Erik Smalley
IT Manager
Yahoo! Groups Links
We use citrix.
Scale 1 to 10
I guess maybe 6
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Thanks!
Erik Smalley
IT Manager
Yahoo! Groups Links
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
Hi Erik
We use terminal services and have no operational problems with it. It
is sometimes faster than a local client.
I believe there are some issues with crystal dll's that need copying
onto the terminal server.and we have had issues with having the same
printer drivers on the server that are installed on the client.
Vantage 8, I believe will be thin client anyway and it is questionable
that terminal services will still be required for Vantage.
Hope this helps
Gary
_____
Thanks!
Erik Smalley
IT Manager
_____
Yahoo! Groups Links
