Vantage Version Housekeeping
I don't need to get that detailed. This is just 14 small references to some OCX routines and mfg.exe that are under "mfgsys60". All I need to do is remove all references to the old folder from their registry - not all of Vantage or Progress. Everything else works great. The Keys that are involved I am sure get overwritten in the client install process (not the Progress install which does not need to be done again between 6.0 and 6.1 - so no remove needed). It was just my own darned laziness that persuaded me to not re-run the client install. Pointing the shortcut to mfgsys61 was so much easier - but that did not update the old mfgsys60 references - mainly in registering the OCXs.
-Todd C.
Sent: Tuesday, January 25, 2005 4:38 PM
Subject: RE: [Vantage] Vantage Version Housekeeping
Removing vantage from the clients was a huge pain for us, too. After doing
a little digging on the Progress Support site, I constructed this document
to manually remove Progress and Vantage. It is extremely quick to do, works
great and doesn't require you to run the uninstall program from "Add or
Remove Programs" in the Control Panel. The dll's and other stuff left
behind get overwritten on the next install.
Hope this helps,
Chris
Christopher Gitzlaff, MSCIS
Manager - Information Systems & Technology
Major Industries, Inc.
Phone: 715.842.4616 ext. 323
Email: cgitzlaff@...
SOP #6501_001: Uninstalling Progress by Removing Registry Entries Manually
Remove the following registry entries:
HKEY_CURRENT_USER\Software\PSC\PROGRESS\<version>
HKEY_LOCAL_MACHINE\SOFTWARE\PSC\PROGRESS\<version>
HKEY_LOCAL_MACHINE\SOFTWARE\PSC\SHARED
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Progr
ess9.1D
Edit the Start Menu for All Users:
Remove "Manufacturing By Epicor"
Remove "Progress 9.1D"
Reboot and reinstall.
Sent: Tuesday, January 25, 2005 4:28 PM
Subject: Re: [Vantage] Vantage Version Housekeeping
Todd,
I've only been able to get the registry cleared out and all speed issues
resolved by wiping out the workstation's drive and reinstalling everything.
Before that, just strange slow spots - like Part tracker or Job Tracker. It
might pull up in less the 1 second one time then the next 12 attempts will
take 30 seconds each.
I'm at the point of writing a Vantage/Progress registry cleaner. I'm just
taking care of 30 pc's, I really feel the those out there with more than 50.
GRRRRRR !!!!!
Charles
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, January 25, 2005 4:34 PM
> Great suspicion. They are indeed screaming. Actually only when the
> exit
Vantage and have to get back in and it won't start..
> When I upgraded from 6.0 to 6.10 I cheated and did nto re-install the
clients. I just re-pointed the shortcuts to mfgsys61. Now with mfgsys60
unshared as suggested all of the sudden these people can't login to Vantage.
There are 14 registry entries pointing to mfgsys60 including mfg.exe. Ooops.
So I get to now reshare the folder and then hit every Vantage user to update
them by reinstalling the client part (pretty quick w/o the Progress part but
still a hike all of the place - just what I was avoiding by cheating).
Or.....perhaps I could delete everything but the referenced files and leave
the "stub" folder there until I eventually clean them all up.
> Just a word of warning for those who upgraded clients from 6.0 to 6.10
> the
same way I did.
> -Todd C.
> From: pjw@... [mailto:pjw@...]
> Sent: Tuesday, January 25, 2005 12:44 PM
> Todd,
> The safe play on a server before deleting would be to remove all
permissions
> for access for a month or so. See if anyone screams. Knowing Vantage
> some clients may still be pathed or referencing old dlls, etc...
> Patrick Winter
> From: Todd Caughey [mailto:caugheyt@...]
> Sent: Tuesday, January 25, 2005 11:03 AM
> Subject: [Vantage] Vantage Version Housekeeping
> I'm trying to recover some wasted disk space on our Vantage server.
> We
have
> been on 6.10 for over six months now. Is there any conceivable reason
> to keep the MFGSYS60 folder around any longer? There are no Userform
> or Reports folder items there and the database was long ago deleted
> from the
db
> folder (a nice fat target it was). But the remaining 500+ MB is
> tempting for space recovery too.
> I suspect I could have deleted it a long time ago - at least after
> there
was
> no chance to needing to restore and "go back" to 6.0. So any other
reasons
> to keep it? Any reason to even bother burning it to a CD?
> Thanks,
> -Todd Caughey
> Harvey Vogel Mfg. Co.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
> and
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
< http://docs.yahoo.com/info/terms/> .
> and
> Yahoo! Groups Links
Yahoo! Groups Links
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
I'm trying to recover some wasted disk space on our Vantage server. We have been on 6.10 for over six months now. Is there any conceivable reason to keep the MFGSYS60 folder around any longer? There are no Userform or Reports folder items there and the database was long ago deleted from the db folder (a nice fat target it was). But the remaining 500+ MB is tempting for space recovery too.
I suspect I could have deleted it a long time ago - at least after there was no chance to needing to restore and "go back" to 6.0. So any other reasons to keep it? Any reason to even bother burning it to a CD?
-Todd Caughey
Todd,
The safe play on a server before deleting would be to remove all permissions
for access for a month or so. See if anyone screams. Knowing Vantage some
Patrick Winter
-Todd Caughey
Yahoo! Groups Links
Great suspicion. They are indeed screaming. Actually only when the exit Vantage and have to get back in and it won't start..
When I upgraded from 6.0 to 6.10 I cheated and did nto re-install the clients. I just re-pointed the shortcuts to mfgsys61. Now with mfgsys60 unshared as suggested all of the sudden these people can't login to Vantage. There are 14 registry entries pointing to mfgsys60 including mfg.exe. Ooops. So I get to now reshare the folder and then hit every Vantage user to update them by reinstalling the client part (pretty quick w/o the Progress part but still a hike all of the place - just what I was avoiding by cheating). Or.....perhaps I could delete everything but the referenced files and leave the "stub" folder there until I eventually clean them all up.
Just a word of warning for those who upgraded clients from 6.0 to 6.10 the same way I did.
-Todd C.
Todd,
Patrick Winter
-Todd Caughey
Yahoo! Groups Links
_____
Yahoo! Groups Links
Todd,
GRRRRRR !!!!!
Charles
up.
same way I did.
> -Todd C.
> Todd,
permissions
> Patrick Winter
have
db
was
reasons
> Thanks,
> -Todd Caughey
have
> Yahoo! Groups Links
> _____
> Yahoo! Groups Links
> Yahoo! Groups Links
Hope this helps,
Chris
ess9.1D
Todd,
GRRRRRR !!!!!
Charles
> exit
> the
same way I did.
> -Todd C.
> Todd,
permissions
> Patrick Winter
> We
have
> from the
db
> there
was
reasons
> Thanks,
> -Todd Caughey
have
> Yahoo! Groups Links
> and
> _____
> Yahoo! Groups Links
> and
> Yahoo! Groups Links
Yahoo! Groups Links
