Vantage Ver 5.2 - 64 Bit
Here is what we do:
Vantage Drive = V
Run V:\Progress\netsetup\setup.exe
Run V:\Vantage\OCX\InstOcx.exe
Edit C:\Windows\System32\Drivers\etc\services (for example: Epic50
2500/tcp) You can find the service in the vantage.vtg file, connections=
-S "xxxxx", 2500 is the default port for 5.0, tcp is the protocol.
The services file needs Local Admin rights or Explicit user Rights
(Domain Admin will not work - although Domain Admin can change the
rights).
For Vantage Help:
For Vantage help on Windows Vista we did not have to turn off any
security settings. But we did have to add some registry settings. You
can copy and paste the following text into a text file and name it
something like vant32hlp.reg. Then you can either double click on it to
install or add it to a script.
Vista 32 bit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\ItssRestrictions]
"UrlAllowList"="N:\\vantage\\HELP\\vnhelp_enu.chm;file://;"
Vista 64 bit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\HTMLHelp\1.x\ItssRest
rictions]
For ODBC:
For the older versions of Vantage we had to use the 32bit ODBC Data
Source administrator located in: C:\Windows\SysWow64\odbcad32.exe. This
is not the same one in "Administrative Tools".
Hth,
Jim
Of sarah.vareschi@...
Sent: Tuesday, December 02, 2008 1:43 PM
Subject: RE: [Vantage] Vantage Ver 5.2 - 64 Bit
From what I understand, no. We recently bought new 64 bit boxes for
engineering and were unable to install 5.2. I was not here at the time
so not sure of the specifics, but I was told by IT that it did not work
and they ended up having to set-up remote access for those users.
<DIV><font size="1.5" face="Bookman Old
Style">__________________________________________________________
This email may contain material that is confidential, privileged and/or
attorney work product for the sole use of the intended recipient. Any
review, reliance or distribution by others or forwarding without express
permission is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
__________________________________________________________<DIV><FONT>
Will Vantage 5.2 work on Windows XP 64 bit?
Thank you,
Dina Hieber
Vamco International, Inc.
555 Epsilon Drive, Pittsburgh, PA 15238
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
Website; www.vamcointernational.com
This e-mail message and any files transmitted with it are confidential and
are intended for the sole use of the intended recipient(s). Any unauthorized
use or disclosure is prohibited. Any opinions expressed in the email are
those of the individual and not necessarily the company. If you are not the
intended recipient, please contact the sender by reply email and destroy all
copies of the original message.
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
